2007 gs eclipse spider
2007 spider cat converter and o2 sensersending codes
Hi
I just purchased a 2007 spider gs and have a service engine light on.My mech said i have code for a o2 sensor and a cat convertor problem.Is there other options besides buying a new cat convertor I,m going to install a new 02 sensor 1st hopefully my light goes out.I live in canada where is the best place to buy a new sensor?? NGK Part#24674 Any help would be very helpful Thankyou |
08 Eclipse GT - SC
have you searched? there's dozens of threads that discuss these codes on here.
Which headers do you recommend ?? I take it the headers have ports for o2 sensors and that should end my service light issue. Because the car had to pass Canadian emissions they also welded another cat converter on. So even with headers there will still be a convertor in the system.
Thankyou |
Pat
08 GT Spyder 6MT
for the GS i think Road Race Engineering is pretty much your only option, and wait times may be high right now... check the thread about it
![]() headers will not solve your check engine light problem, but at least they eliminate the cat converter and add some hp you must be talking about the 3rd cat, underneath the car, correct? you can keep this one, or replace it with a high-flow cat (same idea, just better)...if your stock cat converter is going bad, you will see an engine light... if you replace it with headers, the engine light might still be there because the computer is reading something different than "stock"... in other words, exhaust gases are not getting filtered anymore as they normally would with the stock cat... the computer expects the post-cat gases to be different than pre-cat gases (the whole point of a cat converter)... RRE headers means no cat in headers, pre-cat gases = post-cat gases = computer is confused... there are ways around it, check the numerous threads about that in the GS section... anyway, i'm starting to confuse myself here, so a more simple way to put it is: - your stock cat is going bad... - if you're under warranty and dont care about some extra performance, take it back to the dealer, get it replaced with stock, and dont worry about it... - if you're out of warranty, get the RRE headers (cheaper than stock), install them, and deal with the engine light if it shows up... good luck ! BTW, where in Canada are you? i know i didnt give 2 sh**s about emissions laws when i deleted my 3 cats in the GT
John
2007 Eclipse GT
Post your OBDII Code/s So we can tell you whether it's a sensor or if the pre-cat is bad. You'll love the price of a pre-cat, $728.00 US dollars. That's why it is a lot cheaper to go with RRE headers. You should be able to find the part number here also.
RRE Parts & Mods: Road Race Engineering's 4G Eclipse Parts and Performance Exhaust Manifold/Pre-cat: http://www.partswebsite.com/courtesy...n=7&type=parts Depending on which O2 Sensor you need: Lower: http://www.partswebsite.com/courtesy...n=2&type=parts Upper: http://www.partswebsite.com/courtesy...n=2&type=parts
2007 Eclipse GT=Sunset=Auto--20% Tint=Injen CAI=RIPP Long Tube Headers (Jet-Hot Coated)=RIPP High Flow Cat=RIPP BRAT Box=Magnaflow Cat Back Exhaust=Energy Motor Mounts=Ingalls Stiffy=Megan Coilover Suspension=Progress Rear Sway Bar=SP Performance Diamond Cut & Slotted Rotors=EBC Yellow Stuff Kevlar Pads=Diamond Lower Grill=Konig Illusion Wheels=BF Goodrich G-Force Super Sport Tires Last edited by Clovisman; June 5th, 2011 at 10:57 AM. |
John
2007 Eclipse GT
The main restrictions in the exhaust system are the Pre-Cat, and OEM Muffler. There is very little HP gained by replacing the secondary cat, so a high-flow secondary cat is not necessary. You can also keep the entire exhaust system if you decide to go with RRE Headers, and replace the stock muffler with a Magnaflow Muffler or any straight through type muffler.
There is one combined Exhaust Manifold / Pre-Cat REMOVAL AND INSTALLATION <2.4L ENGINE> Page 15-17 http://tearstone.com/eclipsefsm/2006...0004600-15.pdf And there is one Secondary Cat EXHAUST PIPE AND MAIN MUFFLER REMOVAL AND INSTALLATION <2.4L ENGINE> Page 15-23 http://tearstone.com/eclipsefsm/2006...0004600-15.pdf
I,m not looking for more horsepower just trying to get rid of that ses light the simplist way. Hey anyone had anything to do with Big Daddies Garage and there 02 simulator cel fix??? Learning more every day
Pat
08 GT Spyder 6MT
If you only need to get rid of the light, replace the faulty sensor, or get oem headers.
Dont bother with anything that was said before... Most people here are performance oriented and will not replace a faulty stock part with another stock part, but rather upgrade to something better... Easiest way to keep the light off is to keep it all stock. Cheers! |
#15 (permalink) | ||
John
2007 Eclipse GT
If you can get someone like your auto parts store to read the OBDII DTC code and post the code here, we will have a better idea what is wrong, and what needs to be replaced. We do have access to the Eclipse Service Manual for T-shooting and repairs. Eclipse Service Manual, you will need Adobe Acrobate to read the service manual. http://tearstone.com/eclipsefsm/ps2406intro.pdf
2007 Eclipse GT=Sunset=Auto--20% Tint=Injen CAI=RIPP Long Tube Headers (Jet-Hot Coated)=RIPP High Flow Cat=RIPP BRAT Box=Magnaflow Cat Back Exhaust=Energy Motor Mounts=Ingalls Stiffy=Megan Coilover Suspension=Progress Rear Sway Bar=SP Performance Diamond Cut & Slotted Rotors=EBC Yellow Stuff Kevlar Pads=Diamond Lower Grill=Konig Illusion Wheels=BF Goodrich G-Force Super Sport Tires Last edited by Clovisman; June 6th, 2011 at 10:29 PM. |
#17 (permalink) | |
John
2007 Eclipse GT
If you could get someone to pull the OBDII code/DTC, we will be able to tell you what is wrong. I'd hate to see you spend money on something that does not need to be replaced. Also with the code I can dig up the information for T-shooting that O2 sensor, and with a multi-meter you can test that sensor before you try to remove the sensor. Just a note, sometimes when you try to remove the sensor, over time the threads of the sensor sometimes gets welded to the manifold. So make sure you use a propper O2 Sensor socket wrench ($5.00), it will help in the removal. Also in advance, like the night before, spray the threads with some penetrating oil, and before you strart the removal spray the threads again. If the sensor does take some threads with it, you'll need to buy a tap set to clean the threads in the manifold before re-installing. if you don't do this, you risk stripping the hole out and then you will be stuck with buying a new manifold. This stuff does happen once and a while, so at least if you know about, it won't be that big of a shock. Also when you do re-install any exhaust type parts, and to include sparkplugs, make sure you use some anti-seize compound on the threads so you won't have this type problem when removing that part again. This is especially true with sparkplugs, our heads are made from aluminum so those threads will strip easily. HEATED OXYGEN SENSOR CHECK, 2.4L. Page 13A-1204 http://tearstone.com/eclipsefsm/2006...05800E-13A.pdf
2007 Eclipse GT=Sunset=Auto--20% Tint=Injen CAI=RIPP Long Tube Headers (Jet-Hot Coated)=RIPP High Flow Cat=RIPP BRAT Box=Magnaflow Cat Back Exhaust=Energy Motor Mounts=Ingalls Stiffy=Megan Coilover Suspension=Progress Rear Sway Bar=SP Performance Diamond Cut & Slotted Rotors=EBC Yellow Stuff Kevlar Pads=Diamond Lower Grill=Konig Illusion Wheels=BF Goodrich G-Force Super Sport Tires Last edited by Clovisman; June 8th, 2011 at 02:48 AM. |
| 2007, canada, cat, code, converter, ding, engine, engine light, install, light, live, o2 sensor, problem, service, service engine light |
