Old October 14th, 2011, 12:57 PM   #1 (permalink)
Chris05's Avatar
Vehicle: 2008/Eclipse/Gs-N
Naaawwzzzz
Sooooo yea. I bought this Zex kif for $400 shipped off the s2k forums and I got a great deal.
10lb bottle
Bottle Warmer
two mounting brackets
All SS hoses and lines
Electronic Pressure gauge (now I need a gauge pillar/ pod)
A Purge kit
2 Choices of Buttons
And the engine management unit
I will keep you guys updated but its not going in until I get new plugs and thermal Spacers and when Kevin Chu and I build a custom box to house My subs and my Bottle
If anybody has any ideas on the box design I'm open to ideas and also any tips for the Nitrous
I don't wanna blow the welds off my manifold
Chris05 is offline   Reply With Quote
Old October 14th, 2011, 01:06 PM   #2 (permalink)
oh you lucky bastard I am so jealous..............................keep us updated w/ plenty of pics please, chris
if you are going for NO backseat at all, ever, I would just have some kind of box that puts the nozzles right up between the two front seats so you can turn around and turn them on. have 2 bottles in a "v" w/ the tip of the "v" aimed right at you between the seats. BAM.
If you want a back seat, I'd just make sure it's mounted at the right angle while still giving you some sub-woofer and trunk space, but also install the auto-openner that you can buy. oh man I can't wait to see you get this in there.
I say again - you are lucky. I am jealous. I want a shot of dope so bad it hurts....but I have to get my engine built and swapped in, not to mention my cooling situation squared away before I can even consider doing this. BUT if it comes to a point where I can get a good set-up for cheap I will be jumping on it if I can.
Old October 14th, 2011, 01:10 PM   #3 (permalink)
Chris05's Avatar
Will do! and I may do a RSD depending on how I feel about it but that's a great Idea I just need another bottle now! Stop filling my head with money leeching Ideas! D= that sounds super sexy though and What do u mean engine swap :O and with all the crazyness you have going on in your engine Cooling is a priority just like I'm not putting mine in until I know my engine can handle it but thank you for the idea and the compliment
Old October 14th, 2011, 01:16 PM   #4 (permalink)
well shit man, a bunch of guys have blown their engines up trying to go FI. So in order to avoid that I have purchased forged pistons, rods, and various other internals to "fully build" my engine. I have even acquired another 6G75 that I will build up at my liesure, that way I don't have to side-line my car for who knows how long while I build it out. I still need several parts before I can complete the process - gasket package, head studs/bolts, etc.
Long story short - I am fully building another 6G75 and once it's ready I will 'swap' it into my GT and it will be a fire-breathing monster - especially if I can get a 125 shot on there like I am planning. the only other person w/ a fully built motor is dejectedangle - and he has stock heads. I am going to get a 3-angle valve job by delta cams, bigger/stronger springs, retainers, lifters, etc. (that is holding me up - it's $2500) so my motor will be COMPLETELY & FULLY Built when done. Twilson and RangerTimmy are also doing similar builds and are going to have fully built motors as well at some point here in the future - probably before me. They are working on Timmys' car right now, and I know that Thomas is getting close to done. So once we are all done that should be 4 members w/ fully built engines. I'm just doing mine on another 6G75 so I can swap when it's built and not have to be w/out my car for too long. It's just taking me forever.
Good luck though man, I can't wait til you get that going!!
Old October 14th, 2011, 01:24 PM   #5 (permalink)
Chris05's Avatar
Oh my lord! I wish you the best of luck with that hopefully I'll get to that point some day and run like 30 lbs of boost! a 3-400 whp GS :O then with a 125 shot of Nitrous! :O the seed has been planted .__. thanks for the couple thousand you just made me spend in the far off future.
Old October 14th, 2011, 01:33 PM   #6 (permalink)
Vehicle: 07 eclipse gs-n
start with a small shot to get used to the nitrous. make sure that you have premium gas in the tank when you go to you the nitrous. otherwise avoid using it at low rpms. ill warn you the extra power becomes addicting.
Old October 14th, 2011, 01:39 PM   #7 (permalink)
Vehicle: 2006 Lancer Ralliart
boost is highly addictive...
Old October 14th, 2011, 02:09 PM   #8 (permalink)
Huge Member
Steveo's Avatar
Vehicle: 2006 Eclipse GT-N
Steveo will become famous soon enough
Wouldn't hurt to tune with the fic., I suggest a bottle opener also
Full Bolt On + Zex 75 wet shot ~ 353WHP~~327lbs TQ
http://club4g.org/board/members-ride...ates-ride.html
RIP Matt (bullet06) A great man you were.
Steveo is offline   Reply With Quote
Old October 14th, 2011, 02:11 PM   #9 (permalink)
both of those r one of my next investments
Old October 14th, 2011, 02:16 PM   #10 (permalink)
oh yes, I'd say that's a MUST HAVE. You don't want to run un-tuned when throwing that go-juice into your engine, trust me. When Ian tuned his up - mainly retarding at the high end, and leaning out where possible, it made a hell of a difference. You want the F/IC for sure. Just thinking of that as a given, but yeah, good call Steve.
Old October 14th, 2011, 02:29 PM   #11 (permalink)
Huge Member
Steveo's Avatar
Ya I didn't hook up the open throttle switch so that I couldn't use it until it gets tuned..haha my back up safety precaution.
Old October 15th, 2011, 01:48 AM   #12 (permalink)
Chris05's Avatar
goodness :O alright I'm already afraid I'm gonna be using it from a dead stop at red lights and such lol wise extra power comes great abuse... thanks for the tips guys I'll keep you posted
Old October 15th, 2011, 01:49 AM   #13 (permalink)
Chris05's Avatar
how does the bottle opener work? does it just remotely open the bottle like actually twist it? and without it do I just keep the bottle open at all times? or everytime I wanna use it do I have to stop open the bottle, blast off then stop and close it then wanna blast off again so I open it again and so on? haha
Old October 15th, 2011, 03:40 AM   #14 (permalink)
Huge Member
Steveo's Avatar
With the bottle opener you will have a switch next to ur purge and activation..u hold it for 2 seconds the bottle opens..run, close it, purge.. What it does is replace the valve handle thing. It will electronically open the bottle..it's a must I think or else you will have to get out of your car every time..don't wanna be doin that when something pulls up next to you..
Old October 15th, 2011, 07:10 AM   #15 (permalink)
you could do i what i do for now. stop and look like an idiot reaching back into the trunk to open the tanks
Old October 15th, 2011, 03:10 PM   #16 (permalink)
Chris05's Avatar
lol whatever works! any type of brand preference? I know it only opens a bottle but maybe some are crap haha
Old October 16th, 2011, 04:46 AM   #17 (permalink)
Huge Member
Steveo's Avatar
I'd go on eBay. I found one from Zex and it's great looks cool to I can't post any pics from my iPad but if you go in my member thread or pictures you will see it it's the purple thing on top.. I paid $180 but it's so worth it..there are cheaper ones but I didn't want cheap when it came to opening my nitrous. Plus you will be able to keep Zex name for ur kit..let me kno if you need any help man..it's good u have the gauge already and the heater is a plus
Old October 16th, 2011, 05:53 PM   #18 (permalink)
Chris05's Avatar
Yea I'll probably save up for that thanks for all the help guys! I'll be PM-ing Steveo and Akley in the near future! you guys are great
Old October 18th, 2011, 02:53 PM   #19 (permalink)
I-Eat-Hondas's Avatar
Vehicle: 2008 eclipse GS
Chris, If you want any ideas or help fabbing a box that's sorta my thing send me a PM
I got that boom boom slow
box, buttons, custom, engine, gauge, great deal, manifold, mounting, nitrous, plugs, subs, uni, zex
