Old June 22nd, 2011, 09:28 PM   #1 (permalink)
Wakko's Avatar
Vehicle: 2012 Mazda 5
Wakko is on a distinguished road
A/C Question?
Ok so My daughter and I went to the store today. Well I turned the A/C on and We got a blast of a finger nail polish smell as my daughter put it. Then My cold a/c stopped blowing cold air. The fan works, but not cold. Is this my Freon needing replacing or is it something worse and I prey it's not worse... Thanks for any help you guys can give me.
(Stock )
Wakko is offline   Reply With Quote
Old June 22nd, 2011, 09:44 PM   #2 (permalink)
2fast4u's Avatar
Vehicle: Sporty eclipse gs
2fast4u will become famous soon enough
Sounds like either a refridgerant line burst or the condenser core burst. Either way it wont be cheap. The cost of the refridgerant itself will run you a good 200bones, its not cause you lost a little you lost a lot. That smell in cab, thats the refridgerant. They dont use freon any more. If your lucky, a fitting came loose to the core.
2fast4u is offline   Reply With Quote
Old June 23rd, 2011, 08:49 AM   #3 (permalink)
Wakko's Avatar
UGH, Thanks for the information. My brother and I are gonna check it out today if the rain stays away.
(Stock )
a/c, air, cold, cold air, question, works
