Old May 9th, 2011, 10:20 PM   #1 (permalink)
keep on modding
eclipsemodder's Avatar
Vehicle: 2008/eclipse/SE
eclipsemodder has a spectacular aura about
Question rpm/exhaust problem please help
alright so ive fixed the exhaust leak and it sounds a little better but its still raspy as fuck past 3k rpms....also since the header install, when im in 2nd gear the rpms will randomly drop or rise when im holding the pedal steady. wtfffffffffffff is going on....this is annoying me so muchhhhh.
Found this quote hilarious...
"may God bless your soul and may your intake only suck in the coldest and purest air forever and ever amen."
eclipsemodder is offline   Reply With Quote
Old May 9th, 2011, 11:10 PM   #2 (permalink)
theBIGone
SMeclipseGT's Avatar
Vehicle: 2006 Eclipse GT-P
SMeclipseGT is just really niceSMeclipseGT is just really niceSMeclipseGT is just really nice
bump**wish i knew man
The Silver Beast
http://club4g.org/board/members-ride...tml#post523843
SMeclipseGT is offline   Reply With Quote
Old May 9th, 2011, 11:12 PM   #3 (permalink)
keep on modding
yeah its bugging the crap out of me. consuming my thoughts lol
Old May 9th, 2011, 11:13 PM   #4 (permalink)
hmmmmmm....ok - could you put up a picture of your entire exhaust system or describe it in detail as to what is in there and what isn't. is there any stock piping in there at all? resonators? cats?
you may be leadking around the header gaskets, did you replace all of the exhaust gaskets when you installed your headers? that needs to be done. you have the GS, right?
Old May 9th, 2011, 11:21 PM   #5 (permalink)
keep on modding
Okay so the obx header to begin with, gaskets were replaced the header is bolted down hella tight, where the header bolts up to the small pipe it comes with it is bolted up hella tight as well, then it is welded to the stock piping (perfect weld no leak), then there is the third cat right after that, then it goes down to where the resonator was deleted and a new pipe was put in, i fixed the leak earlier then it goes through stock piping to the hks muffler
Old May 9th, 2011, 11:25 PM   #6 (permalink)
keep on modding
i can understand the raspyness for the most part cuz its prettty much straight piped but the rpm dips is a concern, there is no check engine light either
Old May 9th, 2011, 11:52 PM   #7 (permalink)
Bats Eat Fruit
Matched88's Avatar
Vehicle: 2008 Sunset Pearl GS
Matched88 is on a distinguished road
its ONLY the rpm gauge doing this? you not feeling anything what so ever?
Matched88 is offline   Reply With Quote
Old May 9th, 2011, 11:55 PM   #8 (permalink)
keep on modding
no im feeling it too.
Old May 10th, 2011, 12:08 AM   #9 (permalink)
Bats Eat Fruit
Matched88's Avatar
does the car feel like its jerking/having hiccups when its happens?
usualy rpm jerking is signs of ignition problems, so i would check things like plugs,injectors,pump,pump relay, and also check out throttle sensor/relays
Old May 10th, 2011, 12:11 AM   #10 (permalink)
keep on modding
yeah kinda feels like it hiccups. do i maybe need to tighten o2 sensors more? this only happened after i installed the header so i doubt it can be anything more then o2 sensors?
Old May 10th, 2011, 12:25 AM   #11 (permalink)
keep on modding
and i still dont understand why it sounds beast when its in neutral being revved but they when im driving it sounds like shit. wtf. blah
Old May 10th, 2011, 12:39 AM   #12 (permalink)
Bats Eat Fruit
Matched88's Avatar
i would say first stop by an autozone and borrow a scanner to see if there is any hidden codes before further messing with the o2 sensors because i have had previous cars throw codes without me knowing until i voluntarily scanned my car, but yes i would check those out and any of the other things i listed for "just in case" situation
Old May 10th, 2011, 12:50 AM   #13 (permalink)
Amarillo 4g
DustinH's Avatar
Do you have spacers on your lower o2 sensors?
Old May 10th, 2011, 12:51 AM   #14 (permalink)
keep on modding
i do not
Old May 10th, 2011, 02:43 AM   #15 (permalink)
Amarillo 4g
DustinH's Avatar
Get some on those lower sensors.
drop, exhaust, gear, header, install, leak, pedal, problem
