Engine overheating. - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old February 24th, 2012, 01:08 PM   #1 (permalink)
gser7's Avatar
Vehicle: 2008/Eclipse GS
gser7 is a name known to allgser7 is a name known to allgser7 is a name known to allgser7 is a name known to allgser7 is a name known to all
Engine overheating.
Alright, so yesterday I swapped out my Tb to the Gt tb. Now today.. I'm guessing because of many factors. My engine is overheating. One of the coolant lines did leak and threw out a lot of coolant when I was in the process of swapping the two. I did check my coolant can and I didn't have much left in there, so, ended up buying coolant today and putting it in. Now, my question/questions are.. What else could cause the engine to overheat if it is not the case that it was indeed the coolant line that spit out all that coolant in the process. And two... Out of pure ignorance. How long should It take for the coolant to actually cool off the engine. Or man.. I don't even know. Still a noob and always wanting to learn more.
Please and thank you.
Flaming is allowed, if questions are answered!
Operation Black on Black Eclipse.
http://club4g.org/board/members-ride...ter-going.html
CAI, Progress Lowering Springs, RRE UDP, Magnaflow Exhaust, GT TB, RRE Header, Debadged.
RIP Matt (Bullet06) Gone but not forgotten.
gser7 is offline   Reply With Quote Quick reply to this message
Old February 24th, 2012, 01:16 PM   #2 (permalink)
Not Your Friendo
Tsensational's Avatar
Vehicle: 2007/Eclipse/GS(T)
Tsensational is just really niceTsensational is just really niceTsensational is just really niceTsensational is just really nice
Air pockets sometimes cause heating. when replacing coolant, the manual says take off the radiator cap when the car is cold (NEVER WHEN HOT), then idling until your car reaches operating temps. For me it's a little below half. Then rev and hold at 3k or so. Afterwards, refill radiator if needed. This will get rid of the larger pockets. For the smaller pockets, they get dumped into your coolant reservoir eventually.
Your cooling system works by having your coolant run through the radiator to get cooled and passed into your engine. Theres a thermostat somewhere there that opens up when it gets warm.
2007 Eclipse GS-T Auto- 4g63 swap in progress
Tsensational is offline   Reply With Quote Quick reply to this message
Old February 24th, 2012, 01:31 PM   #3 (permalink)
gser7's Avatar
Perfect. Thank you very very very much. Is there anything else perhaps I should look out for? Temperature seems fine now. It wasn't before. It got extremely hot. I'll keep an eye on it and see what comes up. It slowly rises up to half.. I usually am a bit below half. I'm assuming it should be normal because of the leak from the coolant line during the Tb swap.
Old February 24th, 2012, 01:42 PM   #4 (permalink)
Not Your Friendo
As long as your temps don't go past half, you shouldn't be in any danger.
Old February 24th, 2012, 01:44 PM   #5 (permalink)
gser7's Avatar
Thank you! Highly appreciate it!
Old February 24th, 2012, 09:10 PM   #6 (permalink)
Fizzix's Avatar
Vehicle: 09 Solar(Y19) Eclipse GS
Fizzix will become famous soon enough
When you are bleeding the cooling system make sure you turn the heater on FULL. This makes sure there is coolant flow through the heater core also. Let us know how you do...
Fizzix is offline   Reply With Quote Quick reply to this message
Old February 24th, 2012, 09:22 PM   #7 (permalink)
gser7's Avatar
Did that! Thank you for the info! It wasn't running well in the beginning, but after a few miles it got better and now everything is fine! I would zone in the temperature gauge and study it! Haha but everything is good now!
Thank you again!
Old February 24th, 2012, 09:47 PM   #8 (permalink)
Fizzix's Avatar
If you have access to a code scanner that shows live sensor data, you can see the output from the engine block temperature sensor to make sure the engine is in a normal range when you drive it.
Old February 25th, 2012, 12:13 AM   #9 (permalink)
UV Blue Crew
jhun35's Avatar
Vehicle: 2006 Honda Civic Si
jhun35 is a splendid one to beholdjhun35 is a splendid one to beholdjhun35 is a splendid one to beholdjhun35 is a splendid one to beholdjhun35 is a splendid one to beholdjhun35 is a splendid one to beholdjhun35 is a splendid one to behold
I learned something new today. haha. Glad to see you got it straightened out Gabe!!
jhun35 is offline   Reply With Quote Quick reply to this message
Old February 25th, 2012, 01:10 PM   #10 (permalink)
Vehicle: 2006 Lancer Ralliart
CrAnSwIcK is a jewel in the roughCrAnSwIcK is a jewel in the rough
thermostat stuck closed could cause overheating fyi..
CrAnSwIcK is offline   Reply With Quote Quick reply to this message
Old February 25th, 2012, 02:00 PM   #11 (permalink)
gser7's Avatar
Car is working perfect now. Thank you all for the info and help!
Old February 25th, 2012, 02:46 PM   #12 (permalink)
so what was the problem? did i miss something, was it air in the system?
Old February 25th, 2012, 02:51 PM   #13 (permalink)
gser7's Avatar
When swapping the TB's one of the coolant lines leaked out most of the coolant it had on it. No coolant=hot engine I'm guessing. And I had very very little coolant left. So... Bought coolant, followed steps from what they told me on this thread, drove it watching carefully the temp gauge. And voila.. Problem solved. No air leak or air in the system. Everything was tightened. Maybe I missed something, but adding coolant solved it for me !
Old February 27th, 2012, 12:44 AM   #14 (permalink)
oh, lol...
that could have been bad...
coolant, engine, leak, long, question, questions, thank you
