Old October 2nd, 2011, 06:55 AM   #1 (permalink)
Vehicle: 2007 eclipse se 2.4l
Kingjames359 will become famous soon enough
Evo rods?
So i read some ware that the evo rods fit 2.4l gs if this is true does any one know what year fits/bolt on. ??
Magnaflow catback 2.50 , GT tb (thermal spacer), Injen sri, RRe headers (jet hot coated),RRe underdrive pulley, cf/gunmetal oil cap, pulstar sparkplugs, ss brake lines, pro-kit drop, Halo projectors, projector eyelids, 6000k hid,Led taillights, Disabled DRL, Oem fogs blacked out, 5% Tint, debadged, 18x8 matte black Rohana rims, Falken 912 tires.
Kingjames359 is online now   Reply With Quote
Old October 2nd, 2011, 11:16 AM   #2 (permalink)
x-street
bullet06's Avatar
Vehicle: 06/GT/AT
Any evo 8-9 models not the x just make sure there for the 4g63 and not the 4b11 and You'll be fine.
Old October 2nd, 2011, 11:25 AM   #3 (permalink)
Vehicle: 07 eclipse gs-n
yeah 4g63 rods are what you want.
Old October 2nd, 2011, 12:19 PM   #4 (permalink)
dsm2mivec's Avatar
Vehicle: 06 Mitsu Eclipse GS
But only get the evo 4g63 rods bc I ordered 4g63 head studs and they were for a 1g dsm and it's what digit off in the part number and they were too big
Old October 2nd, 2011, 12:26 PM   #5 (permalink)
4G69er
Lanzerralliart's Avatar
Vehicle: CS7A
Lanzerralliart is a glorious beacon of lightLanzerralliart is a glorious beacon of lightLanzerralliart is a glorious beacon of lightLanzerralliart is a glorious beacon of light
the head studs, mains, and bearings will fit you just need to get them for a 7bolt 4g63
RIP SILVERSIDE you'll be immortalized with your accomplishments...The all new 2009 2002 Eclipse - Equipped with 265-horsepower MIVEC V6 - First in the world!
Lanzerralliart is offline   Reply With Quote
Old October 2nd, 2011, 12:31 PM   #6 (permalink)
yeah i picked up head and main studs for a 7bolt.
heres this is over on evolutionm's site
The only thing I don't like about the 4G69 is that the block height is 6mm shorter than the 4G64. This brings the block height back to the same as the EVO 4G63. The 4G69 uses the same length rods as the EVO with a longer stroke of 100mm. EVO pistons, even forged ones can be used in the 4G69. However, these pistons need to be 87mm. That's the only downside. The solution is to get stroker pistons for the EVO in 87mm. 87mm pistons for an EVO, however, are not easily sourced. They more than likely would have to be made custom by JE, Wiseco, Arias, etc.
4G69 uses 4G63 rod and crank bearings (old news)
4G69 uses 4G64, 4G94 valve guides and seals
4G69 uses the EVO timing belt tensioner which is aluminum, not cast iron
4G69 intake valve = 34mm (4G63 EVO = 34mm) May fit?
4G69 exhaust valve = 30.55mm (4G63 EVO = 30.5mm) May fit?
4G69 uses 4G64, 4G94 valve spring retainers
4G69 uses 4G63, 4G64 head bolts (can use 4G63 ARP head studs )
4G69 uses 4G63, 4G64 main bolts (can use 4G63 ARP main studs )
4G69 uses 4G63 EVO balance shafts (can use 4G63 EVO BS eliminator kit )
Nothing spectacular, I know. Every little bit helps though. Here's a good read on how Mitsubishi took a 4G64, modified it and called it a 4G69: Article (http://www.theautochannel.com/news/2...14/253444.html). Lightened rods, lightened crank, lightened crank pulley, larger valves, shorter block height and other goodies. They did a very nice job and came out with a very nice engine.
I Know that Eagle just released a 100mm stroker kit for the Evo/ Eclipse. Something you might want to look into.
Old October 2nd, 2011, 12:37 PM   #7 (permalink)
229boss's Avatar
Name: James Alphadawg Jones
what does this mod do exactly?
DC SPORTS CAI....PIAA LIGHTS....DRL MOD......RALLIART EYELIDS....FLAT BLACK PAINTED STOCKERS.....NEXT MOD??? FLAT BLACK PAINT JOB AND WHEELS!!!!
Old October 2nd, 2011, 12:42 PM   #8 (permalink)
what the rods. it beefs up the engine for boost, nitrous, or what else someone has planned.
Old October 2nd, 2011, 10:32 PM   #9 (permalink)
ok im gana try to find some thanks for the info if i can get my money right im gana try to buy that psi kit and evo rods with wisco pistons from rre or coustm pistons from ross. im also trying to buy new 1mm over valve rods . springs etc
Old October 3rd, 2011, 12:58 AM   #10 (permalink)
What ratio should i look for ?
Found on ebay http://item.mobileweb.ebay.com/viewi...id=66000366350
Old October 3rd, 2011, 01:47 AM   #11 (permalink)
you can get pistons for the 4g69 cheaper through import performance parts then rre
Old October 5th, 2011, 05:56 AM   #12 (permalink)
chowetime's Avatar
chowetime is on a distinguished road
That is a great buy as the add reads as though you are going to be getting rods pistons headbolts gaskets...
Was Turboed now going all Motor
circuit racehttp://www.youtube.com/watch?v=kfCJ5PjRToI
drag race http://www.youtube.com/watch?v=DGcYaSg2-K0
Headers http://www.youtube.com/watch?v=u7C3_ui5-24
chowetime is offline   Reply With Quote
Old October 5th, 2011, 06:07 AM   #13 (permalink)
evo pistons will not work unless the whole setup is for a 100mm stroke i believe
Old October 5th, 2011, 07:20 AM   #14 (permalink)
dsm2mivec's Avatar
I thought they just had to be stroker pistons 87mm
Old October 5th, 2011, 08:46 AM   #15 (permalink)
4G69er
Vehicle: CS7A
kingjames do some more research before you think about just throwing money into the car , not half of what your saying is needed for a dd 4g69, and the $ to hp gain ratio is something to consider unless your rollin in the dough.
87mm evo pistons will work
Old October 5th, 2011, 09:32 AM   #16 (permalink)
wiseco makes 4g69 forged pistons. a set costs 479 with out rings
Old October 16th, 2011, 11:12 PM   #17 (permalink)
I have and still learning but the $ to hp ratio is ok to me with psi turbo kit upgraded internals ill be rollin good. I plan to keep this car till it drops like a old indian mans truck.
So that set i have posted will work?
Old October 19th, 2011, 04:37 AM   #18 (permalink)
Bump
Old October 20th, 2011, 11:49 AM   #19 (permalink)
4G69er
Vehicle: CS7A
It looks like it will work but dropping your cr from 9.5:1 to 8.5:1 will kill your car without a tune for it, It will be good for a higher hp turbo build.
Old November 4th, 2011, 04:14 PM   #20 (permalink)
How about this kit you seem to know a lot so thank for ya help
http://item.mobileweb.ebay.com/viewi...id=24917661917
Old November 5th, 2011, 01:45 AM   #21 (permalink)
bump
Old January 22nd, 2012, 11:03 AM   #22 (permalink)
I love To Drift
Animefreak1983's Avatar
Vehicle: 07 Eclipse GT
Animefreak1983 has a spectacular aura about
Will they work on a GT as well?
An is it worth doing on one?
Join the list of those attending the Illinois 4g meet that's taking place June 1st.
http://club4g.org/board/great-lakes-...-up-sheet.html
Animefreak1983 is online now   Reply With Quote
Old January 22nd, 2012, 11:04 AM   #23 (permalink)
dsm2mivec's Avatar
I would say no.. I think it's just i4
Old January 22nd, 2012, 12:22 PM   #24 (permalink)
Its well worth building internals if plan on boost or fi of some kind.
Old January 22nd, 2012, 12:43 PM   #25 (permalink)
i have those rods, and arp cylinder head and main studs for sale
Old January 22nd, 2012, 12:57 PM   #26 (permalink)
Vehicle: 2006 Lancer Ralliart
i wonder if 6-bolt 4G63 rods will fit, appearently they are stronger than their 7-bolt counterparts...
Old January 22nd, 2012, 01:03 PM   #27 (permalink)
from what i read on evom the 4g69 needs to use the 7 bolt. the manley h beams that i have are rated to 700bhp. which is more then anyone on here has made
Old January 22nd, 2012, 01:47 PM   #28 (permalink)
dsm2mivec's Avatar
No I know from experience that it has to be 7 bolt
2.4l, evo, fit
