Old August 23rd, 2009, 10:40 PM   #15 (permalink)
Ralliart_on_lsd
Vehicle: 2004 Mitsu Ralliart Turbo
Ralliart_on_lsd has a spectacular aura about
no problem... Just a question about the evo fuel injector theory.
It says you can use the evo 8/9 injectors if you use the AMS fuel rail. does that mean that any evo 8 injector can fit and is plug n play, as long as you have the ams fuel rail?
I can get a set of 750 RC engineering evo 8 injectors. Or i can get the 565 STI top fed injectors (USDM but top fed. still fit right?). not sure which would be easier setup to use. what do you think?
Ralliart_on_lsd is offline   Reply With Quote
