Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority - View Single Post - 06 Eclipse GS will crank but not start. Help!
Old May 4th, 2017, 09:03 PM   #10 (permalink)
BryceA
Vehicle: 2006 Eclipse GS
BryceA is on a distinguished road
Originally Posted by Sabertooth^2 View Post
I don't feel it would be the timing belt. Slipped timing would have very different symptoms
Do you have any codes at all?
Only codes I have were for the oxygen sensors. I had it diagnosed at the Mitsubishi dealership, they ruled it out as the timing belt slipped (timing belt was in rough condition) causing jumped time, and bent some valves. So the bent valves weren't creating compression, I've ordered almost $1200 in parts (re-maned head, timing belt, timing components, balance shaft belt and headgasket). Also, I had Mitsubishi reflash the ECU while my car was there just as a precautionary measure.
BryceA is offline   Reply With Quote
