Thread: TECH: Audio FAQ
Old July 25th, 2008, 07:37 PM   #13 (permalink)
Permastudent
Overeducated Slacker
Permastudent's Avatar
Vehicle: '08 Spyder GT Rave Red
Rep Power: 1 Permastudent is just really nicePermastudent is just really nicePermastudent is just really nice
Originally Posted by Bart-man View Post
Here are some FAQ's relating to the Audio system in the 4G. I know there are more and I will be updating this as information is available.
H.U. Info:
The stock Head Unit is manufactured by Mitsubishi Electric in Japan ( Thanks ajiuo for this information)
There are two harnesses on the back of the radio. The white one is the main harness the black one sends info the the display above.
Here is a Diagram of the main factory harness (white one)
1 2 3 4 5 6
7 8 _ 9 10 11 12 13
Here is what each pin is.
1 Right Rear Speaker Positive
2 Left Rear Speaker Positive
3 Power Antenna (which we don't have)
4 Illumination Dash Light
5 Left front Speaker Positive
6 Right front Speaker Positive
7 Right Rear Speaker Negative
8 Left Rear Speaker Negative
9 Switched Power
10 Constant Power
11 Dimmer
12 Left Front Speaker Negative
13 Right Front Speaker Negative
Thanks to BONES for the following info on the NON-ROCKFORD system. These are the Speaker wire colors at the speakers for the front door and rear speakers.
Front Left +: White w/Blue Stripe
Front Left -: Black w/Blue Stripe
Front Right +: White w/Red Stripe
Front Right -: Black w/Red Stripe
Rear Left +: Yellow w/Blue Stripe
Rear Left -: Grey
Rear Right +: Yellow w/Green Stripe
Rear Right -: White
AUX:
Currently there is no function for the AUX input on the RF head unit. Once something is available I will post it here.
Also note you can access the Aux mode without the steering wheel by holding the CD button down for more then 3 seconds. ( Thanks ajiuo for this information)
MP3:
When playing MP3 Discs the only information displayed is the folder number and the track number.
AMP installations:
It is very Easy to install an amplifier into the new 4G Eclipse. The Power wire can be routed in two ways.
1. You can use a factory grommet that is located inside the fenderwell area. Remove the drives side tire. Next remove the fender well liner. Now you can run your power wire from your battery into the fender area then to
the access grommet and into the floorboard area of the car. (30 min)
2. There is a nice open area that is just above the brake pedal. Using a step drill or a drill bit about 1/16" larger that the grommet you plan to install drill through your firewall. Check both sides to make sure you are clear of
anything you don't want drilled. Then install your grommet and run you power wire right inside the drivers side foot well. (10 min)
Please don't attempt any of this if you are not familiar with using drill's or installing an amplifier. Also if you would like further assistance please contact me.
IPOD Kits:
As of now the easiest and least expensive way to play your IPOD/MP3 player through your factory system is with an FM Modulator. Currently nobody offers an IPOD solution for the 4G Eclipse. There is however another way to
play your IPOD through your stereo. It involves a JL Audio Cleansweep. What this does is take the factory signal and smooth out any EQ curves your factory system has and then applies it's own DPS with 30 band 4 channel
equalizer to allow your factory Head Unit to work with after market amps without any loss. It converts the factory analog signal to a 24-bit Digital one. As an added bonus you have the ability to have an AUX input for your IPOD or
XM/Sirius Radio. Also being released is an AUX switcher that will expand that input to 3 AUX inputs for even more flexibility. This unit is easy to install and for around $350.00 will give your factory radio all the benefits of an
after market radio.
XM/Sirius:
Currently an FM modulator is the only way of adding satellite radio to the 4G, but this should change in the future and once I have any news I will post it here. Also see IPOD above for options on adding an AUX input to the 4G.
Speakers:
The factory RF System is a 9 speaker system that is made up of the following.
Front dash: 1" Tweeters
Front doors: 6.5" Midbass speakers
Rear side: 6.5" 2-way speakers
Trunk: 10" 150watt dual 2 ohm Rockford Subwoofer.
Updated: 6/1/2006
There have been a lot of questions about certain things still working when you replace you stock radio. Here is the answer. YES.
Just about any feature that comes with a factory radio can be retained when you change to an after market radio. Just about any specialty shop can retain any feature you want. From the factory sub or the steering wheel controls.
*Original Post by blk4g*
Originally Posted by dentedz71guy View Post
I can take a pic of lisa's but she won't get off work until 8 (central time)
I will have your baby.
Permastudent is offline   Reply With Quote
