Old April 21st, 2009, 07:02 PM   #8 (permalink)
DarkSidEclipse
Did u see GT on the back?
DarkSidEclipse's Avatar
Vehicle: 2006 Eclipse GS W26
Never seen anything like that with a DSM ECU older cars will shut off if the oil level is to low but not because of the ecu. It will shut down due to mechanical reason's like oil pressure, oil pump stuff like that. If the timing chain or drive belt is broke yes it will act like it wants to start but won't start. You would here like a clicking noise when you turn it. Then again if she was driving with no oil it could be the oil pump. Lesson number 1 if someone isn't going to take of your car then don't let them drive your car.
"Owning a 9 second neon is like comming out of the closet. At first you suprise everyone, but in the end your still gay."
DarkSidEclipse is offline   Reply With Quote
