call centers suck
Elliott
06/eclipse/gs 5spd
obx lt for gs questions
after seeing the price of the obx header for the gs on ebay, I figured id search them on here, which brought up more questions.
thank you all for the anticipated help 1. are they really as bad as they are made out to be? 2. how hard is install, i am assuming it would be harder than the rre? 3. instead of welding to stock exhaust can you use a pipe clamp? 4. can you run with the 3rd cat? if yes, do you still need to weld the o2 bung? 5. does the o2 spacers clear the cel?
mods: rre header, rre axleback, rre underdrive pulley, tb bypass, fujita cai/aem bypass valve, eibach prokit, twm shifter/type r knob, tanabe stb, oe fogs, webasto sunroof, eclipse cd4000 hu |
Amarillo 4g
Dustin
NO, People just dont do it right. 2. how hard is install, i am assuming it would be harder than the rre? Not harder but does require MORE work. 3. instead of welding to stock exhaust can you use a pipe clamp? Only if you want to deal with exhaust leaks in the future!!! 4. can you run with the 3rd cat? if yes, do you still need to weld the o2 bung? Yes you can...Yes you will. The header only has 3 o2 bungs. our car had 4 o2 sensors. 5. does the o2 spacers clear the cel? If you either get the right ones or make the right ones. Pm me if you need some answers.! |
Amarillo 4g
Dustin
Because obx has another product sold separately "Test pipe" or cat delete and it has the "lower" two bungs needed for the sensors. The bung on the header thats by its self is for a afr gauge. Or so i was told.
keep on modding
2008/eclipse/SE
fuckin a...no one told me they sell a test pipe separately....would this fix the issue im having?
Found this quote hilarious... "may God bless your soul and may your intake only suck in the coldest and purest air forever and ever amen." |
2007 Spyder GS
then why do they include the stupid pipe with no bungs with the header? I was just thinking thats not a bad value, $235 for a SS long tube with a section of pipe that deletes the cat in the downtube included, but i guess im starting to see why people make the install out to be hard?
what is hard about it? especailly of u can buy the test pipe separately and just put a plug in the 5th hole. |
Amarillo 4g
Dustin
The best thing to do honestly is install the header itself, Then take the rest of it to a shop and have them weld the down pipe to your existing exhaust. Put spacers on the lower o2 sensors and its a done deal.
2007 Spyder GS
where can u buy this test pipe? i dont see it on OBX homepage. they dont even show a header for a 4g there either.
and whats the deal with the spacers? |
2007 Spyder GS
i find it odd that pipe is straight, and the one included with header is not. no mount flange either. have to take a look while up on stands doing springs and see what might work well. thanks
2007 Spyder GS
that pipe does not appear to fit this app. at all? the 02 bungs are towrads the middle, and it has a curve where it should be straight, and its straight where it should be curved
#13 (permalink) | |
Amarillo 4g
Dustin
| bad, cat, cel, exhaust, header, install, obx, pipe, question, questions, rre, stock |
