I look stock...
Jason
2008 GS 5spd
fuel map/map load
today ive been checking out my maps on the fic software and i was able to get the idle fixed by changing the voltage on MAF map to 1.68 but as im experimenting with the fuel map and changing values its not having any luck and have a couple questions.
1. is .8 the minimum increase for the cells. if i try to add anything lower than +.5(0.8) it goes right to 0.8 2. the cars "load" stays in the 15&12.5 rows. what are the others there for? ![]() 3. i tried to add +.5 fuel in the 3400-5950rpm range and it ran really choppy like when i would let off the gas or let it stay in gear for too long. why is that? 4. on the x-axis of fuel map what should the rpm numbers read from where to where. like start at 4000 and end at 6300? or do i need it to read from idle to redline. thank you in advance for any and all advice!!
I look stock...
Jason
2008 GS 5spd
anyyyyonneee? lol
06 Eclipse GT
You have to hook up a vacuum line from the FIC to the manifold...the reason it's staying at 12.5 - 15 is because the FIC isn't connected to the manifold.
If you're not forced induction, you'll never see over 15 or so...so you should rescale that side from 0-16 instead of 0-40... I forget, but .8 might be the lowest you can go...remember that's .8 of 1%...that's not much change... People will have different opinions on the RPM scale...but I would set it to 0-7500...
I look stock...
Jason
2008 GS 5spd
i put a T splitter in my vacuum line on the valve cover and intake and ran the tube from there to the fic..not enough vacuum? so scale it 0-16 going up by 2 and a half each time? also wherever i put that .8 it was really jerky and ran like crap. actually if i put anything other than 0's it ran like crap
I look stock...
Jason
2008 GS 5spd
where else could the vacuum line go?
#6 (permalink) | |
Contributing Member!
Trevor
07 Spyder GS6
V6 Swap in Progress; Fujita F5 CAI, MagnaFlow CatBack, Energy Suspension Bushing, KYB/Eibach Pro Kit Combo, TB Bypass, Ripp Mods F/R Poly Mounts, Iridium IX One Step Colder Plugs, 8k HIDs Last edited by trevroar; April 28th, 2011 at 11:28 AM. |
Trevor
07 Spyder GS6
V6 Swap in Progress; Fujita F5 CAI, MagnaFlow CatBack, Energy Suspension Bushing, KYB/Eibach Pro Kit Combo, TB Bypass, Ripp Mods F/R Poly Mounts, Iridium IX One Step Colder Plugs, 8k HIDs |
I look stock...
Jason
2008 GS 5spd
ahhh. yeah that was the thing i was figuring out if i should remove or not. is that the only other vacuum option or just good idea?
Trevor
07 Spyder GS6
I would say tap the stock black baffle... if something goes wrong, it would be easiest to repair/replace.
I look stock...
Jason
2008 GS 5spd
did removing the baffle do anything positive for yours tho?
Perfection over power
Trevin
06 GS-Turbo
You could get a vacuum block and hook it up to the IM bit thas just a waste of money I suppose. Want me to take a pic of how mine is?
I look stock...
Jason
2008 GS 5spd
yeah if you could that would be awesome. im up for any options that are available
Trevor
07 Spyder GS6
There was a discussion on it awhile back... some said it improved gas mileage without it there, but there was a loss in low end power. It was advised that the baffle helps the velocity stacks in the manifold so it was best to leave it on.
Trevin
06 GS-Turbo
Well my car is in the shop but I'm gonna dig and find a picture with my vaccum block so you can see how I have it set up. My block is hooked up to my f/IC, turbo, wastegate, and boost gauge from the IM
![]() Sorry for the bad quality it's the only one I have, you can see where my vaccum block hose connect to the left side of the IM. That's where I get all my pressure readings from. |
Rob
2009/Eclipse/GS
They hooked up this vacuum line to my fic when they tuned it. Does this line have to stay connected to the fic permanently? Or just while tuning it?
Boobies: Because you can't motorboat personality |
Trevor
07 Spyder GS6
Did you just "t" the port on the head into the one on the intake?
I look stock...
Jason
2008 GS 5spd
oh i see its like a distributor for vacuum then. i just need to move the vacuum source then to either where trevroar did or how you did it
trev--yeah i cut the line from the head to the intake in half and put the T in between, then ran the fic tube to the fic
Rob
2009/Eclipse/GS
Could anybody verify that for me? Because after they tuned it they disconnected it. If it needs to be connected that would explain why i havent noticed much of a difference... I wouldnt think it would need to be though... anybody? Brian?
I look stock...
Jason
2008 GS 5spd
idk zumspeed. i just started doing all this also. but i would guess that yes you do need it hooked up. try it out and see if you get the gains back
#20 (permalink) | |
Trevin
06 GS-Turbo
EDIT: Eclipse you dont need to do it like I did because I have a ton of hoses that need to read vaccum thats the only reason I have the block, for you to have it would be overkill but I figured I would show you an actual way to connect it if nothing else works for you, you have that. |
#21 (permalink) |
Rob
2009/Eclipse/GS
I PM'd brian about it in case he doesnt read this thread again. I'm really not sure though because if they tuned it and saved the map, then I guess its possible that you wouldnt need it connected. Because my AFR's are changed from what they used to be so the tune is there... baha im such a tuning nOOb
#22 (permalink) | |
Rob
2009/Eclipse/GS
#23 (permalink) |
Trevin
06 GS-Turbo
Hey next time you get it tuned bring a USB and ask them to load anything they do to it on the USB, all the maps they used trial and error. it would be a good bit of help for a few N/A people in the future to see who are about to do this. thats only if you ever go again, just a sugestion
#24 (permalink) |
I look stock...
Jason
2008 GS 5spd
oh gotcha. yeah ill probably tap into the baffle then unless trev can confirm removing it was a gain then ill remove it and hook it up like his pic showed. thanks tho!
#25 (permalink) |
Trevin
06 GS-Turbo
When you say trav it confuses the hell out of me because their is two of us lol, but I know who your talking to its just very amusing
#26 (permalink) |
Trevor
07 Spyder GS6
If you're map is based on load, then you'll need it connected. You can check this by looking at the setup on the fic software
#27 (permalink) |
Trevin
06 GS-Turbo
So trev since I am heavily load based if I ever take away the vaccum connection the F/iC wont respond as it should VS. having it in correct?
#28 (permalink) |
I look stock...
Jason
2008 GS 5spd
haha srry.
trevroar-how much would you want for the cover with the hose tap on it?
#29 (permalink) | |
Trevor
07 Spyder GS6
Mystery piece of plastic?
#30 (permalink) |
I look stock...
Jason
2008 GS 5spd
yeah i was in on that thread a couple times. everyone just kinda seemed back and forth. did you like it tho?
#31 (permalink) | |
Trevor
07 Spyder GS6
$30 to your door... I believe I paid $45 for it
#32 (permalink) |
Trevor
07 Spyder GS6
Once I took mine off, I left it off, didn't personally notice anything. But now I have the ralliart manifold
#33 (permalink) |
Trevor
07 Spyder GS6
Actually, I'm starting to second guess myself here..... best to wait for BrianJ on this one
#34 (permalink) |
Trevin
06 GS-Turbo
Ok well thanks anyway, always unanswered questions when it comes to the F/iC. I'll wait to see as well what he has to say about all of this.
#35 (permalink) |
Rob
2009/Eclipse/GS
Brian said that yes it needs to be hooked up if that was how it was tuned, I'm gonna run the line and then download the map. I'll go do this now, idk what size tube i need but I'll go figure it out I guess unless you know Elemenohpee off the top of your head
#36 (permalink) | |
Loves haters !
09 5 speed manual
Modified |
#38 (permalink) |
I look stock...
Jason
2008 GS 5spd
zumspeed--on your tuned fuel map what are your values on the y-axis(left side) where it says load-map-psia
#39 (permalink) |
I look stock...
Jason
2008 GS 5spd
like is it re-numbered from 1-16 like brian said and if so does it go up a whole number each time?
| art, cars, fic, fuel, gas, gear, injen, long, lower, maf, questions |
