Old December 30th, 2011, 07:48 AM   #1 (permalink)
UV Blue Crew
jhun35's Avatar
jhun35 is a name known to alljhun35 is a name known to alljhun35 is a name known to alljhun35 is a name known to alljhun35 is a name known to all
Timing belt question
I was reading on here that the GS has a timing and driveline/balancing belt or something like that. I was wanting to replace my timing belt and get a new underdrive pulley (2006+ Mitshubishi Eclipse (2.4 MIVEC) RRE Underdrive Pulley Kit Sport Compact Auto & Import Performance Superstore) is this pulley for the timing belt or the other one? And if it is not for the timing belt where would be the best place to get a new one? Sorry, I'm the most intelligent when it comes to mechanics of a vehicle. Not something I took a lot of time to learn yet. But thanks for any help!
jhun35 is online now   Reply With Quote
Old December 30th, 2011, 08:06 AM   #2 (permalink)
Chris05's Avatar
Vehicle: 2008/Eclipse/Gs-N
Are you trying to replace it or upgrade it? The one you found is the upgrade
Chris05 is online now   Reply With Quote
Old December 30th, 2011, 08:12 AM   #3 (permalink)
UV Blue Crew
jhun35's Avatar
I wanna upgrade the pulley definitely. I'm slowly modding the car. I just didn't know if the pulley and belt I found was the timing belt or the other belt the GS has.
Old December 30th, 2011, 08:14 AM   #4 (permalink)
b1gkishan's Avatar
1 Highscore
Vehicle: 06 Gt 6spd
b1gkishan is a glorious beacon of lightb1gkishan is a glorious beacon of lightb1gkishan is a glorious beacon of lightb1gkishan is a glorious beacon of light
Timing belt doesn't have a pulley my dude. It has sprockets and tensioners.
Originally Posted by joeyb
- it may ruin me financially, get me divorced, and who knows what else, but I WILL get this build done some day
Est.430+whp Nitrous-150shot. Aiming for 350+WHP N/A
b1gkishan is online now   Reply With Quote
Old December 30th, 2011, 08:17 AM   #5 (permalink)
UV Blue Crew
jhun35's Avatar
Okay, so the pulley is for the other belt then. Where would be a good place to find the replacement timing belt?
Old December 30th, 2011, 08:23 AM   #6 (permalink)
UV Blue Crew
jhun35's Avatar
2006 Mitsubishi Eclipse Timing Belt - Gates W0133-1767123 <---would this be all i need?
Old December 30th, 2011, 08:23 AM   #7 (permalink)
dsm2mivec's Avatar
Vehicle: 06 Mitsu Eclipse GS
There are two timing belts on a gs and they only send you the front belt! Im a little worried when you say your not that familiar with mechanics bc you probably are gonna have to pull the motor and our timing belts are sorta crazy
Good luck though
Old December 30th, 2011, 08:28 AM   #8 (permalink)
UV Blue Crew
jhun35's Avatar
I'm not gonna be the one putting it on lol I would probably mess something up pretty bad. I'll be doing it with my dad and uncle more than likely. But if they only send the front belt where would I get the other one?
Old December 30th, 2011, 10:24 AM   #9 (permalink)
b1gkishan's Avatar
1 Highscore
Vehicle: 06 Gt 6spd
There is only one timing belt. The other one is for a balance shaft.
Old December 30th, 2011, 11:15 AM   #10 (permalink)
dsm2mivec's Avatar
If I'm not mistaken can't you use the balance shaft eliminator kit out of the evo x
Old December 30th, 2011, 11:42 AM   #11 (permalink)
mrgibs121's Avatar
Vehicle: 2007 eclipse GS
the belt can be replaced with the engine in the car, its just a hugeeee pain in the ass. you can do the underdrive pulley yourself. took me only about an hour. i would definitely have the belt done at a shop tho. be expecting a 600+ dollar bill for the job
Old December 30th, 2011, 01:04 PM   #12 (permalink)
UV Blue Crew
jhun35's Avatar
Okay I see now. My fiance's step dad owns a shop so I may be able to get him to let us do it there. Because $600 is ridiculous for maintanence. So the pulley i seen with the belt that comes with it would be for the balance shaft, which shouldn't be hard to do from reading other people talk about it online. Just the timing belt is going to be the annoying part.
Old December 30th, 2011, 03:14 PM   #13 (permalink)
dsm2mivec's Avatar
Haha no that pulley is for your serp belt the balance shaft belt is behind the timing belt
Old December 31st, 2011, 06:57 AM   #14 (permalink)
UV Blue Crew
jhun35's Avatar
Damn, okay, got it haha. Do I need to replace the balance shaft belt also? One of my belts squeel's really awfully when it's really rainy or cold and just started this about two months ago.
Old December 31st, 2011, 09:36 AM   #15 (permalink)
nokiauser's Avatar
Vehicle: Eclipse GS 5 Speed
Squealing is usually caused by a worn out serpentine belt.
Old December 31st, 2011, 11:10 AM   #16 (permalink)
UV Blue Crew
jhun35's Avatar
Oh wow, you're right. lol I don't know what I'm talking about. I know my car could use a replacement timing belt (115,000 miles :/) and I want the lighter and smaller underdrive pulley as a mod. But I can get a new serpentine belt right now and put that on. I for some reason just assumed it was my timing belt because I knew I needed to reaplce it lol. Thanks for all the help tho guys.
Old December 31st, 2011, 12:38 PM   #17 (permalink)
b1gkishan's Avatar
1 Highscore
Vehicle: 06 Gt 6spd
You better replace the timing belt ASAP with those miles. They get dry rotted and get cracks. You don't want a timing belt to pop ...they don't make noises to let you know they are going bad lol. If it pops you looking at cpl grand worth of damage vs 500$ timing belt job and water pump job.
Old December 31st, 2011, 06:40 PM   #18 (permalink)
So many ideas, But no $$$
Scottishsamurai's Avatar
Vehicle: 2007/SE/GS
Scottishsamurai has a spectacular aura about
when do you usaully replace the timing belt? about how many miles give or take?
DC CAI, Custom Interior Paint, Custom Interior wiring/switches, Black painted stock rims, Aftermarket Fogs, Orange underglow, ATL Rotors
Scottishsamurai is offline   Reply With Quote
Old December 31st, 2011, 07:07 PM   #19 (permalink)
Trying to be fully built
roman lujan's Avatar
Vehicle: 2007/eclipse/gs
roman lujan has a spectacular aura about
100,000 miles
mods/ obxr lt header/es motor mounts/cold air intake/megan racing catback/ rre und pully/gt tb/stage one delta cam/ aem fic/ msr stlye 44 rims/tein stechmods i have waiting to be put in stage 2 cam/ manly rods/ apr head and mian studs/ wisco pistions/in need of a nitrious kit/ head/intake manifold
roman lujan is offline   Reply With Quote
Old January 4th, 2012, 12:32 PM   #20 (permalink)
UV Blue Crew
jhun35's Avatar
I'm going to this month. I'm going to get the underdrive pulley, a new timing belt, waterpump and serpentine belt and do it all at once.
Old January 4th, 2012, 12:46 PM   #21 (permalink)
the mathematical
mwaterous's Avatar
Vehicle: 07/Eclipse/GS
mwaterous is just really nicemwaterous is just really nicemwaterous is just really nice
Do the UDP yourself for the experience, it's a ridiculously easy install and a great way to get wet behind the ears (showering is another great way to get wet behind the ears, but that only gives you two extra torques).
The only thing I'd recommend is getting into the habit immediately of either taping the screws you pull out (of the splash guards, etc) to the hole they go back in, or placing them in an area that will remain untouched in a pattern you would remember a week later. Otherwise you will put them back in wrong, or lose one which is almost as bad.
Also the UDP comes with the new belt you need, don't buy that separately unless you need a spare. Keep the little cardboard shell that comes with it so you know what model number to get if you ever do need a replacement.
Sorry for thread jacking.
mwaterous is offline   Reply With Quote
Old January 4th, 2012, 12:48 PM   #22 (permalink)
the mathematical
mwaterous's Avatar
I had a timing belt go out on a Ford Escort, on the Las Vegas strip of all places... thankfully the Escort 2.0l sohc is a non-interference engine, but at the time my knowledge of diagnosing was pretty limited and I tried turning it over a few times before we figured it out.
Try that on an Eclipse and you might as well write it off and get a new one.
Old January 4th, 2012, 01:15 PM   #23 (permalink)
UV Blue Crew
jhun35's Avatar
^this is my biggest worry. I know they can cause a ton of damage. :/ that still sucks though man.
Old January 4th, 2012, 08:22 PM   #24 (permalink)
nokiauser's Avatar
All these people helping you out and not a single erep doled out to answer your questions? Kids these days.
Old January 5th, 2012, 02:35 AM   #25 (permalink)
Vehicle: 2006 Lancer Ralliart
stripped the T-belt on my 4G69 lancer at around 4k rpm...no damage...of course i didn't know until i removed the head. but i skipped the compression test and just pulled it cause i assumed being an interference engine that i was going to find holes in my pistons, or smashed valves, or something terrible, but the pistons actually made very little contact with the exhaust valves only...
HOWEVER! it did cost me around $900 to repair, and i did all the work myself, except for machining the head, reseated and lapped valves etc. was done professionally, and cost around $300...the rest was shipping and parts...the gaskets and timing belts kit was very pricey...
Old January 5th, 2012, 06:55 AM   #26 (permalink)
UV Blue Crew
jhun35's Avatar
I was all repped out yesterday and the day before from the e-rape thread. I got you today though.
Old January 5th, 2012, 08:25 AM   #27 (permalink)
Vehicle: 2009 4G69
im not looking forward to doing a timing belt on this car. . . luckily i should still have a long time before that day comes
Old February 7th, 2012, 11:58 PM   #28 (permalink)
Vehicle: 2007 Eclipse GS
chad_a_alex is on a distinguished road
Hey guys. I'm coming up on 60k and going to be doing the timing and balance shaft belts myself. I'm not questioning my ability to do the work, but I'm curious to know if I should buy any of the special tools? If I should, any recommended sites to buy them from would be greatly appreciated. Thanks in advance for any advice.
chad_a_alex is offline   Reply With Quote
Old February 8th, 2012, 08:23 AM   #29 (permalink)
Megawatt's Avatar
Vehicle: 2008/Spyder/GS
Megawatt is on a distinguished road
If you're seriously considering replacing your timing belt go here: http://tearstone.com/eclipsefsm/2006...000500-11A.pdf
Section 11A-50 has the drawings, component names, and torque specs you need to know. At 115 k miles In addition to both timing belts I would also recommend replacing (or at least closely inspecting) the tensioner and idler pulleys.
The Only known 4G Spyder with a Power Antenna
Injen SRI, De-bagged, Blackened Diamonds and Fuel door
Megawatt is offline   Reply With Quote
Old February 8th, 2012, 09:09 AM   #30 (permalink)
Vehicle: 07 eclipse gs-n
i have to do mine soon. im just gonna replace everything while im in there
Old February 9th, 2012, 03:13 AM   #31 (permalink)
good call...there's actually a really sweet video on youtube someone did for a 4G69 timing belt job...pretty sure it's an eclipse, but same engine as us Lancer RA...
anyways great visual how-to, should use the manual as well, but it helps to actually see it
Old February 9th, 2012, 05:30 PM   #32 (permalink)
Aviator
Jonrod's Avatar
Vehicle: Sexy?
Jonrod has a reputation beyond reputeJonrod has a reputation beyond reputeJonrod has a reputation beyond reputeJonrod has a reputation beyond reputeJonrod has a reputation beyond reputeJonrod has a reputation beyond reputeJonrod has a reputation beyond reputeJonrod has a reputation beyond reputeJonrod has a reputation beyond reputeJonrod has a reputation beyond reputeJonrod has a reputation beyond repute
Not something that is simple by any means. I had one strip 12 teeth on me, luckily I had no valve damage.
Originally Posted by randman View Post
Win. You've had a long hiatus from the site your rants are legendary.
Glad your back this site plummets with almost every noob sign up. Bomb away
Jonrod is offline   Reply With Quote
Old February 9th, 2012, 08:07 PM   #33 (permalink)
same here, my belt was stripped in two spots opposite eachother on the belt, so they were competing on which side would fail first...but no valve damage...
inspect your timing belt often!
Old February 25th, 2012, 02:24 AM   #34 (permalink)
B-bo4's Avatar
Vehicle: 2007/Eclipse/GS
B-bo4 is on a distinguished road
be sure to change out your timing belt man! at 60k miles bc my car is now in the shop and i may have done some major dammage....
B-bo4 is offline   Reply With Quote
Old February 25th, 2012, 03:23 PM   #35 (permalink)
mot700's Avatar
Vehicle: 2008/Eclipse/GT
mot700 is on a distinguished road
How many miles were you at when your timing belt gave out?
Sent from my BlackBerry 9650 using Tapatalk
2008 Eclipse GT - Sun and Sound Package - Fujita Cold Air Intake, OBX Long Tube Headers, Header-back exhaust system, 50% tint
mot700 is offline   Reply With Quote
Old February 28th, 2012, 11:51 PM   #36 (permalink)
B-bo4's Avatar
Just hit 100,000 luckly I had no valve damage! But it was about 500$ to get the belt replaced but to get the valves replaced would have been anywhere from 1500-2500 according to the people at my shop.. So if you have more than 60k def a good idea to start thinking about getting a new belt
Old February 29th, 2012, 08:47 AM   #37 (permalink)
mot700's Avatar
Yeah, I guess it could have been worse, it costs about $550 to get the timing belt and water pump replaced.
Old February 29th, 2012, 11:35 AM   #38 (permalink)
the mathematical
mwaterous's Avatar
This thread is an excellent example of how a $1-200 set of tools can pay for themselves quite quickly. Putting the cost of quality parts and nice tools against a mechanics shop on just the timing belt alone and you're still coming out $100 ahead at the least.
06+, 2.4, 2006, belt, eclipse, kit, mivec, performance, question, rre, rre underdrive pulley, timing
