Poor and Powerful Idle. - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old February 19th, 2017, 09:39 PM   #1 (permalink)
escapefate's Avatar
escapefate will become famous soon enough
Ive noticed that sometimes My car will roll back when on a steep incline at a stop sign, and other times it will hold itself in position at the same stop sign.
I first thought it was temperature related but that doesn't seem to be the case, anyone else with auto tranny notice this?
Sun and Sound Package.
escapefate is offline   Reply With Quote Quick reply to this message
Old February 19th, 2017, 09:57 PM   #2 (permalink)
stayer's Avatar
Vehicle: 2010 Galant9G 4G69MIVEC
stayer is a jewel in the roughstayer is a jewel in the rough
From rolling back, this is a malfunction.
There could be two faults.
1) Low oil pressure.
A) the Wear of the oil pump.
B) the Oil loses its properties.
C) high oil temperature, it becomes too liquid.
2)Wear of clutches in the packs. Clutches become thinner and can't hold the weight of the car.
The first thing I will recommend you. Replace oil. To set the correct oil level.
stayer is offline   Reply With Quote Quick reply to this message
Old February 19th, 2017, 10:15 PM   #3 (permalink)
escapefate's Avatar
wouldnt low oil pressure trigger a CEL
Old February 19th, 2017, 10:48 PM   #4 (permalink)
stayer's Avatar
I can tell when this happens. The engine and transmission are fully warmed up. While the oil in the transmission is cold this effect does not occur. So I wrote to you a possible reason. You need to come to a specialty service on the transmission. There you may measure the pressure in the system. This is done with a pressure gauge (manometer). After that, it will be clear what to do next.
PS So you need to check the operation of the heat exchanger. If there are problems, the oil will be very hot and liquid.
Old February 19th, 2017, 11:05 PM   #5 (permalink)
Wwwyzzrdd's Avatar
Vehicle: 2009 Eclipse GT
Wwwyzzrdd is on a distinguished road
I don't think we have a transmission fluid pressure sensor in our vehicles so you wouldn't get a SES light for that. There *is* a temperature sensor for it, but it doesn't trigger a SES light. That sensor only causes your "shift indicator light" (just the little circle with the gear you're in on your gauge cluster) to flash when the transmission fluid exceeds 115C (238F).
So like Stayer said, it's probably a combination of the oil not being quite warm enough/too warm combined with wear on the clutch packs. Automatic transmissions are very sensitive to small differences like these, after all.
Wwwyzzrdd is offline   Reply With Quote Quick reply to this message
Old February 19th, 2017, 11:40 PM   #6 (permalink)
stayer's Avatar
Auto tranny has no oil pressure switch. To measure pressure it is necessary to unscrew the two screws on 10mm, and connect the pressure gauge. In the service maintenance of the transmission know how to do it.
Old February 20th, 2017, 05:51 PM   #7 (permalink)
escapefate's Avatar
ok so tested it today. Warm start up, drove 1000ft, wouldnt idle up hill. Later on, warm start up, drove same distance, would hold in place just fine.
Noticed the temp gauge was same on both tests. ambient temp difference of about 10 degrees.
Old February 26th, 2017, 12:41 PM   #8 (permalink)
escapefate's Avatar
ok after noticing more and more, its only low power when the car is fully warmed up.
Old April 4th, 2017, 02:22 PM   #9 (permalink)
escapefate's Avatar
Update. no idea what to do. What causes loss of pressure, a leak or ....
Old April 20th, 2017, 01:46 PM   #10 (permalink)
escapefate's Avatar
Do I check ATF with car on hot, off warm, off cold??
auto, back, car, idle, roll, stop, temperature, tranny
