well there is a few things you found out i did even know but, i would of dumped all that and more if i thought somebody really cared... so here we go...
The exhaust was a single in dual out steel muffler
-Replaced With: Single in single out Flowmaster 40 series dumped directly behind the axle... Plus a Test Pipe... People love it becuase unlike most states LA doesn't check emissions or that matter most of the safety requirements at all... so i dumped it to create more bounce... I have wanted to put the super 40 single in dual out with some tips but... im telling you i am haing trouble finding something that will fill the space and look good... i want a fit like the Acura TL ot the Chevy Arcadia... no luck so far
-Replaced With: LT1 Street/Strip Hydraulic Roller Cam .510"/.510" and a Flow Plate that fits it the throttle body.
-Replaced With: New Votech Heads...
The Intake consisted of the box you see, a weak mass air flow sensor, and a crappy airfilter
-Replaced With: K&N and a upgraded Mass air flow sensor once my other one went out...
System was the stock tape player and their Monsoon sound system
-Replaced With: Panasonic Ghost deck... Focal components... and Focal Kevlar 6 1/4 & 6x9s... which are powered by a 375watt Eclipse highs amp... two 10" Eclipse Alums in my hand built Fiberglass enclosure... that was then wrapped in space foam and then Leather... which is powered by two 500watt Eclipse MONO amps... an optium batter Red Top with 3 Feret Cap... and a 50 watt fuse...
Blacked out...
Had before it was played out... Had 2 Slim 7" screens in the visors and had my PS2 that was built in to glove box with wireless remotes... I do miss going to school and meeting all my friends b4 school to play Teken Tag / Devil May Cry 2...
i think that is it... plus to add to the list you aquired...
With a Comp T/A you get a 3 x 1 1/2" Key ring, a custom owners manual that explains the cars birth (mine was made in Canada in the 4th plant), a transmission that is equiped with a rev extender (shift kit) and 6 months of free oil changes
