At what point would one want to bump up the timing of an all motor car? I'm assuming after you've acheived a stable 11.7 to 12 AFR at WOT and you're happy with the fueling??
My plan once I get everything running is to get the AFR where I want it first, then add timing. Is this the right approach??
Mods:
