Well, if you don't mind that then I could make a real nice flying lead harness for you, completely labeled, with the MAF circuit built in...you'll just have to buy the FIC and send me the pigtail harness that comes with it...I'll attach that to your harness and you'll be good to go. I'll just need some dimensions from you, like where the ecu is and where the FIC will be inside the car, etc.etc.
