6-Speed Transmission Install Help - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old March 17th, 2017, 08:25 AM   #1 (permalink)
Codyw734's Avatar
Vehicle: 2006/Eclipse/GT
Codyw734 is on a distinguished road
First of all I wanna say hi to all you 4G owners, I became a proud owner last year and instantly fell in love with mine. I had to replace the clutch, flywheel and throw out bearing recently, but when I jacked the trawnsmission back up into the engine cavity it didn't go so smoothly, I had to turn it one way to get it over the sub-frame but the U-Shaped top that goes between the thermostat housing got caught, and when I tried the other way it wouldn't go over the sub-frame.. so my question is, to everyone that's had to remove there tranny's and reinstall them, do you have to take the sub-frame out to get it back in? Or is there a special trick for getting into place? I'm so confused it was so easy to get out
Codyw734 is offline   Reply With Quote Quick reply to this message
Old March 17th, 2017, 09:55 AM   #2 (permalink)
0 - 60 Eventually
Desert Rat's Avatar
Vehicle: 06 GT Manual
Major props to you for doing your own install... I don't trust myself enough to do that. That said, I have absolutely no idea, and most of our active members drive auto like the schmucks they are Welcome to the club regardless, Cody! Hopefully someone can help.
Desert Rat is offline   Reply With Quote Quick reply to this message
Old March 17th, 2017, 02:53 PM   #3 (permalink)
No Worries
tcsoccer09's Avatar
Vehicle: 2009 Eclipse GS Auto
Wttc Cody! Sorry - Im'ma schmuck and can't help
Old March 19th, 2017, 07:30 PM   #4 (permalink)
Codyw734's Avatar
It's all good now I did had to take the sub-frame out with all the scary steering parts, but got the tranny back in place with slightly more ease! (Our cars can be a real b#$ch to work on lol) thanks for the support even though you guys didn't know either ?.
Old March 19th, 2017, 07:31 PM   #5 (permalink)
Codyw734's Avatar
*Have to
Old March 23rd, 2017, 02:42 PM   #6 (permalink)
Vehicle: 07 Eclipse GT 6speed
skysky has a spectacular aura about
Wish I would have seen this earlier. I did the LSD and clutch install on my car. I DID NOT have to remove the subframe. Granted it was a bitch to do in a tight garage on lifts (never doing transmission stuff again without access to a lift), but i contorted it back into place. With the transmission out, the engine should hang in the engine bay by the engine mount on the passenger strut and by a cherry picker/hanger holding the block hooks. My clearance issue was the transmission not having room to slide up in front of and back above the subframe center without binding on the flywheel side of the engine and subframe. I had to angle the flywheel side of the engine down I think and rock the engine forward significantly. Partially attach the transmission and jack them up in place together. Then I was able to get the transmission back up over the subframe. That 4" you save when you slip the bellhousing over the clutch/FW is a precious 4" for getting the pieces back in.
I'm pretty sure I had to do the same to get it out also, like 95% sure, as when I slipped the transmission OFF and OUTWARD from the clutch/FW I no longer had room to drop it out of the subframe. It took patience and some large scale tetris but the transmission does go in and out, you just have to move the engine around first to make space.
***Important Note: Don't squish the pulleys on the passenger side of the engine when your pivot it on the mount***
Injen intake, RRE short tube headers, Injen exhaust, Outlaw Engineering spacers, Quaife LSD, CM fx350 with steel FW, ViS CF OEM hood, XXR 527 wheels, Conti. Extr. Cont. DW 245/45/18 tires, Progress sway bar, Energy Suspension motor mounts and suspension bushings, RRE shifter bushings, Tanabe strut brace, MR coilovers, AEM FIC.
skysky is offline   Reply With Quote Quick reply to this message
Old March 26th, 2017, 11:49 PM   #7 (permalink)
Codyw734's Avatar
Oh darn lol I just angled the engine down ward to better fit the tranny back perfectly center, my patience may have run thin but now I'm paying for it, hooking the steering back into place and center was a whole other beast of a challenge, but finally everything is back together now waiting for the 75w 80 gl-3 gear oil to arrive, no parts store seems to carry that in my area but I'm willing to wait a few days to drive my baby again,. Also I wish I had that post sooner lol but definitely good to know I don't have to remove the sub-frame if I ever have to do this again, Thank you sir!
Six Speed Manual Transmission Rebuild Issue Timmy42 Problem Reports 4 April 10th, 2016 06:33 PM
Does anyone know where i can find a 5 speed transmission for my 07 Eclipse SE. please thedalehayes New England 1 March 23rd, 2016 10:47 AM
Checking Transmission Fluid? Silence_ 2006-2012 Eclipse (General 4G) 3 September 10th, 2015 04:07 PM
Ghetto Upper Tranmission mount install. inherheart Problem Reports 1 August 7th, 2015 12:59 AM
Sparco Hood Pins install guide Dead Capricorn Interior and Exterior Modifications (Show) 6 July 2nd, 2015 11:09 AM
