Old November 3rd, 2008, 05:31 PM   #14 (permalink)
BrianJ
Vehicle: 06 Eclipse GT
Originally Posted by horse-eater View Post
so, to do an entire set, you have to highlight all the cells repeat said process...
but the cells that i want to set the amount for, i just set the amount and omit that cell from the "calculate" function?
??? Um...I'm confused now...
Ok let's say you put 0, 1, 1.7, 2, 3.............5, you would highlight all the cells starting at 3 and ending at 5...in this case there would be 13 cells highlighted, the 3 the 5 and 11 cells in between. Hit calculate and it will evenly populate the other 11 cells between 3 and 5. There's all kinds of right click tricks/tips in the manual for the FIC...it's worth a read...it'll definitely save you some time.
BrianJ is offline   Reply With Quote
