Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority - View Single Post - Cut springs
Thread: Cut springs
Old April 17th, 2012, 01:53 PM   #7 (permalink)
snakeeyes
Drives fast
snakeeyes's Avatar
Name: Good will always triumph over evil.you can believe that !
Vehicle: 09 370z intimidator
if you can get them to seat right(which i doubt),then it would work but it is in no way safe.what happens if you dont do it right and you're going down the interstate,hit a bump and the spring or springs decides to jump out ? not a good scenerio.good luck !
Makes engines run efficient !
