Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority - View Single Post - I have a question Car won't start after transmission work
Thread: I have a question Car won't start after transmission work
Old January 10th, 2017, 07:22 PM   #2 (permalink)
wingo171
wingo171's Avatar
Vehicle: 08 GT SE and 91 3kgt VR4
wingo171 is a jewel in the roughwingo171 is a jewel in the rough
Check the clutch pedal switches in the floor. If the pintle is not moving when you push the clutch pedal it will not crank the motor over as it thinks you didn't push in the clutch. (If the top one is messed up, you can unplug it and it should let you crank (if that is what the issue is down there in the floor).
The burnt wire thing is a WTF did the previous owner do, kind of thing.
Tearstone has the full service manual to download.
Link to FSM
wingo171 is offline   Reply With Quote
