Engine build done!
RRE headers ceramic coated
Delta Cam regrind cams
Custom Cometic head gasket
ARP 2000 main/head/rod bolts
Quainfe LSD
880cc injectors
RRE carbon fiber engine cover
K&N custom short ram intake
Optima battery
Powdercoating: Everything!
From the beginning:
See less See more
3
#29 ·
Well boys it's starts! Just dropped off the block and crank to be acid cleaned, pistons and rods are shipped, headers in the mail, I'll he ordering all arp head and main studs in a half hour. Later one I'll be ordering gaskets and bearings online...get those in and ship headers bearings and pistons to jet-hot. Slap it all together. Same guy will be doing my heads when I order delta springs and retainers. still not sure about cams....I guess we can do that later once we see results!
Stay Tuned!
#34 ·
Outstanding progress from something that went bad, keep it up. I'm excited to see what you are gonna push when you have everything finished but honestly when are we ever finished lol
Edit: quick question so BC never gonna make rods again?! That really #$5^ing blows, do you know of anyone else that makes them for this car, eagle maybe?
#45 ·
Damn a brand new MR for 28k? That is a deal..... and who can pass on a free iPad. My dealership is about to get bought out too, maybe they will have a similar deal going on
#51 ·
I love these things but they're such a pain in the shit to install on some cars...
Nice though...did you have to have ARP do a custom kit for you or does someone assemble one?
#54 ·
MRs are manual with an electronic dual-plate clutch engagement that's faster than you could ever shift. And the X GSR's 5-speed is still better than the 6/sp in the Eclipse GT in terms of gearing and engagement.
And what does a transmission have to do with a motor? The 4B11T is capable of handling a LOT of punishment for an aluminum block motor. Plus, for being matched with a puny 5-speed transmission, the gearset on that 5/MT has better teeth and guts than previous Evos. Not to mention the transfer case.
Again, I wouldn't throw blind assumptions out there just because you have more displacement and an extra gear. You may put out more power than an Evo at the crank with an engine build, but the X will hand you your ass for less power, off the line or on a road course, and build up for much lesser cost than you would spend, apples to apples.
#55 · (Edited)
I was saying who wants to buy my 4g motor so I can buy a evo. I don't consider a clutchless manual a manual. I know it's fast shifting. It's one of the fastest trans in the world. I just rather have a clutch. When driving a GSR you're in 5th before you know it and it feels like it's done, I know it's not buy still. It just didn't Live up to it's hype. I like the eclipse. I haven't drove a mr, but from what im told you can just buy the ralliart which has the trans and the only difference are the intercooler, brakes and suspension....all stuff that can be bought aftermarket for the 10G price diff.
Im not going to do it anyways. I'm in too deep with this car. Too Many evos out there. It's easy/common to see a build Evo, I want to show people something different for once.
Maybe this time I won't have any "mishaps"
