Has anyone actually installed an O2 spacer on that rear bank 1 sensor for P0421 code? - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old May 20th, 2014, 09:27 PM   #1 (permalink)
cllamont's Avatar
Vehicle: 2006 Eclipse GT - factory
cllamont is on a distinguished road
I have a factory 06 GT and I just want to try to get past emissions. THe P0421 is popping every day and a half know. I have been driving with it for almost 2 years with no visible performance issues. Tried the disconnect of the battery cable to clear the code but it is not going to stay off long enough to allow the monitors to reset - I was turned away from inspection because I did this right before I took it in for the scan.
I want to try the spacer trick but I cant reach that sensor - which was replaced by the dealer about 3 - 4 years ago. I dont have the capacity to be drilling spark plug non-foulers. I thought I would try to get some actually spacers and install myself. Just seems to be a tough job for a novice and I havent seen anyone actually do it - just talk about it.
cllamont is offline   Reply With Quote Quick reply to this message
Old May 20th, 2014, 11:19 PM   #2 (permalink)
Vehicle: 2006 Lancer Ralliart
CrAnSwIcK is a jewel in the roughCrAnSwIcK is a jewel in the rough
if you need to pass an emissions test, spacers are probably not permitted maybe illegal. you'll need to replace the sensor... it could be the catalytic converter...what do your spark plugs look like?
CrAnSwIcK is offline   Reply With Quote Quick reply to this message
Old May 21st, 2014, 10:20 AM   #3 (permalink)
Silver Behemoth
Vehicle: 2007 Eclipse GT Spyder
Masyn is on a distinguished road
I did. It worked for a while, passed for an inspection but is now throwing p0420. Haha
Masyn is offline   Reply With Quote Quick reply to this message
Old May 21st, 2014, 10:25 AM   #4 (permalink)
cllamont's Avatar
Can you tell me how you did it? I dont know how to reach that sensor to remove it. I also dont know where to find a factory made spacer.
Old May 21st, 2014, 10:30 AM   #5 (permalink)
cllamont's Avatar
I had new plugs installed last year - or at least that is what I am told. I really cant know since I cant access them. THe sensor - the hardest one to reach way down there after the cat on the back of the engine - was replaced by the dealer about 4 years ago. The rest are original with 110K miles. I want to believe it may just be a sensor since the car has run well with the P0421 code popping up every 2 days (sometimes I clear it) for 2 years. I do notice a rattling sound when on a cold start that goes away after a few seconds - I think that is the cat.
Should I risk trying to replace the O2 sensor to see if that makes it any better?
Old May 21st, 2014, 01:09 PM   #6 (permalink)
yeah, and why can't you access the spark plugs? I've never worked on the 3.8, so I don't know.
Old May 21st, 2014, 03:46 PM   #7 (permalink)
cllamont's Avatar
3 plugs are underneath and require some serious work (serious for my level of expertise) to reach.
Spark Plug Replacement on 2006-2012 4th Generation Mitsubishi Eclipse GT - YouTube
Old May 21st, 2014, 04:35 PM   #8 (permalink)
Silver Behemoth
You need a 02 sensor socket and a half inch ratchet. The spark plug nonfouler you get from oreilly, i cant remember what its called though. Ill put a picture of it up though. Take a half inch drill bit and drill through the holein the nonfouler and install. Put some antiseize on it too so it wont forever be attached to your sensor.
Old May 21st, 2014, 06:25 PM   #9 (permalink)
cllamont's Avatar
THanks - that part I understand. It is getting to that rear downstream sensor that I can not figure out. It is way down there and it doesnt seem like a long bar with the socket would be possible. I heard someone mention taking the front passenger wheel off to access it but I dont know about that either.
So did this spacer work to eliminate your P0421 - even temporarily? I have to pass emissions and I cant afford a real mechanic or a new car.
Old May 21st, 2014, 06:36 PM   #10 (permalink)
cllamont's Avatar
HOw many Cats and sensors in the GT?
I am thinking 2 cats and 4 sensors. Is there a third cat somewhere?
Old June 8th, 2014, 10:33 PM   #11 (permalink)
Silver Behemoth
I just took a half inch ratchet with the 02 sensor socket from the top. You might press your hand on the fan a little but its possible
Old June 8th, 2014, 10:35 PM   #12 (permalink)
Silver Behemoth
There is more than 2 cats but only 2 cats are read. Bank 2 would suck to get to. If i get a chance, ill take a picture or two wednesday when i redo mine. My inspection is out but now im reading the opposite xD
Old June 9th, 2014, 04:55 PM   #13 (permalink)
The 2006 is famous for burning out the rear pre-cat. Someone put a post on here were Mitsu has extended the warrenty for our cats. I think he said it's 120,000 miles or ten-years. So talk to a Mitsu Dealership and have them replace the cat and reflash the ECU so it will stop burning out cats.
Catalatic Converter Warranty Extended
Old June 9th, 2014, 10:54 PM   #14 (permalink)
cllamont's Avatar
Unless this happened in the last few weeks, this extension is only for cars purchased in certain states since emission laws vary from state to state. This is what Mitsubishi told me 2 months ago when I called HQ to complain about the fact that I could not get the repair while other owners could.
Old June 10th, 2014, 09:20 PM   #15 (permalink)
I didn't figure that in, well it's worth trying at least.
Old October 27th, 2014, 04:00 AM   #16 (permalink)
luk76's Avatar
Vehicle: 2007/4G/4G69
luk76 is on a distinguished road
this spacers will solve cat code problem:
luk76 is offline   Reply With Quote Quick reply to this message
Old October 29th, 2014, 09:02 PM   #17 (permalink)
ModgePodge is on a distinguished road
The extension is technically for cars that are registered in certain states, but it doesn't hurt to ask.
ModgePodge is offline   Reply With Quote Quick reply to this message
06 gt, battery, clear, code, day, drilling, factory, install, issues, long, performance, rear, reset, sensor, spacer, spacers, spark, spark plug
Where are the bank 2 o2 sensors? Code P0431 BAnthony 2006-2012 Eclipse (General 4G) 18 March 21st, 2014 09:54 AM
Is this Bank 2 Sensor 1? pridesi Problem Reports 1 September 5th, 2013 05:49 PM
Check Engine Light code P0421, 02 SENSOR? BAnthony Problem Reports 6 December 9th, 2012 10:16 AM
P0421 engine code mayday295 4G Eclipse GT/SE Specific 6 October 25th, 2011 12:32 AM
P0421 OBD-II Trouble Code macwest 4G Eclipse GT/SE Specific 3 January 24th, 2010 02:10 PM
