Old May 12th, 2011, 02:22 PM   #1 (permalink)
keep on modding
eclipsemodder's Avatar
Vehicle: 2008/eclipse/SE
eclipsemodder has a spectacular aura about
Question trying to avoid paying a mechanic :/
sooo my car is still being a bitch. i went to oreilly this morning and the code was p1047 or something which is the too lean code. idk what to do...ive been fidgiting with the o2 sensors for days now and nothing is working. car boggs down every like 20seconds while driving. sometimes its hard just to push the car past 2k rpms cuz its bogging so bad. anyone else have any ideas? i really dont wanna pay more money on this issue.
Found this quote hilarious...
"may God bless your soul and may your intake only suck in the coldest and purest air forever and ever amen."
eclipsemodder is offline   Reply With Quote
Old May 12th, 2011, 02:34 PM   #2 (permalink)
dsm2mivec's Avatar
Vehicle: 06 Mitsu Eclipse GS
Ok so this could be totally wrong but maybe you have some kind of carbon build up on your o2 or maybe one of the wires are burnt up? Maybe it's not plugged in completely by the header? Idk I haven't heard of this happening but that is my best guess or maybe if you have spacers from rre they are clogged? just tryin to help
Old May 12th, 2011, 02:35 PM   #3 (permalink)
x-street
bullet06's Avatar
Vehicle: 06/GT/AT
Time for a fic man or fuel injector cleaner. Realy don't know though man golf luck though.
Old May 12th, 2011, 02:39 PM   #4 (permalink)
x-street
bullet06's Avatar
Vehicle: 06/GT/AT
Ya that is true I had a wire get fried and had problems till the car die because I couldn't't track it down. With the car not running though I had plenty of time to find it and it was a melted wire.
Old May 12th, 2011, 02:40 PM   #5 (permalink)
keep on modding
how do u know which o2 sensor is bad specifically if that is the problem?
Old May 12th, 2011, 02:46 PM   #6 (permalink)
haladafs's Avatar
Vehicle: 2008/Eclipse/Gs
haladafs is a splendid one to beholdhaladafs is a splendid one to beholdhaladafs is a splendid one to beholdhaladafs is a splendid one to beholdhaladafs is a splendid one to beholdhaladafs is a splendid one to beholdhaladafs is a splendid one to beholdhaladafs is a splendid one to behold
should say on the slip, I had carbon build up on my piston which caused it to fail, which ended up in a new short block
Magnaflow Catback Exhaust & Fujita F5 CAI
haladafs is offline   Reply With Quote
Old May 12th, 2011, 02:51 PM   #7 (permalink)
keep on modding
damnit im getting a bit worried now haha.
Old May 12th, 2011, 05:05 PM   #8 (permalink)
keep on modding
it also said BANK 2? what does that mean lol
Old May 12th, 2011, 07:21 PM   #9 (permalink)
yeah my guess would be o2 sensor issues. perhaps clogged or too much build up. I would start with a visual examination of the sensors themselves, carefully clean them, and see if that buys you anything. sounds like ECU is not getting the proper reading of how much fuel is actually in there - which could be caused by clogged o2 sensors.
how many miles are on the car? you will likely need a tuning shop to help trouble shoot this, as the dealer or O'riellies just isn't going to know enough
Old May 12th, 2011, 09:15 PM   #10 (permalink)
keep on modding
53k exactly is on the car, and how do i properly clean o2 sensors?
Old May 12th, 2011, 09:22 PM   #11 (permalink)
Amarillo 4g
DustinH's Avatar
I use carb cleaner or brake cleaner. Whats the set up man ...o2 spacers? On what o2 sensors if any?
Old May 12th, 2011, 09:25 PM   #12 (permalink)
keep on modding
yeah but do u soak it or what? yeah i went and bought the spark plug anti foulers and drilled them out and put them on the lower o2 sensors
Old May 12th, 2011, 09:35 PM   #13 (permalink)
Amarillo 4g
DustinH's Avatar
Take some pics of the foulers "how much theyre drilled" Just spray carb cleaner on them.
Old May 12th, 2011, 09:41 PM   #14 (permalink)
keep on modding
okay ill go take pics now
Old May 12th, 2011, 10:24 PM   #15 (permalink)
keep on modding
Old May 12th, 2011, 10:24 PM   #16 (permalink)
keep on modding
Old May 12th, 2011, 10:30 PM   #17 (permalink)
Amarillo 4g
DustinH's Avatar
Mine are drilled out a little more than that. Try a little more..or as much as u can go. Also be sure the sensors are plugged in the right spot on the harness.
Old May 12th, 2011, 10:53 PM   #18 (permalink)
keep on modding
its just i dont have a drill bit that will go a little wider without hitting the threads at the top, is there another way to hollow it out more? my spacers im hoping will be here tomorrow that i ordered off ebay. will those work right away instead?
Old May 12th, 2011, 10:58 PM   #19 (permalink)
Amarillo 4g
DustinH's Avatar
They should...Im not sure though. Buy a bigger bit. Or try a stepper bit.
Old May 12th, 2011, 11:05 PM   #20 (permalink)
keep on modding
and im slightly confused as to what exactly the spacer does...does it just keep it farther out of the exhaust and keep it cooler?
Old May 15th, 2011, 05:20 PM   #21 (permalink)
keep on modding
this is such fucking horseshit. i got the new spacers for the o2 sensors that i bought off ebay like someone said to do and it still runs like shit. fuck this engine.
Old May 15th, 2011, 05:27 PM   #22 (permalink)
Queen Goon
Asian Cracker's Avatar
Tournaments Won: 3
Vehicle: 06/Eclipse GT
Asian Cracker has a reputation beyond reputeAsian Cracker has a reputation beyond reputeAsian Cracker has a reputation beyond reputeAsian Cracker has a reputation beyond reputeAsian Cracker has a reputation beyond reputeAsian Cracker has a reputation beyond reputeAsian Cracker has a reputation beyond reputeAsian Cracker has a reputation beyond reputeAsian Cracker has a reputation beyond reputeAsian Cracker has a reputation beyond reputeAsian Cracker has a reputation beyond repute
Try getting new o2 sensors
Chaos -
lisa i like your car a lot. Here's why, the black says ill fuck you up if you try to mess with me but the pink accents tells me that you'll cuddle afterwards
-Mods: SRI, Exhaust, Headers, Stiffy, Rear Sway bar, Motor Mount, Reflashed Ecu, Black
-Pink Rims , Spoiler,Painted tail lights, 2% Tint Tein Springs,-
Asian Cracker is offline   Reply With Quote
Old May 15th, 2011, 06:27 PM   #23 (permalink)
keep on modding
they r expensive and i dont know which ones to get if that is the problem.
Old May 15th, 2011, 06:35 PM   #24 (permalink)
Amarillo 4g
DustinH's Avatar
I just noticed in your pic and i dont know if it makes a difference or not but the bung that was welded in is at an angle. So even with the spacer on it the exhaust is going to be pushed towards the sensor. But like i said i dont know if it matters. Make sure the o2 sensors are plugged into the right plug on the harness, thats if you mixed them up somehow. The spacers you ordered and made should work unless theres something else wrong...And the engines awesome but the ecu gets bitchy. Take your time with it.
Old May 15th, 2011, 06:36 PM   #25 (permalink)
Amarillo 4g
DustinH's Avatar
Try double spacers on the lower 2 see if it helps any...Sometimes one isnt enough!
Old May 15th, 2011, 06:38 PM   #26 (permalink)
Amarillo 4g
DustinH's Avatar
Oh and next to last resort..Extend your "lower" o2 sensor wires run them down behind the 3rd cat "if you have one" weld 2 bungs there. Your ecu will read that theres a cat in the system.
Old May 15th, 2011, 10:50 PM   #27 (permalink)
keep on modding
yeah i still have the third cat, should i do that? where can i buy the proper kit or whatev to extend the wires? also how would i fill the lower o2 sensors on the header? and behind im assuming would be the side towards the back of the car after the cat
Old May 15th, 2011, 10:52 PM   #28 (permalink)
Amarillo 4g
DustinH's Avatar
I've got some plugs at my shop that cap off the bungs. I'll see if i can round them up.
Theres a thread somewhere that joeyb posted that had our type of o2 wiring extended. I would do that...But before anything make sure the sensors are good so u dont have to spend alot
Old May 16th, 2011, 05:38 PM   #29 (permalink)
keep on modding
okay thatd be much appreciated. yeah im not exactly sure how to figure out if the actual sensors are bad and how many, ive been trying to search it but not getting very good results.
bad, car, code, issue, money, sensors, what to do
