Old July 10th, 2007, 04:51 PM   #5 (permalink)
RyMac
Go NOLES!!!
RyMac's Avatar
Vehicle: 06 GT 6 spd
Rep Power: 2 RyMac is on a distinguished road
Nevermind, I found out for myself .
OK. Now for the real stats on the Comp T/A's:
First, you have to start with a special order T/A with the following from Pontiac:
* - V87S + Y82 Trans Am Coupe or T-Top
* - Bright Silver Metallic Exterior - 13
* - AQ9 Ultima Graphite Leather Buckets
* - 1SA Option Package
* - R6V Merchandising Option Code
* - T43 Trans Am Spoiler
* - GU5 Performance Axle (Automatics Only)
* - QLC High Performance Tires
Second, SLP will add the following goodies to your ride.
* - Uniquely-Styled hood and cold air induction package (More commonly known as Ram-Air now!) Please note, the Comp T/A hood is of composite construction.
* - Dark gray 10" wide center stripe’
* - Matching gray 'Comp T/A' headlamp door and wheel center cap graphics
* - 3-Dimensional matching gray 'Comp T/A' door graphics
* - 17 x 9 5-spoke Firehawk style alloy wheels(Speedline)
* - BFG P275/40ZR17 Comp T/A performance tires
* - Dual cast aluminum exhaust tips
* - Sport Suspension Package (Std. with manual coupe, Opt. with auto., N/A with -Tops)
* - Hurst Shifter with custom leather wrapped shift knob (N/A with auto)
* - Heavy Duty embroidered 'Comp T/A' floor mats
* - 'Comp T/A' Cloisonne' numbered dash plaque (1 to 200) and Two(2) matching key fobs
* - Mobil 1 synthetic engine oil and rear axle oil, semi-synthetic power steering lube and a premium synthetic media oil filter
For a few bucks more SLP will add:
* - Sport Suspension Package (if you have an auto)
* - BF Goodrich's Comp T/A ‘R1’ Competition series ultra performance tires mounted and balanced on an additional set of 'Comp T/A' wheels. This tire and wheel combination will improve 0-60 mph and 1/4 mile acceleration and handling significantly but will result in much harsher ride quality(stiffer side wall) and reduced tread life(10,000 miles) compared to the standard Comp T/A ZR tires.
- 2 on the left performance exhaust system
Delivery will be dealer direct.
Comp T/A Production Figures:
1995 - 72 Comp T/A's
1996 - 45 Comp T/A's
1997 - 47 Comp T/A's
Total = 164 Comp T/A's produced
1995 - 30 coupe (13 Auto, 17 6-spd)
42 t-top (11 Auto, 31 6-spd)
6 w/sport suspension package
28 w/R1 tire option
1996 - 10 coupe ( 6 Auto, 4 6-spd)
35 t-top (23 Auto, 12 6-spd)
25 w/Torsen
34 w/Lubes
15 w/Hurst
26 w/Suspension
28 w/Engine Cooler
44 w/Floormats
33 w/Car Cover
1997 - 7 coupe ( 2 Auto, 5 6-spd)
40 t-top (15 Auto, 25 6-spd)
31 w/Torsen
8 w/Lubes
29 w/Hurst
25 w/Suspension
33 w/Engine Cooler
43 w/Floormats
33 w/Car Cover
3 w/R1 Tire Option
RyMac is offline   Reply With Quote
