Old September 21st, 2008, 10:52 PM   #95 (permalink)
ronron112
ronron112's Avatar
Vehicle: 2006 Mitsubishi EclipseGS
Rep Power: 4 ronron112 has a brilliant futureronron112 has a brilliant futureronron112 has a brilliant futureronron112 has a brilliant futureronron112 has a brilliant futureronron112 has a brilliant futureronron112 has a brilliant futureronron112 has a brilliant futureronron112 has a brilliant futureronron112 has a brilliant futureronron112 has a brilliant future
with the FIC you will run into problems such as hiccups at certain rpm levels and even after you tune the car to remove them they can still appear in time, could be 1day or 1 month, also not to mention ur car will always throw a 3 or 4 codes. U have to understand the FIC is a piggyback and it fools the ECU into thinking ur car is running stock. With a standalone you can take over your car and have your car ECU do it thing for certain stuff still lights, radio ect..., but with standalone u get to write your own fuel paths wihout the ECU overriding them and disturbing ur tuning, and wacky rpm levels and erractic hiccup that ur must clean every so often. Its all about the fuel.
TURBO GS - 262 WHP / 255 TORQUE
http://s307.photobucket.com/albums/n...112/?start=all
ronron112 is offline   Reply With Quote
