Originally Posted by BrianJ
Got any high res pics of the connectors that plug into the ECU? That would tell me the most about whether or not I can do a PnP.
As for the MAF sensor...is it the same sensor as the 4G? If so, then yes, I can interface it. If it's a frequency based sensor (karman vortex) then you'll need the FIC8 as it's the only one with karman based compatibility...
Do you happen to have the part number for your MAF? I can take the pics, but I need a day or 2 to do so...
