Shawn Saabye
2007 Eclipse GS/SE
burning antifreeze
hey guys my car is smoking like a blue ish hazy smoke out of the exhaust and its not burning oil but it looks to be like its burning antifreeze cause after a week of driving my resevoir was almost empty...is this burning antifreeze? and if so what could be wrong with my car? thanks a lot guys
John
2007 Eclipse GT
For the most part, the cooling system is a closed system, and coolant doesn't normally evaporate, so... Sounds like you have some major problems if your coolant is leaking into the combustion chamber and leaving a smoke trail out of your exhaust. More then likely your head gasket has a leak, or you have a cracked head or block.
How is your warranty?? First owner 100,000/10 years, second owners 60,000/5 years on mostly everything except consumables. If not mechanically inclined, find a good mechanic or dealership to do the work, and make sure you get the quote and warranty in writing. A cracked head or block will be expensive, even a head gasket will cost about $500/$600. If you are close to 70,000 miles, you my as well get those services done at that time, about another $500/$600. Point in case, most of the same stuff will have to come off to repair the head gasket so the labor chage should be absorbed by the head gasket job. If you wait to do the 70,000 mile scheduled maintenance it will cost about $1000 to have it done at a later date.
OWNER OF C4G
Rick
2008 GT-SC
x2 ^^^^^^ proably a head gasket... Goodluck man keep us updated
Liquid Latex
Myles
2006 Eclipse GS
i vote head gasket
Mods : I have some. Future Mods : I want some. Uninstalled Mods laying around : I wish. Newest Mod : Ricos super awesome LED Fog Bezels M/T all day, errday.
Elitist Prick
Jason
2011/Eclipse GS
I third the head gasket. Could also be warped or cracked head. I doubt the cracked block because a block will usually leak to the outside of the block, as opposed to internally.
RRE UPD, Custom Exhaust, CAI, AEM F/IC, Ralco Short Shifter, Eibach Rear Sway, Big Cock |
Dexy's Driver
Jay
2006/Eclipse/GS
correct me if I'm wrong but doesn't coolant burn whitish cooler(like steam) and oil normally burns blueish, and I second nokiauser it will stink really bad, has the car overheated for have you noticed a change in operating temp?
Elitist Prick
Jason
2011/Eclipse GS
^I was thinking the same thing, but considering his loss of antifreeze, I was leaning more toward coolant issues.
| blue, car, exhaust, oil |
