Spark Plug Replacement - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old July 27th, 2010, 01:47 PM   #1 (permalink)
Vehicle: 2006 GS
AED55 is on a distinguished road
I want to replace the plugs on my 2.4L, but can't find any instructions on how to do it. I searched the forum and found a guide in the maintenance section for the V6, but nothing for the 4 cyl.
In the 4G technical manual under "spark plug replace", all it shows is a diagram of a plug, with gap settings. There is nothing about how to remove the plug to check the gap.
I sure hope it's not as difficult as the V6 because that looks like a real pain in the ass.
AED55 is offline   Reply With Quote Quick reply to this message
Old July 27th, 2010, 02:06 PM   #2 (permalink)
Vehicle: 08 Eclipse GT-SC
can't remember if they have the same 'boot' on there but I bet they do...can you see where your spark-plugs are? mmmmmm.....I'd need to see a pic, hold on....yes, they have that same ignition coil boot, looks to be under the engine cover. there is a pic of them on page 11A-11 of the service manual
so - take that cover off, then unscrew the bolts holding the 'boot' to the motor. once the bolts are removed you can wiggle the boot loose and pull it out. down in the exposed hole is the plug - you'll need a long ratchet and a 'spark plug removal' socket - 14 mm I believe but someone w/ a GS please double check me. doesn't look to me like you have to remove your intake manifold to get to them (like you do for the rear 3 on the v6) so it shouldn't be too bad. hope this helps
http://i1134.photobucket.com/albums/...33/joecopy.jpg
joeyb is offline   Reply With Quote Quick reply to this message
Old July 27th, 2010, 02:31 PM   #3 (permalink)
Vehicle: 08 pathfinder - modded
akley88 is a splendid one to beholdakley88 is a splendid one to beholdakley88 is a splendid one to beholdakley88 is a splendid one to beholdakley88 is a splendid one to beholdakley88 is a splendid one to beholdakley88 is a splendid one to beholdakley88 is a splendid one to behold
depending on the type of plug u are using like iridium you shouldnt gap them. u can break the electrode since they are so small
akley88 is offline   Reply With Quote Quick reply to this message
Old July 28th, 2010, 09:30 AM   #4 (permalink)
Gots me a sooby
Ballfade's Avatar
Vehicle: 02 wrx
i forgot what size socket i used to remove my sparks, would check but it is at friends house lol.
Anyways do what i did, buy the spark plugs, take it to autozone or somewhere, test fit it in the sockets till you find the right one. You will need an extension.
Mods: Protuned by S.Clark , Ebay hood scoop w/STi air splitter, Ebay turbo inlet, Ebay tmic, Ebay Turbo-back, vf39 w/blanket, STi pinks, Megan mounts, Defi boost, AEM WB, Walbro 255, GS EBC, Tein coils, RA mudflaps
Ballfade is offline   Reply With Quote Quick reply to this message
Old August 1st, 2010, 12:07 AM   #5 (permalink)
subtechnician(eat fresh!)
redstar666's Avatar
Vehicle: 07/gs
redstar666 is a name known to allredstar666 is a name known to allredstar666 is a name known to allredstar666 is a name known to allredstar666 is a name known to all
5/8 plugsocket did the job. make sure you also have some kind of rubber hose to fish the new plug down in the depths and be able to finger tighten first so as not to cross thread. gl
F5CAI, RRE pully/axle-back/header/slotted rotors ceramic pads, Gt TB bp+outlaw spacer, rp 5w20, progress springs/swaybar, tanabe strut bar, 8K HID, cf engine cover, DNX5140
SOON: im spacer, ISAMU body kit , MR coilovers (waiting for spring to install)
redstar666 is offline   Reply With Quote Quick reply to this message
Old November 30th, 2010, 12:06 PM   #6 (permalink)
choppertwo's Avatar
Vehicle: 2014 Mustang
choppertwo has a spectacular aura about
I'm gettin ready to install new pulsars, anybody got a pic of where they're at- THX - CHOP
choppertwo is offline   Reply With Quote Quick reply to this message
Old December 1st, 2010, 12:10 PM   #7 (permalink)
Start here, should give you everything you need to know.
http://tearstone.com/eclipsefsm/2006...0000900-16.pdf
Spark Plugs:
http://tearstone.com/eclipsefsm/2006...0000100-00.pdf
2.4l, how to, manual, plugs, remove, shows, spark, spark plug, spark plug replacement
