Old April 12th, 2011, 12:35 AM   #1 (permalink)
I look stock...
3CL1PS3's Avatar
Vehicle: 2008 GS 5spd
3CL1PS3 has a spectacular aura about
f/ic mounting
ill be getting my f/ic anytime now but im just wondering what you guys have found the best/ easiest place to mount it. pics are welcome
Magnaflow catback, Injen CAI, RRE Underdrive Pulley,Ripps Brat Box,GT Throttle Body, Throttlebody bypass, Ralco Short Shifter, AEM UEGO wideband,AEM F/IC w/ brianj harness, ralliart strut bar, Optima Yellow top, JL W3 12", JL speakers front/rear, diesel audio 1600 watt apm, pioneer navi, tint.
3CL1PS3 is offline   Reply With Quote
Old April 12th, 2011, 06:52 AM   #2 (permalink)
Perfection over power
Elemenohpee's Avatar
Vehicle: 06 GS-Turbo
Under the dash rite below the steering wheel, works great and the USB cord the supply you with is hella long.
Old April 15th, 2011, 10:46 AM   #3 (permalink)
mrgibs121's Avatar
Vehicle: 2007 eclipse GS
yep thats where mine is too... ive also seen one chillin in front of the fuse box as well.
Old April 15th, 2011, 08:20 PM   #4 (permalink)
leet's Avatar
Vehicle: 2006 Eclipse GS-Turbo
leet will become famous soon enough
thats where i have mine. easy access to the usb port.
leet is offline   Reply With Quote
Old April 15th, 2011, 08:22 PM   #5 (permalink)
leet's Avatar
Old April 15th, 2011, 08:48 PM   #6 (permalink)
Not Your Friendo
Tsensational's Avatar
Vehicle: 2007/Eclipse/GS
Tsensational is just really niceTsensational is just really niceTsensational is just really nice
If you wanna mount under the steering wheel, I suggest you use some heavy duty velcro. Its inexpensive and very stable.
Kalapana Black Sporty GS
F5 Intake//RRE Headers-Catback Exhaust-4g69 Underdrive Pulley-Camshaft//Cusco Front Strut Tower Bar//Progress Lowering Springs//AEM FIC//Zeitronix Wideband
Tsensational is offline   Reply With Quote
Old April 15th, 2011, 08:59 PM   #7 (permalink)
229boss's Avatar
Name: James Alphadawg Jones
fic
what does the fic do for a stock gs?
Old April 15th, 2011, 09:40 PM   #8 (permalink)
^you can dial in your AFR curve if nothing else. We are rich, too rich, coming from the factory tune - so you can 'lean out' your mix for more power.
and as far as mounting the F/IC - you really don't want that under the hood, imo. that is something that should be inside. and if you buy the harness, you get the install DVD from brianj, and he shows you exactly where to mount it. It's the absolute perfect place. and velcro is the perfect thing to use to mount it. good luck!
Old April 15th, 2011, 09:43 PM   #9 (permalink)
Daxenth's Avatar
Vehicle: 2008 Eclipse GS-N
ive read the Fic can bump up stock hp anywhere from 10-25 horses. i have a hard time believing that but what do i know... throw some bolt ons under the hood then we'll talk. i have yet to install my FiC. procrastination fo- ill finish that sentence tomorrow or something
Mods=Daxenth's Satin Girl
Buy My Stock Shit!
mount, mounting, pics
