Go Back   Mitsubishi Eclipse Forums > Performance and Technical > Audio & Lighting
Old July 2nd, 2009, 10:42 PM   #1 (permalink)
XxkevinchuxX's Avatar
Vehicle: 2007/eclipse/SE
XxkevinchuxX has a reputation beyond reputeXxkevinchuxX has a reputation beyond reputeXxkevinchuxX has a reputation beyond reputeXxkevinchuxX has a reputation beyond reputeXxkevinchuxX has a reputation beyond reputeXxkevinchuxX has a reputation beyond reputeXxkevinchuxX has a reputation beyond reputeXxkevinchuxX has a reputation beyond reputeXxkevinchuxX has a reputation beyond reputeXxkevinchuxX has a reputation beyond reputeXxkevinchuxX has a reputation beyond repute
relay/HID
so i was told this would most likely solve my problems...anyone have a diagram of could tell me how to do this?
白人看不懂
XxkevinchuxX is offline   Reply With Quote
Club4G Sponsors
Old July 2nd, 2009, 11:39 PM   #2 (permalink)
Project XK
xpandabl3's Avatar
Vehicle: 07 Eclipse GT-P
xpandabl3 has a brilliant futurexpandabl3 has a brilliant futurexpandabl3 has a brilliant futurexpandabl3 has a brilliant futurexpandabl3 has a brilliant futurexpandabl3 has a brilliant futurexpandabl3 has a brilliant futurexpandabl3 has a brilliant futurexpandabl3 has a brilliant futurexpandabl3 has a brilliant futurexpandabl3 has a brilliant future
I honestly doubt relay will solve your problem as it's more of a protection for your stock harness not for your HID bulbs. You can give it a shot anyway. I would say your problem is your ballasts. Have you tried switching to another ballast? since you have tried new set of bulbs, checked all the wires according to your another thread, it's only ballast left. Does your ballast have external ignitor?
A relay kit is relatively easy to install you just have to find places to route and the wires and secure them. I can show you how I routed mine if you don't want to figure it out yourself.
http://media.photobucket.com/image/H...006Labeled.jpg
Props to many friends for the project! Wouldn't have happened without any of you
My Seller Feedback: http://club4g.org/board/good-guys-ba...bl3-rocks.html
xpandabl3 is offline   Reply With Quote
Old July 2nd, 2009, 11:44 PM   #3 (permalink)
well i talked to juz10xD and searched about 4 forums on the issue and all have said relay..justin did this and it solved his problem...but yea if you could tell me how yours is done that be great.
白人看不懂
Old July 2nd, 2009, 11:48 PM   #4 (permalink)
Project XK
xpandabl3's Avatar
Well like I said you can give it a shot and it's better to have a relay if your car doesn't come with HID so it's win either way. I'll go take some pictures in a bit just check back later.
Old July 3rd, 2009, 12:35 AM   #5 (permalink)
Project XK
xpandabl3's Avatar
The pictures are not the greatest since it's tough to actually see what's going on.
Old July 3rd, 2009, 06:14 PM   #6 (permalink)
Sully's Detailing
FLGTeclipse's Avatar
Vehicle: 2008 Raider
FLGTeclipse is a splendid one to beholdFLGTeclipse is a splendid one to beholdFLGTeclipse is a splendid one to beholdFLGTeclipse is a splendid one to beholdFLGTeclipse is a splendid one to beholdFLGTeclipse is a splendid one to behold
What is your problem? If your lights are flickering when the lights are on then a relay kit will solve the problem. If they are flicking when you turn them off then you have to disable the DRL or leave the lights on.
FLGTeclipse is offline   Reply With Quote
Old July 3rd, 2009, 06:53 PM   #7 (permalink)
Hates carbon fiber
JUZ10xD's Avatar
Vehicle: 07 Satin Mesai GT
JUZ10xD has a brilliant futureJUZ10xD has a brilliant futureJUZ10xD has a brilliant futureJUZ10xD has a brilliant futureJUZ10xD has a brilliant futureJUZ10xD has a brilliant futureJUZ10xD has a brilliant futureJUZ10xD has a brilliant futureJUZ10xD has a brilliant futureJUZ10xD has a brilliant futureJUZ10xD has a brilliant future
will post again in 14 minutes.
Express, not impress.
JUZ10xD is offline   Reply With Quote
Old July 3rd, 2009, 07:22 PM   #8 (permalink)
Hates carbon fiber
JUZ10xD's Avatar
k kinda late, got caught up in some things. heres a diagram i drew in paint.
LEGEND:
Green wiring is for the magnetic (switch/control) portion of the relay
Light blue is for the HID Circuit
Red is positive
Black is negative
for the headlamp low beam wire, use the positive wire that would power up the bulb on the stock harness.
i use the frame for ground, so i just attach a ring terminal to the wire and drill a hole and put in a tapping screw to hold it in place after stripping off a little paint to ensure a proper connection. then i apply a little grease so it doesnt corrode.
for the wiring going to the battery, use thicker gauge since your hid's will draw more amperage so run a wire from the relay to the battery terminal, and then use the same size wire to run from the relay to the connector on the ballast.
You will need an SPDT relay, i'd get these because they come with the harness and you dont have to crimp new spade terminals on the wiring. and it makes it easier to plug and unplug.
10 PACK 30/40 AMP RELAY HARNESS SPDT 12V BOSCH STYLE S - eBay (item 400038450805 end time Jul-18-09 10:47:43 PDT)
keep in mind that you need to make 2 of these for left and right.
of course this is making your own harness kit. u can buy these kits premade like expandables.
Old July 3rd, 2009, 11:29 PM   #9 (permalink)
yea they flicker when on...i had the DRL problem at first but then i disabled them and pow worked like a charm....i'll try the relay in a few weeks seeing as i will be in china for awhile....anyway thanks a million guys
白人看不懂
Old July 3rd, 2009, 11:42 PM   #10 (permalink)
PearlClipse :)
ALBOE's Avatar
Vehicle: Eclipse GT
ALBOE has much to be proud ofALBOE has much to be proud ofALBOE has much to be proud ofALBOE has much to be proud ofALBOE has much to be proud ofALBOE has much to be proud ofALBOE has much to be proud ofALBOE has much to be proud ofALBOE has much to be proud of
LEGEND:
Red is positive
Black is negative
you have good pbrush skill!
Old July 4th, 2009, 11:22 AM   #11 (permalink)
Hates carbon fiber
JUZ10xD's Avatar
lol i tried to keep it clean
Old July 4th, 2009, 11:58 AM   #12 (permalink)
Go Slow or Go Home
rbk001's Avatar
Tournaments Won: 8
Vehicle: 2007 Eclipse GS
rbk001 has a reputation beyond reputerbk001 has a reputation beyond reputerbk001 has a reputation beyond reputerbk001 has a reputation beyond reputerbk001 has a reputation beyond reputerbk001 has a reputation beyond reputerbk001 has a reputation beyond reputerbk001 has a reputation beyond reputerbk001 has a reputation beyond reputerbk001 has a reputation beyond reputerbk001 has a reputation beyond repute
My HID's were flickering for awhile, ended up replacing the balasts and thats solved the problem.
*RRE Short Tube Header*RRE Underdrive Pulley*Fujita CAI*Magnaflow Catback Exhaust*Outlaw Throttlebody and Intake Spacers*E4E Front Lip*E4E Blacked Out Tails*CF Spoiler Delete* Progress Rear Sway Bar*Progress Lowering Springs*Tanabe Front Strut Bar*Powerslot Rotors*Painted Calipers*Black Halo Projectors*8k HID's*Drifz 18" Venom Gunmetal*JVC 7" Touchscreen DD*Kenwood Speakers*
rbk001 is offline   Reply With Quote
Old July 5th, 2009, 10:52 PM   #13 (permalink)
Sully's Detailing
That could be 2 reasons
1. You have cheap HIDs
2. You need a relay kit because the HID kit wasnt getting enough power
Old July 9th, 2009, 08:01 PM   #14 (permalink)
Hates carbon fiber
JUZ10xD's Avatar
^^^told ya kev lol
Old July 9th, 2009, 08:36 PM   #15 (permalink)
Sully's Detailing
It sounds like you have cheapo HID's if so You can get a pair of my HID's or Bi-Xenon
Old July 21st, 2009, 04:28 AM   #16 (permalink)
alright guys just got back from china and ready to do this...i was looking on ebay...and is this what it need?
HID RELAY FOR McCULLOCH HID KITS H1 H3 H4 H7 H8 H9 H10:eBay Motors (item 320390109407 end time Jul-26-09 18:56:36 PDT)
白人看不懂
Club4G Sponsors
