oil change right now help! - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old February 17th, 2012, 04:25 PM   #1 (permalink)
yes no maybe so
sdrn's Avatar
Vehicle: '11 Eclipse GS Sport
sdrn is just really nicesdrn is just really nicesdrn is just really nice
ok im changing the oil for the first time and im confused i know its supposed to be easy but ok help me out , the directions i got below, questions are in bold, thanks!
This how-to is written simply for reference only. Perform these steps at your own risk and use common sense. The author will not be responsible for any ill-effects (if any) if you make a mistake somewhere during the process.
Tools Needed:
1) 17mm socket or closed-ended wrench
2) oil filter wrench
3) jack and jack stands
4) oil catch-pan
5) shop rags
Steps:
1) Carefully jack up your vehicle on the jack-up point just behind the passenger-side front wheel, under the passenger-side door.
ok done
2) Secure the vehicle on jack-stands, never hold up the vehicle on the hydraulic jack alone.
ok done
3) Remove the oil-filler cap and the engine oil dipstick.
so the car doesnt have to be on right now?? the manual says:
ENGINE OIL REPLACEMENT
M1121001000803
1.Start the engine and allow it to warm up until the temperature of the coolant reaches 80 − 90C (176 − 194F).
WARNING
Use care as oil could be hot.
2.Remove the engine oil filler cap.
3.Remove the drain plug to drain oil.
4) Turn the oil drain plug counter-clockwise using the 17mm wrench.
so turn it just enough so oil comes out, dont remove it all the way??
5) Turn the oil filter counter-clockwise using the oil filter wrench.
6) Let the oil drain thoroughly before reinstalling the oil drain plug and a new oil filter.
7) If you are replacing the oil filter (as recommended), you will need approx. 4.5 quarts of oil. The recommended oil viscosity is 5W-20. If you are not replacing the oil filter, you will need approx 4 quarts.
8) Reinstall the oil filler cap and dipstick.
9) Run the engine for about 5 minutes. Then shut it off and wait for a few minutes before checking the oil level on the dipstick. The oil should be somewhere in between the 2 dots on the dipstick. Also, check the oil filter and drain plug for leaks.
sdrn is offline   Reply With Quote Quick reply to this message
Old February 17th, 2012, 04:33 PM   #2 (permalink)
1SLO4G's Avatar
Vehicle: 2009 Eclipse GS
1SLO4G is on a distinguished road
4) remove the drain plug all the wait out! wait till all of oil is drained.
7) it's over 4qts make sure you have 5qts
9)after pouring oil in car you don't have to run it for 5 mins, 30 sec is fine, shut it off and check level add if needed
hope that helped
2009 GS auto, DC intake, obx header, obx down pipe, GT cat back, openport 2.0 cable, mmcflash, eculfash, and evoscan.
1SLO4G is offline   Reply With Quote Quick reply to this message
Old February 17th, 2012, 05:00 PM   #3 (permalink)
I got this
midnight07GT's Avatar
Vehicle: 2007 eclipse gt
midnight07GT will become famous soon enough
hope that helped
In a gt, put 5 quarts in and don't even bother checking
midnight07GT is offline   Reply With Quote Quick reply to this message
Old February 17th, 2012, 05:06 PM   #4 (permalink)
the mathematical
mwaterous's Avatar
Vehicle: 07/Eclipse/GS
mwaterous is just really nicemwaterous is just really nicemwaterous is just really nice
Your car shouldn't be on, but the oil comes out much easier (and more of it) if it's been warmed up recently. Take the bolt all the way out, and make sure you clean the boss (the area around where you removed the oil filter) before you put the new one on. Stick your finger in the new oil and coat the gasket on your new oil filter before putting it on... only has to be hand tightened, no more.
Our cars hold 4.5qts of oil for an exact fill. Put in 4, turn it on and let it run for a minute, then turn it off and check before adding the last half a quart. Torque on the oil pan bolt is 30ft lbs. Have fun!
Sorry for thread jacking.
mwaterous is offline   Reply With Quote Quick reply to this message
Old February 17th, 2012, 05:07 PM   #5 (permalink)
the mathematical
mwaterous's Avatar
Both engines hold 4.5 qts, and always check... it's not worth over filling it and causing damage.
Old February 17th, 2012, 05:09 PM   #6 (permalink)
Vehicle: 08 Eclipse GT-SC
you get what you need man?
unplug/unscrew the plug/bolt
drain into pan
remove oil filter if you want to do this
fill up new oil filter w/ new oil - screw back on
replace the oil pan bolt/screw - use lock-tight (*optional)
fill up w/ oil - let run - turn off - check again until just right.
easy as it gets, my son.
http://i1134.photobucket.com/albums/...33/joecopy.jpg
joeyb is offline   Reply With Quote Quick reply to this message
Old February 17th, 2012, 05:36 PM   #7 (permalink)
Spyderman2007
Guest
Tournaments Won: 4
Posts: n/a
Old February 17th, 2012, 05:38 PM   #8 (permalink)
yes no maybe so
sdrn's Avatar
dude i bought the mobil 1 filter M1-104
this was the number filter in the book at autozone for me to get
, so i bought the oil filter wrench " B" and i tested it on the mobil one filter, and it fits perfect, but then i get home and the fucking oil filter "B" wrench cap doesnt fit on the stock filter?
what size?? damn it
i drained the oil so far and i put the screw back on it, hand tightened it, good enough?
now the damn oil filter wrench is what i need
Old February 17th, 2012, 05:44 PM   #9 (permalink)
yes no maybe so
sdrn's Avatar
the mobil 1 oil filter M1-104 i got said fits eclipse 2010 GS mines 2011 so does it fit mine also or what? cause the stock filter is not the same size? cause the filter wrench wont fit?
ahh
Old February 17th, 2012, 05:45 PM   #10 (permalink)
Spyderman2007
Guest
Tournaments Won: 4
Posts: n/a
if that dont work use a set of channel locks if you have a set..
Old February 17th, 2012, 05:47 PM   #11 (permalink)
Spyderman2007
Guest
Tournaments Won: 4
Posts: n/a
most makes of filters have different ends on them. but the part that screws in will be the same.
Old February 17th, 2012, 05:48 PM   #12 (permalink)
yes no maybe so
sdrn's Avatar
i dont have and how would that even work the filter is round on the base
copied this image but it looks just like this:
Old February 17th, 2012, 05:57 PM   #13 (permalink)
man - this is a situation where the torque wrench is invaluable. you have a mechanical garentee that it's torqued/tightened just right. If you don't have a torque wrench - get one. You won't regret it. will be the best $30 - $40 you spend on the car - especially if you intend to keep modding.
Old February 17th, 2012, 06:06 PM   #14 (permalink)
the mathematical
mwaterous's Avatar
If you can't get your old filter off by hand, and the oil filter wrench you have isn't working, AND you can't go get one that does...
Punch a screwdriver through the filter and use it like a handle.
Old February 17th, 2012, 06:31 PM   #15 (permalink)
Love My Truck
snakeeyes's Avatar
Name: 370z's are pieces of lateral shit
Vehicle: 2012 nissan frontier v6
snakeeyes is a splendid one to beholdsnakeeyes is a splendid one to beholdsnakeeyes is a splendid one to beholdsnakeeyes is a splendid one to beholdsnakeeyes is a splendid one to beholdsnakeeyes is a splendid one to behold
i remember the first time i changed the oil on this car.the factory put those bitches on TIGHT.i finally had to go get oil filter pliers and tear the bitch half off before it came loose.as far as the mobile oil filter,yes its correct.i know cause thats the one i use
Makes engines run efficient !
snakeeyes is offline   Reply With Quote Quick reply to this message
Old February 17th, 2012, 07:32 PM   #16 (permalink)
yes no maybe so
sdrn's Avatar
thanks for the help.. saddly i couldnt take off the oil filter, i tried everything but im not that strong at all and nothing worked fucking sucks so bad but i wasted half my day with this oil change
i think im going to go to some mechanic and have him drain the oil (mobil 1) i just put in there, take off the filter for me install the new one and then put back the oil and ill top off the oil when i get home, i put just 4 quarts in there
i had to put the oil in there or else i cant drive the car so yea this sucks
and the old oil i took out was completely black disgusting at 3500k
Old February 17th, 2012, 07:48 PM   #17 (permalink)
the mathematical
mwaterous's Avatar
Didn't trust my screwdriver method? It works, you're just punching through aluminum and if it was the stocker probably some cardboard crap on the inside. They're not meant for reuse so you can pretty much do whatever you want to it on the way off.
No big loss, other than to your pocketbook. Swapping the oil out again that quick will actually help "rinse" everything inside and get you a few miles of extremely pristine slippery stuff.
Old February 17th, 2012, 09:16 PM   #18 (permalink)
yes no maybe so
sdrn's Avatar
i read that after i finished everything i might try it tomorrow or the day after but its like hard plastic how am i going to punch a hole in that? with a sharp knife? i will try
Old February 17th, 2012, 09:22 PM   #19 (permalink)
^it will work. if you have to man, remove the oil filter shield on there for more room to work.
Old February 17th, 2012, 10:12 PM   #20 (permalink)
the mathematical
mwaterous's Avatar
ah if you have the time, I'd just drop by autozone/pep/oreilly/walmart/kmart/target/convenience-store/back-alley/bobs-place/napa and get an oil filter wrench that'll grip any size of filter. They sell strap ones in various sizes and "claw" grip style ones, sometimes as cheap as $2. You don't need anything fancy, you'll only be using it once every 3000 miles, and after installing your own, probably not even then.
Old February 18th, 2012, 08:35 AM   #21 (permalink)
I got this
4.5 is low on my dipstick, i do it so often that i know it takes 5 on the dot. Working in a shop kinda helps too.
Old February 18th, 2012, 08:43 AM   #22 (permalink)
mayday295's Avatar
Vehicle: 2008/Eclipse/GT
mayday295 is on a distinguished road
I used my hand to unscrew/screw it in. maybe something to grip it better if you can't do that.
mayday295 is offline   Reply With Quote Quick reply to this message
Old February 18th, 2012, 03:25 PM   #23 (permalink)
yes no maybe so
sdrn's Avatar
seroiusly wtf i totally disected the stock oil filer and it still wont come offfffffffff its like stuck on there and now i dont know wtf im going to do cause i cant drive my car
im gonna post a picture and someone please help me what do i do
already have and tried oil filter wrench WONT COME OFF
Old February 18th, 2012, 03:35 PM   #24 (permalink)
yes no maybe so
sdrn's Avatar
Old February 18th, 2012, 03:38 PM   #25 (permalink)
yes no maybe so
sdrn's Avatar
im about to tow my car to some mechanic and kill myself
Old February 18th, 2012, 03:51 PM   #26 (permalink)
Mdixon23's Avatar
Vehicle: 2008 Eclipse GT Spyder
Mdixon23 is a name known to allMdixon23 is a name known to allMdixon23 is a name known to allMdixon23 is a name known to allMdixon23 is a name known to allMdixon23 is a name known to all
WOW DUDE!!!! Mine was hard to get off and I ended up using channel locks to grab it and get it off. I did dent the hell out of it. I have no clue what to suggest to you at this point because you don't have much to grip onto. Only thing I could think for you to do know is to get a screwdriver in one of the little hole on the top of the filter and at an angle and maybe tap it with a hammer or something. Are you sure you were turning it in the right direction????
DDM 6k HID Headlights and Fogs, Blacked out OE spoiler lip, Teins S-Tech Lowering Springs, Red painted brake calipers
Mdixon23 is offline   Reply With Quote Quick reply to this message
Old February 18th, 2012, 03:54 PM   #27 (permalink)
yes no maybe so
sdrn's Avatar
those fucken holes on there are part of the filter or the car?? yes i was turning the right way ok im a girl and no im not strong i hate myself for trying this shit fucking a
cause if the holes are part of the filter i can try to use that to help remove the rest?
Old February 18th, 2012, 04:01 PM   #28 (permalink)
Mdixon23's Avatar
The holes are part of the filter. Look at the new filter and you can see that the big hole is threaded and that screws onto the car. The gasket seals it onto the car.
Old February 18th, 2012, 04:02 PM   #29 (permalink)
the mathematical
mwaterous's Avatar
I've never seen an oil filter look like that before, I'm not going to lie.
Two things, Mike's on the right track, use a flat head to brace against the edge of one of those holes and tap it with a hammer until it comes loose. The other is you could get two pairs of needle nose pliers and put a pair in either side and torque it out. Those holes are the filter so you can hurt them. Try not to hurt the part in the center.
Sorry you're having trouble with this, the next time will be much easier, I guarantee it!
Old February 18th, 2012, 04:06 PM   #30 (permalink)
Mdixon23's Avatar
Yeah I saw that picture and I was like DAMN!!!! I wish I was close to her and could help her out in person. Of course this is a good way to learn.
Old February 18th, 2012, 04:26 PM   #31 (permalink)
yes no maybe so
sdrn's Avatar
ok well i called my handyman friend to come help hopefully he can do it but damn seriously im scared to ever try this again
Old February 18th, 2012, 04:32 PM   #32 (permalink)
Mdixon23's Avatar
Let us know how it goes. Don't be worried to do it again believe me it won't be as tight. I only tighten mine as tight as I can by hand. I've been doing it that way for years and have never had one fall off or leak.
Old February 18th, 2012, 04:47 PM   #33 (permalink)
Spyderman2007
Guest
Tournaments Won: 4
Posts: n/a
whoa!!!! thats some crazy shit right there!! sorry your having a hell of a time w/ this.. oh and dont kill yourself that wont be good. just sayn. good luck w/ finishing it!
Old February 18th, 2012, 04:59 PM   #34 (permalink)
North 4G Korea dissident
xxxxxxpat_08GT_Spyder's Avatar
xxxxxxpat_08GT_Spyder is a name known to allxxxxxxpat_08GT_Spyder is a name known to allxxxxxxpat_08GT_Spyder is a name known to allxxxxxxpat_08GT_Spyder is a name known to allxxxxxxpat_08GT_Spyder is a name known to allxxxxxxpat_08GT_Spyder is a name known to all
holy jumbo !!!
i never thought a girl could rip out an oil filter like that
just giving you a hard time, but damn, first time i changed mine it came off by hand, not like Superman-hand-power, just average joe twist...
and since then like someone said, i only tighten it back by hand...
get a screwdriver or something in one of these holes and hammer away...
props to you for trying girl, not everyone would do it ! it's just like **** ***, first time is always rough, but after that it's easy-peezy...
xxxxxxpat_08GT_Spyder is offline   Reply With Quote Quick reply to this message
Old February 18th, 2012, 05:01 PM   #35 (permalink)
Love My Truck
snakeeyes's Avatar
as i said,they put those bitches on tight.i would try a flat head screw driver, stick it on the edge of one of the filter holes and try tapping it with a small hammer being very careful counter clockwise.thats some crazy shit,yours must have been on extre tight from the factory.
EDIT; looks like this advice has allready been given.if it was me and this last ditch effort didnt work,then i would have to tap me a couple of bolts in two of those holes,one on each side, making sure the bolts dont go far at all in the filter holes.then use a tool to slide between the two bolts and turn.kinda like a breaker bar
Old February 18th, 2012, 05:19 PM   #36 (permalink)
choppertwo's Avatar
Vehicle: 2014 Mustang
choppertwo has a spectacular aura about
drain into pan
Yea, what he said
choppertwo is offline   Reply With Quote Quick reply to this message
Old February 18th, 2012, 05:23 PM   #37 (permalink)
choppertwo's Avatar
Punch a screwdriver through the filter and use it like a handle.[/QUOTE]
MY GOD, this is what we used to do back in the old days -- CHOP
Old February 18th, 2012, 05:27 PM   #38 (permalink)
choppertwo's Avatar
MY GOD, just take a fucking hammer and hit the screwdriver thru the filter LOL-- CHOP
Old February 18th, 2012, 05:27 PM   #39 (permalink)
too late man, check the pic, she already ripped the filter in half...
Old February 18th, 2012, 05:29 PM   #40 (permalink)
could try one of those "stripped bolts removal" sockets on the center bolt of the filter..
art, coolant, door, engine, filter, manual, oil, oil change, questions, remove, shop, temperature, wheel
