do you still have pressure in the tank? sounds like it may have all run out on you during that year....otherwise, check lines, trigger electronics, etc.
It's only a 50 shot, I didn't want to over do it. The "kick" was never really too noticeable as it was. Does this sound about right to others using a 50? It's a professionally installed Edelbrock system.
What I mean by that it when I turn the knob on I can hear the sound of the pressure pressurizing the line. Like when you screw a CO2 tank onto
a paintball gun for the 1st time (if that helps).
Just get the bottle filled then you'll know for sure you have nitrous in there and no just leftover air..And when you purge do you get a white cloud ?? If not your on empty...
yes its dense and white. Thanks for all your responses, clearly the nitrous is working correctly. Probably user error. Thanks
Related Threads
Mitsubishi Eclipse 4G Forums
928K posts
23.8K members
Since 2007
