Yes they fit.. although the Deatschwerks 560cc are closer to OEM than the Deatschwerks Cobb Spec 565CC Injectors.. so therefore if you choose to go Deatschwerks I recommeng getting the 560's.
The 565's have some slight coil parameter and flow parameter changes to optimize these injectors specifically to the Cobb Accessport map for tuned Subaru's. So I do not know how those changes will affect tunability on the Eclipse/Lancer Ralliart. But as for fitment.. it should be the same.
Although I would recommend going for something like these:
Subaru Impreza WRX STI pink fuel injectors 565cc:eBay Motors (item 300344507303 end time Sep-06-09 06:09:19 PDT)
As they already have been fully confirmed on our platform.
Soon to be installed: T3/T4 50 Trim Hybrid Turbo, Full Tubular Manifold, Forge Blow-Off Valve, 38mm Tial Wastegate with 10psi spring, 1,100 cfm Intercooler, 440cc Subaru WRX Injectors, Greddy Profec B II Boost Controller, Intake/Intercooler/Exhaust Piping, AEM FIC, GT Throttle Body, Outlaw Engineering Throttle Body Spacer, Oil Catch Can, PLX M-300 Tuner Edition Wideband, RRE Underdrive Pulley, RRE Magnaflow Exhaust.
