Old November 28th, 2011, 03:23 PM   #1 (permalink)
Vehicle: 2008/Eclipse/GS
agent_of_chaos26 is on a distinguished road
idle issue
when my 2008 Eclipse GS is at a stop my tacometer needle is jumping erratically. anyone have any suggestions as to why or how to fix it? the only performance mod that i have so far is a fujita intake.
agent_of_chaos26 is offline   Reply With Quote
Old November 28th, 2011, 04:11 PM   #2 (permalink)
Vehicle: 2009 4G69
check for any vacuum leaks
Old November 29th, 2011, 12:47 PM   #3 (permalink)
NitroGlisson's Avatar
Is it just the needle on the tach or do you actually hear the engine fluctuating too?
Old November 29th, 2011, 01:22 PM   #4 (permalink)
snakeeyes's Avatar
Name: Loves haters !
Vehicle: 09 5 speed manual
check and make sure your battery is good
recheck all the clamps tightness on your intake connections.
bad gas maybe ?
you should do the tb bypass as well.not much point in having a cai when your throttlebody gets as hot as your radiator.
Modified
Old December 11th, 2011, 08:54 AM   #5 (permalink)
Mnm
Moyer627's Avatar
Moyer627 is an unknown quantity at this point
Did you just put on your cai? Cuz when I put mine on it did the same thing then I unhooked the battery and that same day put on a gt throttle body but Rebooting the ecu did help. Was still not a steady idle for about a week. Since though I've had a steady 600rpm idle. It seems like the ecu has to learn the mods and adjust till its right.
Moyer627 is offline   Reply With Quote
Old December 11th, 2011, 11:21 AM   #6 (permalink)
nokiauser's Avatar
Vehicle: Eclipse GS 5 Speed
^ resetting the ECU helps but only if there are no vacuum leaks. Make sure everything is fastened good.
08 eclipse, 2008, eclipse, eclipse gs, fix, fujita, how to, intake, issue, mod, performance
