Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority - View Single Post - What did you do for your car today?
Old February 14th, 2017, 05:18 PM   #4611 (permalink)
escapefate
escapefate's Avatar
escapefate will become famous soon enough
So the other rotor was just as bad.
This install was so much easier because I knew exactly what to do and I bought new titanium drill bits, and an extractor bit. So I saved the two screws on the other side and reused one. It worked great.
The car rolls better, the car stops good, has a good "bite" and has no sqweeks or grind noises.
Love IT ! my rear rotors arent damaged like this for some reason.
I do still have an E brake issues. The E brake makes the WORST grinding noise and it works at about 50% capacity. I think the cable is not letting the pads back off like they should. Anyone else have this issue?
Sun and Sound Package.
escapefate is offline   Reply With Quote
