Engine build done!
RRE headers ceramic coated
Delta Cam regrind cams
Custom Cometic head gasket
ARP 2000 main/head/rod bolts
Quainfe LSD
880cc injectors
RRE carbon fiber engine cover
K&N custom short ram intake
Optima battery
Powdercoating: Everything!
From the beginning:
Quainfe LSD
880cc injectors
Optima battery
From the beginning:
