Quebec Light Source
Olivier
Lancer ES/AWC 2012
How to -> GS oil catch can
Hello everyone,
Here is a little "how to" to install a oil catch can on a GS. This installation is very very...very...very....ve....ry...simple. When you buy your catch can, it comes with all the hardware, BUT the hose included is very short and ugly as hell so you probably want to get a new one. So i ordered 10 ft of 1/4 vacuum hose from ebay for this installation(1/4"(6mm) is a bit small so you better get a 5/16"(8mm) one(you will need something like 5 ft). Now all you have do to is assemble the can wich means...take the collar and tighten it on your bracket. The easiest place i found to mount the can is on the hole that is originally made for the OEM filter box. There is only 1 hole but 1 screw is enough to hold your can in place(drill a 2nd hole if you wish to). Run the 1rst piece of hose from your valve cover to you catch can, and then run the 2nd piece of hose from your catch can to your intake. Before plugging the hoses you should put the collar on it wich is a bit logic and tighten the 4 collars in place. Now you are done...what??? you tough it would be harder????Some pictures now You think that a oil catch can is useless on your "not so moded" car???? ![]() ![]() My GS only have 50 000km...so what your own intake manifold looks like??? ![]() ![]() ![]() ![]() Some links you might need for your own catch can The can i bought the hose i bought (remeber that 5/16" or 8mm is the best but 1/4 can do it) Last edited by zedawg; August 30th, 2011 at 06:46 PM. |
Celer, Silens, Mortalis
Rob
2006 GT
How similar is this with a gt hook up I wonder?
"If you teabag someone with a nut allergy is that attempted murder?" -J Chris Newberg |
2009 4G69
did u notice the first pic of his manifold with all of the oil residue inside. it also builds up on ur throttle body. the silicone line that connects to ur intake is a breather for the engine and it often spits out oil residue. the catch can prevents it from building up in ur intake and manifold. hence the name "oil catch can"
#7 (permalink) | |
Chris
2008/Eclipse/Gs-N
2009 4G69
well i got my parts together and i will toss mine on tomorrow. i could use one for sure
will post pics as well
2009 4G69
here is my install . . i have a breather filter on the nipple at the bottom of the can that way the oil vapor is not going into the can and being re-sucked back into the intake and the filter also prevents the vapors from building in ur bay.
AEM FIC / UEGO Wideband + POD / Custom Bolted Last edited by FeaRlezZ; August 31st, 2011 at 12:28 PM. |
2009 4G69
?? where then. . . i have seen a good amount of build-up on the front face of the throttle going into the manifold. . . that means the vapors enter through the intake ?? i just tossed it on today lol. let me guess it should b connected to the line thats above the ignition coils ?
#18 (permalink) | |
Loves haters !
09 5 speed manual
Modified |
#20 (permalink) |
a=dv/dt
Matthew
2008 ECLIPSE GS
so tell them where it does................
Selling E4E rear and sides, will need to be refinished and repainted. Pm me |
#22 (permalink) | |
2009 4G69
so do i now leave the line connected to the valve cover and run it to the can . . . then connect a seperate line from the manifold to the can and leave my breather ??
#23 (permalink) |
Loves haters !
09 5 speed manual
honestly dude,i had an inline see through filter on the line you have hooked up to the can right now.had it on for a good 6 months and i never seen no oil on the filter.i even took the see through filter off and ran a hose to a small breather filter close to the firewall.it stayed cool the whole time.i would put the oem hose,(or a better one) back on the intake tube and put the catch can on the other side connected to the pcv hose(if you can figure out how to mount it) to keep the vacuum line as short as possible
Modified Last edited by snakeeyes; August 31st, 2011 at 02:11 PM. |
#25 (permalink) |
Tanner
2008 eclipse GS
Just wanted to say thanks for making this thread, this is something i plan on doing at some point.
I got that boom boom slow |
#30 (permalink) |
2009 4G69
but u dont have ur catch can in the most productive location. ccv is where the vapors come from
#34 (permalink) |
UV Blue Crew
Jay
2006 Eclipse GS Auto
I'm just seeing a "." in place of where your pics are suppose to be. I'm just needing to see where to run lines to and from for the catch can.
Gutted Exhaust Manifold; GT TB w/bypass; RRE Pulley; Tanabe Front Strut Bar; GT Front Strut Bar; DC Sports CAI; RPW Spacers; CF Mod-GT Hood; Halo's; Footwell, dome, and trunk LED's; Oil Catch Can; Black on Blue My ride -> My Sexy Blue Beast |
#36 (permalink) |
Loves haters !
09 5 speed manual
look around on ebay.i do believe this is the one we all have;
Godspeed Universal Oil Reservoir Catch Can Tank Turbo Racing Silver JDM Parts | eBay
Modified |
#37 (permalink) |
Quebec Light Source
Olivier
Lancer ES/AWC 2012
Exactly. But the vacuum hose included with the cans is short and very ugly so you better order some. This is where i bought mine from http://stores.ebay.ca/ZENARacing/Sil...=p4634.c0.m322 .
#39 (permalink) |
Kat (Karolyn)
2011 Spyder GT-P
well looks like I ordered the same oil catch can as zedawg but I am worried that a few of you say the way his is hooked up isn't correct. Also found a Youtube video which shows a different hook up
Oil Catch Can Install on 4g Eclipse GT. - YouTube Anyone have more detailed pictures or information for a gal who isn't mechanically enclined and wants to try to do this herself? hmmm
Mods so far: Eibach Pro Kit lowering springs, Injen CAI, Redline Tuning hood lifts, Ralliart colour matched eyelids, custom painted fuel door with eclipse, painted calipers, Kenwood DNX 7160 Double Din w/bluetooth and Garmin GPS |
| box, bracket, buy, car, cover, filter, how to, install, installation, intake, intake manifold, links, manifold, mount, oem, oil, oil catch can, pictures, screw, short, valve |
