Originally Posted by Trevorcjones
One thing I believe someone told me about a year ago when my car did that for a few days was the Brake fluid was too high. That or it was really close and when you drove the car hard it would trip a sensor or something in the reservoir.
Originally Posted by dc5jimbo
could also be your car thinks its loosing traction . it happens alot with cars with a safe traction program .
also reset your ecu . as odd and crazy it sounds your ecu controls that ..
Originally Posted by ALBOE
Something similar happened to me.. now I'm not sure if it'll be the same thing, but I would drive my car for about 5 minutes, and then the traction control and the swerving car came on at the same time. Then I would have to kill the engine, and start it again for it to go away for another 5-10 minutes.
I checked all my fuses because also my AC lights weren't comming on either, and I came to find out that my passenger brake light, and the front signal light (passenger side as well) wasn't turning on due to a faulty ground connection, and a blown fuse.
check your fuse box since we have the sws on our cars and also all your brake/signal lights. Hope this helps
Thank you gentlemen. I'm not sure which one of you is right...I sorta did all three and it turned it off. Been 3 days now without it. Thank you!
Currently Working On: Buying a House, Wedding Planning, Trying to Find a Cheap Carbon Fiber Hood, Looking Into Shift Lights
