x-street
Matt McAlear
06/GT/AT
Maybe is all anyone can say. Dealerships are all different some are cool some are not. But if it don't directly affect what's wrong you can take them to court.
2007 eclipse GS
simple just swap it every time you need to go to the dealer
Cesar
2008 Generic Veyron
i have a CAI and full exhaust and my dealer still does EVERYTHING under warranty.
aka Niño4g
Alex
Magnuson–Moss_Warranty_Act
TL;DR: Your mods only will void the warranty of what they replace, not the whole warranty. And only if they can prove the part you installed caused a failure. Last edited by 4gAddict; July 21st, 2011 at 02:03 PM. |
travis
07 eclipse gs-n
^^ exactly.
John
2007 Eclipse GT
CAI... taking your time, about an hour and a half. If this is your first install, take your time, it's so easy you might over look something. Also do a little reseach on CAI... tons of do's and don't, pay attention to those and you won't run into any problems.
Take care of your MAF/IAT Sensor, i.e. don't drop, bump or get it dirty, and before you start the install disconnect both battery leads, when you finish connect the battery leads back-up. This will cause the ECU to reset and learn its new parameters from the factory setting, and it will also reset your throttle position sensor to its new idle position. I.E. you'll be less likely to throw any codes this way. CAT Back Exhaust, depending if you have any rusted parts, two to three hours.
#13 (permalink) | |||
Will
2007 Eclipse Spyder GT-PN
#14 (permalink) | |
Joey
2007/GS
| cai, car, exhaust, exhaust system, question, system, warranty |
