Go Back   Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006+ Eclipse Authority > Performance and Technical > 4G Eclipse GS/SE Specific
Old July 28th, 2010, 05:43 PM   #1 (permalink)
4G69er
Lanzerralliart's Avatar
Vehicle: CS7A
Lanzerralliart is just really niceLanzerralliart is just really niceLanzerralliart is just really nice
Intake Manifold Thermal Gasket Group Buy 4g69
If your TRULY interested pm me or post up in the thread. This os for 2 spacers, one between the intake manifold and the motor and the other goes between the throttlebody and the intake manifold.Price is 25 usd shipped for the set with 25 people.
FOR A LIST OF PAID ORDERS LOOK AT POST # 181
1. RJ88 (2x).............11.Cedric..........21.RD_Chef
2. akley88................12.DustinH........22.Darewo od
3. joeyjoey...............13.Pedro (2x)
4.Ralliartize It...........14.ryanastyG4
5. Arxylis..................15.amber1293
6. haladafs................16.06gsgts
7. trevroar(3x)..........17.leet
8. Lanzerralliart.........18.Tsensational
9. sporty...................19.redstar666
10. deadninja............20.Daxenth
RIP SILVERSIDE you'll be immortalized with your accomplishments...The all new 2009 2002 Eclipse - Equipped with 265-horsepower MIVEC V6 - First in the world!
Lanzerralliart is offline   Reply With Quote
Club4G Sponsors
Old July 28th, 2010, 06:03 PM   #2 (permalink)
deadninja's Avatar
Vehicle: Eclipse GS 5-speed
deadninja will become famous soon enough
ALL YOU NEED TO KNOW ABOUT THE THERMAL SPACERS!!!!!!
Gaskets shipped out Thursday/Friday (Aug 26/27)
Thickness of TB and IM gaskets: 1/8th, 2/16th, .125 inches, 3.175mm
The TB will require longer bolts: 8mm x 1.25 pitch - 70mm
You also need to buy new lock washers apparently.
Clean up the IM (using seafoam).
Side options:
1. Conduct a radiator flush
2. Install the motor mounts
Sealing Tips:
1. To prevent the P0171 (running lean), reuse the OEM gasket behind the thermal gasket.
Example: Intake Manifold>OEM gasket>thermal gasket>throttle body.
The OEM gasket between TB and IM has a protruding corner on the top-right.
2. The thermal TB gasket has a side with stencil-like cut impressions. That side needs to to face the TB to create a tight seal as it conforms to the TB curves.
3. Buy gasket sealer for an ultra tight seal.
deadninja is online now   Reply With Quote
Old July 28th, 2010, 06:11 PM   #3 (permalink)
4G69er
Vehicle: CS7A
I honestly don't have a clue he says it's alot cheaper than rpw set ,I'm working on getting more info for you guys, but I'm pretty sure it would depend also on how many people come forward..
Old July 28th, 2010, 07:41 PM   #4 (permalink)
joeyjoey's Avatar
Vehicle: 09/eclipse/gs
joeyjoey is a jewel in the roughjoeyjoey is a jewel in the rough
if its real soon and i can get it before i do some head work count me in.oh if the price is decent lol
09 gs.a/t trans,header,intake with ram air,underdrive pulley,tb bypass,drop springs and nitrous soon to be hooked up.
joeyjoey is offline   Reply With Quote
Old July 30th, 2010, 08:49 AM   #5 (permalink)
4G69er
Vehicle: CS7A
Ok guys I talked me friend that's trying to get this to happen for everyone an the price is about 40 dollars SHIPPED for the SET , as long as we can get 25 people to step up. It's the deal of the year for any 4g69 owner!!!! Post up if you want it.
Old July 30th, 2010, 08:56 AM   #6 (permalink)
got a quote
RJ88's Avatar
Vehicle: 2009 Eclipse GS
RJ88 is a name known to allRJ88 is a name known to allRJ88 is a name known to allRJ88 is a name known to allRJ88 is a name known to allRJ88 is a name known to all
i guess i want some too... what do they do?
add me to the list tho.
Chrome Injen CAI/ Chrome headers/ Underdrive Pulley
Follow me on Twitter
Evo Manifold FOR SALE
RJ88 is offline   Reply With Quote
Old July 30th, 2010, 09:16 AM   #7 (permalink)
4G69er
Vehicle: CS7A
Reduces heat transfer from the engine to the intake manifold
The cooler manifold no longer heats the incoming air which allows increased ignition timing / tuning
This modification can be installed without visible signs and can retain factory new vehicle warrant
Can be cleaned and refitted multiple times
Also supplied with a throttle body insulator as well to stop heat transfer from the water heated throttle body. Retain normal cold start functions.
Old July 30th, 2010, 09:19 AM   #8 (permalink)
Vehicle: 07 eclipse gs
akley88 is a jewel in the roughakley88 is a jewel in the rough
sign me up
Old July 30th, 2010, 09:20 AM   #9 (permalink)
got a quote
RJ88's Avatar
gracias for the clarification.
Old July 30th, 2010, 12:52 PM   #10 (permalink)
Vehicle: 04 Lancer RA
Ralliartize It is on a distinguished road
Gentlemen,
I'm the guy that started it over on EvoM, but per site rules (I didn't know this) only vendors can start group buys. If users can start interest gathering threads that potentially evolve into group buys on club 4g then I can have the guys who would be making them log on and provide more info. I just need confirmation of that.
Although I'm new on Club 4G I want to assure you guys I'm not here to scam you or weasel you out of your monies. Check on EvoM, I'm a regular contributor over there. In fact I'm ponying up some of my own money (template gasket) to get this done.
The plan is once we have enough people I will arrange it so that no monies will come to me, everything will go straight to GT fabrications. I will just provide them confirmations on every order (this will be based on the group buy list). The confirmation will be so that no one outside that first 25 tries to cut the line.
If any of you guys are in Canada I would say add about 12 bux too shipping. that's just an estimate
Once that first 25 comes I will put in the order. Expected wait time once you've paid is about two weeks, if there's a backlog of work around 3-4 weeks.
If there's interest beyond 25 orders GT Fabrications will most likely make the gaskets for sale on their website after the group buy orders are shipped out. I have no idea of when they may do that .
I just want to be clear, I don't work for GT Fabrications, I just am not paying 200 Mother******g dollars to have gaskets shipped from Australia.
Ralliartize It is offline   Reply With Quote
Old July 30th, 2010, 01:01 PM   #11 (permalink)
Shocker
haladafs's Avatar
Vehicle: 2008/Eclipse/Gs
haladafs is a splendid one to beholdhaladafs is a splendid one to beholdhaladafs is a splendid one to beholdhaladafs is a splendid one to beholdhaladafs is a splendid one to beholdhaladafs is a splendid one to beholdhaladafs is a splendid one to behold
Hmmm 40 bucks when ya need money seems like I'm down
MODS:Fujita Cai, Magnaflow Catback, RRE Pulley, 6000k HIDS, Disabled DRLS, RRE Header, VIS OEM CF Hood, 2 jh45mtx subwoofers, 1 jh300 amp, blue led remote bass knob, oem aux ipod connector.
haladafs is offline   Reply With Quote
Old July 30th, 2010, 01:12 PM   #12 (permalink)
Step 1: Clear everything away from the throttle body....intake,loose wires etc.
Step 2: Loosen the 4 bolts on the throttle body
Step 3: With TB in hand, put new longer bolts through bolt openings and place gaskets onto bolts.
A. OEM gasket>thermal gasket>throttle body.
B. Note protruding top right corner of gasket, that has to go back in the same spot
C. You can put on gasket sealer at this point if you'd like
Step 4: Place TB back against IM and tighten securely.
Voila you're done. Takes about 20-25 mins tops.
Old July 30th, 2010, 01:36 PM   #13 (permalink)
4G69er
Vehicle: CS7A
I'd say once we have the slots filled. So tell your 4g69 friends lol.
Old July 30th, 2010, 02:40 PM   #14 (permalink)
trevroar's Avatar
Vehicle: GS Vert, S13 240sx, ZX6R
trevroar will become famous soon enough
$40 mod, DIY-able... sign me up!
07 Eclipse GS Vert Pursuit to Boost!: RRE uD Pulley; Injen CAI; Eibach Pro Kit; RippMods LtH; RippMods F/R Mounts; MagnaFlow Catless-Back; ACT MR1-HDG6 Clutch; AEM F/IC PnP; AEM Meth Injection; AEM UEGO; TbBp; E3.86; GlowShift Pod, Boost & Fuel PSI Gauges; Walbro Inline Fuel Pump; WRX 440cc Injectors; Mobile1 5W-20
trevroar is offline   Reply With Quote
Old July 30th, 2010, 04:17 PM   #15 (permalink)
I just got official confirmation from the manufacturers. 25 shipped for the set!!!!
Old July 30th, 2010, 04:26 PM   #16 (permalink)
4G69er
Vehicle: CS7A
Bump heading changed price changed !!!! People jump on this !!! Pm me or post up if your in.
Old July 30th, 2010, 04:28 PM   #17 (permalink)
got a quote
RJ88's Avatar
I'll buy two sets.... does that count as an extra person?
Old July 30th, 2010, 04:33 PM   #18 (permalink)
I don't see why not. I'm ordering a regular IM gasket so they can begin using that as a draft for the thermal plastic.
Old July 30th, 2010, 04:41 PM   #19 (permalink)
4G69er
Vehicle: CS7A
Updated , I joined it as well. I already have the IM spacer but what the hell I can't pass this up.
Old July 30th, 2010, 04:41 PM   #20 (permalink)
got a quote
RJ88's Avatar
Ok
Old July 30th, 2010, 07:22 PM   #21 (permalink)
deadninja's Avatar
Just to clarify this and I know I'm sounding like a complete noob but just to reassure myself, the Intake Manifold spacer and the Intake Manifold Thermal Gasket are the one and the same, right?
Old July 30th, 2010, 07:40 PM   #22 (permalink)
nope they are two different gaskets.
Old July 30th, 2010, 08:01 PM   #23 (permalink)
trevroar's Avatar
Think you can get them to also do the TB thermal gasket for us at a great price also?
Old July 30th, 2010, 08:07 PM   #24 (permalink)
deadninja's Avatar
What's the difference? They both sound like the same thing. One adds a gasket between the throttle body and the manifold and the other does...?
Old July 30th, 2010, 08:26 PM   #25 (permalink)
4G69er
Vehicle: CS7A
Read the top main post...There are 2 gaskets in the set for 25 dollars ...
Old July 30th, 2010, 08:36 PM   #26 (permalink)
black guy with nawzz
Ballfade's Avatar
Vehicle: 07 silver GS-N
Ballfade has much to be proud ofBallfade has much to be proud ofBallfade has much to be proud ofBallfade has much to be proud ofBallfade has much to be proud ofBallfade has much to be proud ofBallfade has much to be proud ofBallfade has much to be proud ofBallfade has much to be proud of
GL with the group buy! PEOPLE GET THESE MODS IF YOU DONT HAVE THEM, BEST POWER TO COST RATIO!
Mods: just ask
Comin Soon: footage
Nitrous is like a box of chocolate
Ballfade is online now   Reply With Quote
Old July 30th, 2010, 08:48 PM   #27 (permalink)
4G69er
Vehicle: CS7A
So do you want me to add you to the list?
Old July 30th, 2010, 09:02 PM   #28 (permalink)
Ballfade's Avatar
naa i alrdy got the RPW spacer and gasket lol. see if i can get more gs people into this
Mods: just ask
Comin Soon: footage
Old July 30th, 2010, 09:29 PM   #29 (permalink)
4G69er
Vehicle: CS7A
Ok got ya bro.... But yea we need 25 to get it for this price ... Come on peeps it isn't getting any better than this ...
Old July 30th, 2010, 09:50 PM   #30 (permalink)
deadninja's Avatar
lol @ sneaky updates or I'm going blind. This just keeps getting better.
What's up with all the other 4-cylinder Eclipse owners out there?
Alright gotta run but when I get back in the morning, there better be 25 names or "somebuddy gonna geta hurta tonight!"
Old July 30th, 2010, 09:51 PM   #31 (permalink)
Cedric's Avatar
Tournaments Won: 2
Vehicle: 2008 Eclipse GS
Cedric is just really niceCedric is just really niceCedric is just really nice
I'm down...
Cedric is offline   Reply With Quote
Old July 30th, 2010, 09:53 PM   #32 (permalink)
Cedric's Avatar
Tournaments Won: 2
btw for future reference... there is a group buy section =)
Old July 30th, 2010, 10:00 PM   #33 (permalink)
DustinH's Avatar
Vehicle: 2006 eclipse gs
DustinH will become famous soon enough
Im down aswell, I've never bought anything here before so i dont know what to do. Help me out lol.
Obx LT Headers, One Step Colder Plugs, TB Bypass, Injen Cold air intake,
Drilled & slotted rotors w/ ceramic pads, Debadged.
TEIN S-Tech Lowering Springs
Old July 30th, 2010, 10:17 PM   #34 (permalink)
Cedric's Avatar
Tournaments Won: 2
Just make sure you have a paypal account pretty much
Old July 30th, 2010, 10:19 PM   #35 (permalink)
DustinH's Avatar
I've got that...Just unsure about pm's. Don't know what that is or how to do it.
Thanks!
Old July 30th, 2010, 10:23 PM   #36 (permalink)
4G69er
Vehicle: CS7A
Click on your name << , then start clicking on everything to see all of your options available...
Updated we're getting there people, we just need 12 more........
Old July 30th, 2010, 10:46 PM   #37 (permalink)
Pedro's Avatar
Vehicle: 2007/Eclipse/Spyder/GS
Pedro is on a distinguished road
Put me in for a set.
http://www.myspace.com/socal4g
Pedro is offline   Reply With Quote
Old July 30th, 2010, 11:08 PM   #38 (permalink)
Pedro's Avatar
oopps I better ask if, it fits with GS Spyder 07 just to be sure? Yes I'm a newb...
Old July 30th, 2010, 11:10 PM   #39 (permalink)
Ballfade's Avatar
a GS is a GS engine wise . haha
Mods: just ask
Comin Soon: footage
Old July 30th, 2010, 11:17 PM   #40 (permalink)
Pedro's Avatar
Thanx, got to ask when you don't know.
Club4G Sponsors
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
redstar666
Copyright ©2007 - 2010, Club4G.org
