Convertible top operation - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old August 3rd, 2011, 11:14 AM   #1 (permalink)
Vehicle: 1955 Mercury Montclair
Slipangle is on a distinguished road
Hi, in case anyone hadn't seen my introduction, I joined here because I was just poking around the internet looking to see if there was any interesting feedback regarding products with which I have had engineering involvement.
I was involved as an engineer with the 4G convertible top. I may be able to answer some questions, but I'll point out that this was (at this point) activity that is about 5 years in the past and I have changed employers since then, so there is the possibility I might have mistaken recollections, but for anyone with an interest I'm sure I can piece together any gaps.
My responsibilities didn't include vehicle level responsibilities. I understand, as far as that goes, that when you push the raise or lower button that lowering the top starts with the vehicle lowering the windows. That knowledge was peripheral to my area of responsibility, and anything more in-depth might be something I can't help with - for example, I'm not familiar with trouble codes or the meaning of the beeps. I had some knowledge about that, but I've forgotten it.
As for the convertible top itself, I will be able to describe it in detail - my hope is that by describing the system, perhaps the information will be helpful for those needing to resolve issues. I've seen that the most frequent convertible related subject matter seems to be that the convertible top won't close. By understanding how the system works, perhaps I can help in resolving this kind of issue.
In participating in these forums, I'll also point out that I know things about design history and testing issues, these are probably things I'd be bound to not share. The information I will offer will be things that could probably be figured out by anyone with access to parts and a little time to study them.
GENERAL
The Mitsubishi 4th gen Eclipse convertible is a cloth convertible top with a back window bonded to the fabric. The top raises and lowers by way of a hydraulic rotary actuator with 2 hydraulic cylinders for raising and lowering the 5th top bow and 1 hydraulic cylinder for raising and lowering the tonneau cover. The hydraulic system is operated by a single pump run by an electric motor, and with valving which is triggered by electronics which receives signals from certain switches I'll describe later. When the top is closed, it is secured at the 1st top bow to the windshield header by two manually operated mechanical latches.
The convertible top has 5 bows and siderails are in 3 sections. Starting from the rear, the 4 & 5 bows operate from a common pivot at the rear of the rear rail and the 3 bow operates from a fixed (non-pivoting) attachment at the front of the rear rail. The 2-bow has a pivot attachment to the front rail and is constrained somewhat by a cable. The 2nd through 5th bows are all made from aluminum extrusions. The 1st bow bolts to the front of the front rails and is a large aluminum casting (all of the side rails are aluminum castings)
A stamped metal link connects the center rail to a bracket on the hydraulic actuator, setting the mechanical motion of the center rail during top operation. A 3-piece linkage connects the rear rail to the center and front rails to control articulation of the front rail during top operation. The rear rail is driven through a link bolted to it which is operated by a hydraulic motor.
OPERATION SEQUENCE - OPENNING THE TOP
Before operation, the latches at the 1-bow to the windshield header should be open. The 1-bow should raise slightly, and switches in the receivers on the windshield header will detect that the pins on the 1-bow have raised. (There may only be 1 receiver that has a switch, I forget)
1) When the user pushes the open button, first the vehicle body control module lowers the windows.
2) When the windows are lowered, the vehicle sends the signal to the top to begin opening.
3) The hydraulic cylinders are extended to raise the 5-bow. These hydraulic cylinders have switches to signal when they are extended.
4) When the signal is received that the 5-bow is raised, the hydraulic cylinder to open the tonneau cover begins to extend. The flipper doors raise with the tonneau and remain in the down position.
5) When the tonneau hydraulic cylinder's position switches indicate the tonneau is raised, the convertible top will begin to cycle until a position switch on the side of one hydraulic rotary actuator detects that the top is lowered. As the top lowers, a mechanical cable connected to the rear rail drive link will allow the flipper door to raise.
6) This will trigger the hydraulic system to close the tonneau cover. When the tonneau cover is in the closed position, the latch will close.
I don't recall the latch details, I think it was also operated by a hydraulic cylinder, but that was a little peripheral. My company supplied the hydraulic system with the top, and that included all hydraulic cylinders, and we supplied the flipper doors, but we didn't supply the tonneau cover. I think we supplied the tonneau latch, but it wasn't my area of responsibility so my recollection about that component is a little sketchy.
OPERATING SEQUENCE - CLOSING THE TOP
Pretty much the reverse of the above opening procedure.
MANUAL OPERATION
Generally speaking, the easy part is raising and lowering the top. It is the 5-bow and tonneau cover hydraulic cylinders that need the release valve opened. The hydraulic pressure for these cylinders does not require pump pressure to hold position (if there are no system leaks) and the cylinders will not move unless you open the manual operation valve.
My recollection is a little hazy, I remember something about a hex-shaped emergency tool and you use this to operate the tonneau latch and the 5-bow... What I do remember is that operating the 5-bow by pushing on the 5-bow was a good way to bend linkages, resulting in the 5-bow not properly sealing when the top is closed and potentially interfering with the top being able to lower completely when the top is open.
TOP NOT OPERATING
Some things you can check for, armed with the knowledge of how the top works, might make it possible to do a simple repair without having to go to a dealership. Here are things which might cause the top to not operate:
1) A hydraulic leak or the manual operation valve may cause the top to raise partially or raise slowly. Either way, the pump will operate for some time and when the expected switch isn't activated when the computer expects to see it, a fault code will be set.
2) Another thing that could happen is that once the tonneau or 5-bow is raised, a loss of hydraulic pressure might cause either or both to start dropping back down. I think this might be detected when a switch changes state, which can either interrupt operation or cause the system to change cycles. If this is happening, watch out for parts crashing into each other.
3) If the system reaches a certain point, and it keeps pumping (like say for example the 5-bow raises but the top doesn't start lowering) it might indicate that a position sensor/switch is not working. Check for broken wires or in the case of the top up/down switch on the side of the hydraulic motor, maybe the bracket is bent and the switch isn't contacting properly. You might be able to fix broken wires or bent brackets on your own. Otherwise it might be a bad switch which would require a replacement part.
4) Receiver switches sticking in the 1-bow (or forgetting to unlatch) can keep the system from cycling.
5) If the windows don't lower it can keep the system from cycling
6) The trunk being open will stop the tonneau from opening (IIRC)
Maybe I'll leave it at that for now, if there's any questions I can answer or corrections I should make I'd be glad to hear it!
Slipangle is offline   Reply With Quote Quick reply to this message
Old August 3rd, 2011, 12:01 PM   #2 (permalink)
The Postwhore's Postwhore
AiRmAn2281's Avatar
10 Highscores
Tournaments Won: 17
Vehicle: 2008/GT/Spyder
AiRmAn2281 has a brilliant futureAiRmAn2281 has a brilliant futureAiRmAn2281 has a brilliant futureAiRmAn2281 has a brilliant futureAiRmAn2281 has a brilliant futureAiRmAn2281 has a brilliant futureAiRmAn2281 has a brilliant futureAiRmAn2281 has a brilliant futureAiRmAn2281 has a brilliant futureAiRmAn2281 has a brilliant futureAiRmAn2281 has a brilliant future
My top opens fine, but when I press the close button, the hatch area opens and the cloth cover raises about an inch then stops. The pump is running the whole time. I have to hold the close button and reach back there to "help" the top up till about half way, then it will close. Any suggestions?
AiRmAn2281 is offline   Reply With Quote Quick reply to this message
Old August 4th, 2011, 08:03 AM   #3 (permalink)
The first thing I would check would be the fluid level in the hydraulic system reservoir.
Basicly, once the top is past the half way point, it can pretty much fall through the rest of the way without any hydraulic assistance at all.
The hydraulic rotary actuator that drives the convertible top is actually a hydraulic piston which drives a set of gear teeth on the shaft, and these teeth drive a gear that provides the rotating input to the rear rail. So if there wasn't enough fluid in the system to fill the piston, it might not be able to complete a cycle.
This can also happen if the manual operation valve is not fully tightenned. My recollection of the torque spec is that as tight as normal people can get it by hand is under spec. If you can easily turn it by hand, you can probably get air through the screw and the system won't get enough hydraulic pressure to raise the top.
Other than that, there are possibilities that there could be something bent or worn, in which case there should be other problems such as gaps between the rear of the top and the tonneau panel when the top is closed or wrinkles from loose fabric.
It is also possible, if the fluid level is good and the manual release valve is tight, that a seal in the hydraulic system might be leaking internally. For a 2008, if it's still in warranty, this would definitely be something that should be fixed under warranty by the dealer. If this is the repair that is needed, it involves removing the top assembly - which is a 2-person job. I've done it, there are worse things to have to do on a car, but it involves unbolting things from the rear rail - which is aluminum, always the possibility of losing threads - so if the dealer does that, then they'd be responsible for replacing those parts too.
Old August 13th, 2011, 08:41 AM   #4 (permalink)
Vehicle: 2007 Eclipse Spyder GT
acmcleod is on a distinguished road
1st bow switches / sensors...
About those sensors, I think my problem stems from them.
Top closes and thumps into the closed position like it always has. BUt window switches won't send the windows up. Fiddle a bit with things (open / close both top latches several times, etc.) and I can get the windows to go up.
Top's open & close buttons now won't work (yes, I unlatched the top!) the audible tone just beeeeeps and the top won't go down.
I let it sit overnight and the next morning the top goes down just fine. Comes up and does the same thing again...
Its August now, as I recall it acted this way ONE day, the first day I took it out this spring. I've used it every day thru the summer with no interceeding problems!
As you said, you're not sure there are sensors in both or one latch.... when I latch / unlatch the driver side latch there's a beep. When I do the same with the passenger side there's no beep. I don't recall if that's normal. Maybe someone whose top works can confirm??
Seems like a sensor issue to me.
Trying to figure out if this is a dealer repair or a do-it-yourself one.
Any help appreciated!!
Thanks!!
Alex
acmcleod is offline   Reply With Quote Quick reply to this message
Old August 15th, 2011, 11:46 PM   #5 (permalink)
deprydation's Avatar
Vehicle: 2012 Lancer Ralliart
deprydation is a splendid one to beholddeprydation is a splendid one to beholddeprydation is a splendid one to beholddeprydation is a splendid one to beholddeprydation is a splendid one to beholddeprydation is a splendid one to behold
Thanks!!
Alex
When you close the top, the windows going back up are not part of the cycle. It only makes sure the windows are down to prevent any catching of weather seal on the windows. Same reason that when you halfway open the door latch (inside or outside) the window creeps down about a 1/4 of an inch. This is to save your weather seal and top from catching, ripping, stretching, tearing on the window or door.
Now, I have an issue with my convertible system. I don't know what it is, but when I first cold start the car and attempt to lower the top, the first stage happens fine with the 5 bow lifting, but as soon as the tonneau cover begins to lift, my engine RPM begins to drop, when it fully raises and the top begins to come back my engine will sometimes die. It's almost as if the hydraulics in the top is drawing power from my engine for some reason. As you say it's an electrical hydraulic pump, but why would it cause my engine to die?
Current Car: 2012 Mitsubishi Lancer Ralliart: Evo X FMIC | MAP UICP | Evo X LICP| Evo X BPV | AEM Intake | AMS Boost Pill | GST Basemap Tuned by ME! | RRM GRIP Springs | Oil Catch Can | Agency Power 3" DP | Avid1 18x9 +35 | Project Kics R28 Lugs | AMS 3" Resonated TP | Ultimate Racing 3" Dual-Tip Catback | Zeitronix ZT-2/ZR-2 AFR+Boost |
deprydation is offline   Reply With Quote Quick reply to this message
Old September 15th, 2011, 10:43 AM   #6 (permalink)
Vehicle: 2008 Eclipse Spyder
Kendogg is an unknown quantity at this point
Mine did the same. I even have it on video. This issue started at the 10,000 mile mark. What a product Mitsubishi offers. I took it to the dealership. They "fixed" the problem. They said some J-plug connector was disconected. So basically check around for some wires that came un-plugged I guess.
I had to also have my top completely replaced. The inliner came un-stitched and started falling down. The outer top started to get two perfectly symetrical holes at the back window. Mitsu replaced the top.
Now the back convertible cover doesn't want to lift when you go to put the top down. These cars are piece of shits. I am the original owner and have paid off my car. I would trade in the piece of shit so I dont have to deal with this anymore. Only problem being, the cars aint worth squat. Guess Im just stuck with this mistake of my life
Kendogg is offline   Reply With Quote Quick reply to this message
Old January 19th, 2012, 10:44 AM   #7 (permalink)
Vehicle: 2007 Eclipse Spyder conv.
terzport is on a distinguished road
GENERAL
MANUAL OPERATION
TOP NOT OPERATING
I have a 07 eclipse convertible. The tonneaue goes up the top goes down but the tonneau will not go back down to finish the top down process.
Any thoughts as to what might be wrong?
Thanks a bunch!
terzport is offline   Reply With Quote Quick reply to this message
Old January 19th, 2012, 10:49 AM   #8 (permalink)
Hi I have an 07 eclipse convertible. When putting the top down the tonneau goes up the top goes down but the tonneau will not go down from this point it stays in the up position..
Any ideas as to what might be wrong?
Thanks a bunch!
Old January 19th, 2012, 03:17 PM   #9 (permalink)
North 4G Korea dissident
xxxxxxpat_08GT_Spyder's Avatar
xxxxxxpat_08GT_Spyder is a name known to allxxxxxxpat_08GT_Spyder is a name known to allxxxxxxpat_08GT_Spyder is a name known to allxxxxxxpat_08GT_Spyder is a name known to allxxxxxxpat_08GT_Spyder is a name known to allxxxxxxpat_08GT_Spyder is a name known to all
something with the hydraulic pump / valves that control the tonneau? never had that happen to me...
xxxxxxpat_08GT_Spyder is offline   Reply With Quote Quick reply to this message
Old January 23rd, 2012, 05:39 AM   #10 (permalink)
There is a switch on the side of the rotary actuator - which will look like an aluminum block where the top pivots. It's on one side only, if I remember correctly it's on the passenger side. When the top is lowered, an arm on the top mechanism hits the switch sending a signal that the top is down and it's clear to start lowering the tonneau cover. Assuming there isn't anything binding in the top that prevents it from being lowered, the switch is the likely issue. Look for the plug to be disconnected, or a wire broken, or see if the switch bracket might be bent such that the top mechanism isn't activating the switch.
It will be on the inboard side of the actuator.
Old January 23rd, 2012, 09:47 AM   #11 (permalink)
thanks for the info man, hopefully buddy tries that and let us know. i appreciate your input on the top, i'm sure it will come in handy at times !!
Old March 4th, 2012, 06:21 PM   #12 (permalink)
Vehicle: 2007/Eclipse/GS
aprincss24 is on a distinguished road
My top opened up fine. Then when I went to close it, it would not close. You could see the top trying to push open the tonneau cover, but it would not open and the top never came out of the well. The beeper just beeped three times loudly at me and thats all it will do. I had to manually pull it out and put it back on. I took it to the dealership and after 3 days and after a new computer and sensor they came to the conclusion it was the hydraulic assyfolding (part #6559A001) which they priced at $2745 with $650 in labor. RIDICULOUS!!! I think they have just run out of things to tell me and just came up with this. Is there anyone who has had this problem and what did you do. Has anyone had to replace this part on their SPyder??? Is this not the same thing as the motor or what is this part anyway??!! Please HELP!!
aprincss24 is offline   Reply With Quote Quick reply to this message
Old March 20th, 2012, 08:51 PM   #13 (permalink)
Vehicle: 2007 Spyder GS
Red955i is on a distinguished road
I am noticing two 1/4' tears forming at the very front of the top running parallel to the windshield probably about were the latches are on the inside. They are not completely through yet but as the are symmetrical I am wondering what is causing them? It doesn't look like anything in well would contact those spots. Any ideas??
2007 Eclipse Spyder....
Red955i is offline   Reply With Quote Quick reply to this message
Old March 20th, 2012, 09:18 PM   #14 (permalink)
Megawatt's Avatar
Vehicle: 2008/Spyder/GS
Megawatt is on a distinguished road
Here is a TSB about top wear on 2007-2009 Spyder: http://65.39.230.227/common/SiteMedi...09-42A-013.pdf
No Chrome, The Only known 4G Spyder with a Power Antenna
Megawatt is offline   Reply With Quote Quick reply to this message
Old March 20th, 2012, 09:19 PM   #15 (permalink)
Megawatt's Avatar
Welcome
Old March 26th, 2012, 07:43 AM   #16 (permalink)
For whatever reason I didn't get or notice an e-mail about new replies on this thread until the more recent responses.
At any rate I'm assuming that the car must be out of warranty. You're describing a condition that sounds like there has been a hydraulic leak.
If you're interested, although odds are I'd guess you're more interested in getting the car to work, I'd be able to explain some of the factors in the price being as much as it is...
If you're mechanically capable, the first thing you'd need to know is where the leak actually is and the dealer might have found that, or they might have just had to replace the hydraulic system complete - for the price it sounds more like a complete hydraulic system replace I think.
You may be able to find components through vehicle recyclers (junk yards) or e-bay. When I did a quick search I found a convertible top hydraulic pump used on e-bay for $130, for example. This part of the system would be relatively simple to replace. On the other hand, if the leak is from the hydraulic motors on each side, the convertible top would need to be removed to replace them. Replacing components of the sytem can cause a risk of trapping air bubbles, and if you have a good manual I'd expect that to be adressed... it's been a while, if I remember you just run the pump or cycle the top to get air bubbles out, but I can't remember for certain.
I'll watch for replies if you can provide more detail or want any suggestions. If you decide to just live with openning and closing the top manually, make sure to use the hex wrench tool for closing down the 5-bow at the rear.
Old March 26th, 2012, 07:56 AM   #17 (permalink)
Just as an fyi to anyone that wanted to look into this for DIY, if you didn't already have a bolt there, make sure to use a hex head bolt and not a socket head cap screw (i.e. use one as shown in the TSB pictures). We tried a socket head cap screw first because it would've cleared easier, but with less contact area it wore metal away on the center rail.
Old March 29th, 2013, 02:33 PM   #18 (permalink)
Vehicle: 2008 Eclipse Spyder GS
salilsurendran is on a distinguished road
I have the exact same problem as acmcleod has except that my top won't open even after letting it sit overnight. I took it to the mechanic and the code read B1301 which means a '5 bow sensor' malfunction. I have detailed my troubles in this post Mitsubishi Eclipse Spyder top not opening . Could someone please help me with this issue.
salilsurendran is offline   Reply With Quote Quick reply to this message
Old September 22nd, 2014, 06:15 PM   #19 (permalink)
Vehicle: 2008 Spyder Black
rxman46321 is on a distinguished road
Sensor light show top open when fully closed and locked
Where are the sensors that work the to open light on the console.
My top is closed and locked but the warning stays lit and the buzzer beeps when you start from a stop and then goes silent.
John Griffin
rxman46321 is offline   Reply With Quote Quick reply to this message
Old September 29th, 2014, 08:50 AM   #20 (permalink)
John Griffin
There is a switch in one of the two receivers in the windshield header that should sense the presence of the pin in the 1 bow. There was actually originally 2 switches in the design, and the error would be triggered if both were not sensing the pin, so depending on when it was made you might have one or both.
Old July 20th, 2015, 07:26 PM   #21 (permalink)
Vehicle: 2008 Mits Eclipse Spyder
Sherry is on a distinguished road
Flipper Door Mechanism
Does anyone know if the flipper door is strickly mechanically operated with a cable, or are there hydraulics involved?
I am speaking about the one with a piece of flat plastic molding attatched, but the door is
only visable when the top is in down position. Parts of the actual flipper broke off & i am hoping that replacing it will just involve nuts & bolts.........
I love my spyder !!
Sherry is offline   Reply With Quote Quick reply to this message
Old July 21st, 2015, 06:29 AM   #22 (permalink)
Sorry, I have a hard top... So I did a search for you and can only hope this information will help, or maybe someone with a top will chime-in that can answer your question. I believe this area is manically, Some years ago, we had a member who got a child seat belt caught in this area and had to remove said part to get the belt out.
http://club4g.org/board/gtsearch.php...%3D5339113&ss=
Old July 21st, 2015, 07:28 AM   #23 (permalink)
Thx Clovisman
Old July 21st, 2015, 07:36 AM   #24 (permalink)
Terzport,
Do u know if the flipper door is strickly mechanically operated with a cable, or are there hydraulics involved?
Thx, Sherry
Old July 21st, 2015, 08:24 AM   #25 (permalink)
Like I said I'm pretty sure this is mechanical, but I do have a hard top and I'm going by memory.
I hope a spider member chimes-in, there seems to be a big mystery about the convertible and problem resolves for said top. Seems people do have problems with their tops, but fail to post their fixes.
It may take another day, or two for some spider members to join in on this conversation. I/We don't have a manual for the operation of the convertible top, I wish we did. We have a Eclipse Factory Service Manual that covers everything on our Eclipse, but the only thing not in that manual is the convertible top!!
Old July 27th, 2015, 05:56 AM   #26 (permalink)
It's mechanically operated. One end of the cable attaches to the flipper door, the other is attached to the linkage near the rotary hydraulic actuator that raises and lowers the top.
I'm an engineer from the company that supplied the top to Mitsubishi. Any questions, I'll see them in this thread since I am subscribed to it.
Old July 27th, 2015, 10:30 AM   #27 (permalink)
Thx Slipangle & Clovisman
Thx so much, my neighbor said if i bought the part he could put it on, if it is strickly mechanical i am willing to try, as i can visually see that there is a kink in the cable that controls the flipper door.
So glad i found Club4g!
Old September 16th, 2015, 10:20 AM   #28 (permalink)
Vehicle: 2008/eclipse/spyder
reaper527 is on a distinguished road
dumb question, but does anyone have a picture of where the 2 release points for the 5th bow are?
my top doesn't want to go down, and googling around it sounds exactly like the 5th bow sensor problem that seems to be pretty common, and one of the pages i came across talked about how to manually open the top and check for a bad splice on the wiring.
justanswer.com/mitsubishi/7nw1g-mitsubishi-eclipse-spyder-gs-hello-friendsi-problem.html
the page had a ton of pictures of everything EXCEPT where the actual release points were. i found the hidden tool behind the sub just fine, and the release point above the sub for the tonneau, but am not seeing anything that the tool fits into for the other 2 release points.
if it makes any difference, my eclipse is a 2008.
---edit---
just an update, i did manage to find those release points and get the top down. i'll take some pictures later so other people have an idea of where they are.
as to the problem i was having, here is where it stands:
1. as i was manually opening the top, i wasn't able to get the tonneau to lift open, however after the 5th bow was up, my top open button magically started working!
2. i let it open to the point where i could get at the wiring for the sensors. i unplugged the one on the passenger side, unraveled the connector some and started cutting back the plastic shielding. i went pretty far, but wasn't able to find the splice before it got dark. how far away from the silver cylinder is the splice point? i'm at a point where it's getting difficult to work on the wire because it's getting pretty crowded, but i haven't reached the two zip ties yet. up to this point, both wires in the connector have been solid, and i haven't seen any splices.
3. when i decided to call it a night due to the darkness (thanks end of summer ), i used the close top button and everything worked perfectly, aside from the fact i ran into the same issue that caused the whole problem to begin with. my windows wouldn't close after the top went up, turning off the car and turning it back on fixed my windows, but now the top doesn't want to open. (i'm expecting that if i try manually again, i'll experience the same thing)
anything specific i should keep my eyes open for next time i open it up and try to find that splice point?
---2nd edit----
problem solved. found the splice, it was popped. soldered back together and the top works like new.
reaper527 is offline   Reply With Quote Quick reply to this message
Old September 17th, 2015, 05:25 AM   #29 (permalink)
On the hard top and I'm sure the convertible there is what we call a short-stroke reset. With the top all the way up and locked, roll one window down at a time, hold the down button until you hear a click (10 Seconds). Release the down window button. Now roll the window up holding it in the up position until you hear a click (10 Seconds). That window is now reset. Do this with all four windows. With all four windows reset, this should reset the ECU for your top and also help with the lowering and raising of the top.
Old November 17th, 2015, 11:26 AM   #30 (permalink)
Vehicle: 2007/Eclipse/Spyder
scapece is on a distinguished road
Slipangle,
My daughter's 2007 Spyder had one of the flipper doors break off, while closing the top, because it didn't close as fast as the other one. Is there a way to adjust the timing of the flipper doors?
Thanks
scapece is offline   Reply With Quote Quick reply to this message
Old November 18th, 2015, 05:23 AM   #31 (permalink)
Originally Posted by scapece View Post
Slipangle,
Thanks
Yes, when you replace the door you should be able to see how to make adjustments.
Old December 9th, 2015, 03:00 PM   #32 (permalink)
michael61341's Avatar
Vehicle: 2007 Spyder GT
michael61341 is on a distinguished road
07 Spyder here, I saw an earlier post where the tannau cover opened, rag top opened and went in the compartment, then top wouldn't close. I had that problem today, so I carefully forced the tannau cover closed. Now the top light flashes and beeps and nothing works.
Any help would be appreciated as the top is down, I have no garage, it I'm sure it'll snow soon because of this.
OK, the owner's manual is a wonderful thing, I got it closed but now the emergency pressure release is open and I'm guessing it won't operate like that. The cover closes first and covers the valve, how do I close it now?
Michael
"If you think I'm crazy let me set you straight, I am, so quit thinking and know it already."
michael61341 is offline   Reply With Quote Quick reply to this message
Old December 11th, 2015, 03:48 PM   #33 (permalink)
Hensen is on a distinguished road
Awesome man! How was the pay as an engineer?
Hensen is offline   Reply With Quote Quick reply to this message
Old December 14th, 2015, 03:15 AM   #34 (permalink)
I believe the switch is located under the base speaker, there is a panel you have to pull to get to it.
Old December 14th, 2015, 09:05 PM   #35 (permalink)
After a couple of trys, I got the tannau cover open and the window open to 90' where it froze the first time, closed the valve and got the top closed with the inside button. Opened and closed it again, it worked fine. It's closed and there're it'll stay until spring.
Old December 15th, 2015, 03:52 PM   #36 (permalink)
Do Not open till Spring, LOL!!
Can you do us a favor and take a couple pictures for us, like how to access the panel, and where the valve is located. There is no information in the Eclipse Factor Service Manual, and very little information to give Spyder owners when they have a problem. For us hard top guys it really doesn't matter, but then again we would like to be able to help when there is a problem, and no Spyder Man around... LOL!!!
Thanks
John
Old December 15th, 2015, 07:28 PM   #37 (permalink)
Actually the manual is pretty clear on page 3-49 thru 3-59 on how to operate the top manually.
I don't think the manual is Spyder specific, mine says 2007 Eclipse & Eclipse Spyder. I'd be glad to write something up, but it would take some time.
Do me a favor and check your manual and see if there is a "Convertible Top" section in the index.
Basically behind the woffer cover and above the speaker is a large allen wrench (emergency tool), above the speaker is a hex nut that slides the lock mechanism about 3 inches side to side to lock and unlock the tonneau cover.
Open the cover and slide the tool into the hinge to keep it up. The top will pull up and down by hand, at the bottom of the space where the top is stowed is a 4" square cover that reads "Only open for manual or emergency top operation" or something close to that. Under that cover is a small "T" handle that turns to open and close the valve that releases the pressure to let the back window open and close. The window is heavy, so if you're releasing the pressure to close the window, hold it with one hand so it doesn't drop on your arm.
When closing the top, either manually or automatically, the tonneau cover closes first then the rear window closes over the top of the cover.
There's more specific info about removing straps and using the tool to force the 4-5 rib open and closed.
Let me know if you need more info.
Michael
Old December 15th, 2015, 08:28 PM   #38 (permalink)
Vehicle: 2007 mitsubshi spyder
aaglendenning is on a distinguished road
2007 mits spyder top won't close all the way... PLEASE
long story short I was sold a car with a bad sensor on the converable top (always beeping saying it wasn't up all the way when it was), they failed to fix it or return any of my phone calls and 2 weeks ago I was driving it on the highway and the top flew open, and now the shop is wanting to call it in at a totalled vehicle since I got the car for 10 grand and the converable is 11 grand and "it needs a new top" and no shop knows what the actual problem is. they took it to 3 'mits dealerships and it all comes back "unknown" why it won't work or what the problem is ?!? the top will go down but won't go up and latch correctly. the 5 bar where the glass is doesn't lay flush it has like a 2 inch opening !? I don't want it to be called into the insurance when it isn't my fault. I didn't do anything. I just want my
car fixed 😫😫😫😫
aaglendenning is offline   Reply With Quote Quick reply to this message
Old December 15th, 2015, 08:42 PM   #39 (permalink)
if the dealer can't fix it, I doubt we can help much here without seeing it.
Good luck though.
Michael
Old March 16th, 2016, 08:30 PM   #40 (permalink)
BVigilante is on a distinguished road
Flipper door
I love my spyder !!
I am pretty sure it's operated by a cable. I need to get 2 of the smaller flaps towards the inside of the car. They are missing and I just saw them in a video. Now I just have a hole in it's place.
BVigilante is offline   Reply With Quote Quick reply to this message
4th gen, body, bolts, broken, button, detail, drive, eclipse, electronics, good, header, loss, lower, lowered, lowering, mitsubishi, move, offer, parts, questions, rear, starting, system, top, works
