P0603 SES Code - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old June 1st, 2015, 10:55 AM   #1 (permalink)
Vehicle: 2006 Eclipse GS
Crzymoe is on a distinguished road
P0603 SES Code
Good Morning everyone. Last year I purchased a 2006 Eclipse. The SES light was on when I purchased it. I am pretty handy at rebuilding things so I figured I can find out what the light wants, fix it, then make the light go away.
I am getting a P0603 Keep Alive Memory error. I have tried many times to go through the tearstone links but for some reason I error out each time and cannot open it. I understand through other google searches that this happens when your CPU has been altered from stock. My car is totally stock, no fancy turbo or anything. Is there a way to reset the CPU back to stock?
Thanks.
Crzymoe is offline   Reply With Quote Quick reply to this message
Old June 1st, 2015, 08:05 PM   #2 (permalink)
P0603* EEPROM malfunction Page 13A-834
NOTE: Do not replace the engine control module (ECM) or the powertrain control module (PCM)
until a through terminal check reveals there are no short/open circuits.
NOTE: Check that the ECM or the PCM
ground circuit is normal before checking for the cause
of the problem.
NOTE: After the ECM or the PCM
detects a malfunction, a diagnostic trouble code is recorded
the next time the engine is started and the same malfunction is re-detected. However, for items marked with a
"*", the diagnostic trouble code is recorded on the first detection of the malfunction.
Basically your ECM/PCM has a Failure. You may have a bent pin in a connector, an open/short circuit, ground problem, check for other DTC's.
This diagram might help in t-shooting the ecu:
http://www.roadraceengineering.com/4...-ecuwiring.htm
Old June 3rd, 2015, 01:49 AM   #3 (permalink)
GROUP 54C CONTROLLER AREA NETWORK (CAN)
http://tearstone.com/eclipsefsm/2006...002300-54C.pdf
GROUP 54B SIMPLIFIED WIRING SYSTEM (SWS)
http://tearstone.com/eclipsefsm/2006...002200-54B.pdf
GROUP 80A CONFIGURATION DIAGRAMS
http://tearstone.com/eclipsefsm/2006...000200-80A.pdf
GROUP 54A CHASSIS ELECTRICAL
http://tearstone.com/eclipsefsm/2006...002100-54A.pdf
GROUP 80B SPLICE LOCATIONS
http://tearstone.com/eclipsefsm/2006...000300-80B.pdf
GROUP 90 CIRCUIT DIAGRAMS
http://tearstone.com/eclipsefsm/2006...0000400-90.pdf
Old June 3rd, 2015, 01:56 AM   #4 (permalink)
Thanks.
In the 13A group there is a broken link, there are five-books in the 13A Group, so you can only read the first book. The work around for this is to down-load the Factory Service Manual to your computer (look at the top of the site for the download). Once you un-zip the files to a location, you can go there and open any fill. The 13A file you are looking for is the forth file out of five.
Old June 4th, 2015, 08:28 AM   #5 (permalink)
Awesome. Thanks for the info. I'll sniff around on this during the weekend.
06 eclipse, 2006, 2006 eclipse, back, car, code, eclipse, fix, good, light, links, reset, ses light, stock, stock., turbo
Code u1108 Flaboy806 Problem Reports 1 March 7th, 2015 08:10 AM
Po 404 code AzRain 4G Eclipse GS/SE Specific 4 October 15th, 2014 12:55 PM
ses light after repairs calitin Problem Reports 11 September 4th, 2014 07:20 AM
Shake After 60 miles plus and error code p0031 makatc Problem Reports 1 June 30th, 2014 06:03 PM
P0057 SES troubleshooting warning Problem Reports 1 July 14th, 2011 02:45 AM
