I have a question Car won't start after transmission work - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old January 10th, 2017, 08:05 PM   #1 (permalink)
towhitch is on a distinguished road
My girlfriend has a 2006 gt and her clutch petal was going to the floor with no resistance. Determined the concentric slave cylinder and master cylinder needed replaced. Replaced them myself and now have pressure back in the clutch pedal. Now is my new problem of the car not starting.
When I turn the key nothing happens. I get power to the dash and my battery seems fine even though it did measure only 10.5v. Even still I tried to jump start it and was still getting the same problem. The starter was getting about 9.5v but it didn't seem like it was transfering the power when the ignition switch was turned on. Using a screwdriver I got the starter to spin by jumping the solenoid. Is the starter bad? If so how did it get bad between the time I took it out and put it back in? (It was out for a few weeks).
Another thing I found that may or may not be having an issue is the wire I found that bypassed some burnt up switch that I think controls the radiator fans.
In the image you can see the burnt up spot is where the black fuse box thing went. It had been replaced before I bought the car with that wire and a 25 amp fuse. I can't remember which prongs these plugged into or if they are even cause a problem. I know I need to get that hooked up to but not sure if I can find an appropriate wiring diagram or someone on here knows a thing or two about that. Thanks for your help and let me know if I have left something out.
towhitch is offline   Reply With Quote Quick reply to this message
Old January 10th, 2017, 08:22 PM   #2 (permalink)
wingo171's Avatar
Vehicle: 08 GT SE and 91 3kgt VR4
wingo171 is a jewel in the roughwingo171 is a jewel in the rough
Check the clutch pedal switches in the floor. If the pintle is not moving when you push the clutch pedal it will not crank the motor over as it thinks you didn't push in the clutch. (If the top one is messed up, you can unplug it and it should let you crank (if that is what the issue is down there in the floor).
The burnt wire thing is a WTF did the previous owner do, kind of thing.
Tearstone has the full service manual to download.
Link to FSM
wingo171 is offline   Reply With Quote Quick reply to this message
Old January 11th, 2017, 04:05 AM   #3 (permalink)
It very much is a WTF moment. That switch was also tested and seems to be working properly. Plugged up or not it won't start.
Old January 11th, 2017, 03:47 PM   #4 (permalink)
Got the car started. Didnt have a plug plugged up all the way. Now I am not getting any throttle response.
06 gt, 2006, art, back, bad, battery, black, box, car, clutch, dash, fuse, ignition, issue, pedal, power, problem, radiator, starter, starting, switch, transmission, wire, wiring, work
Car won't start. jmflo571 Problem Reports 5 August 26th, 2016 10:46 PM
Car wont start. No compression after oil change! Porcupinepuffer 2006-2012 Eclipse (General 4G) 6 January 23rd, 2016 07:12 AM
Crank but wont start!!! After ECU remove. adrianglez305 Tuning and Electronics 4 November 13th, 2015 12:11 PM
Car won't start..? CuTi08 Problem Reports 26 August 12th, 2015 06:29 PM
Help my car wont start Jh3rnandez 2006-2012 Eclipse (General 4G) 2 March 3rd, 2015 02:30 AM
