Go Back   Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006+ Eclipse Authority > Performance and Technical > Audio & Lighting
Old February 5th, 2010, 01:18 PM   #1 (permalink)
Vehicle: 2008/eclipse/GT
ROOSE is on a distinguished road
HOW TO air vent LED install
I installed these Blue leds that i got from autozone $14.99 a pair in my dash i attempted installing them in the side vents i got one side was quite complicated and decided it wasnt worth doing the other side so i moved them to the doors
First I took the counsel apart (if u need help with this ask)
then i took a drill n drilled just a big enough hole for the wire to fit though as far back as i could get the drill
I have a auto 08 gt so i wired the leds to the lights that light up the P R N D the white and the red wires, dont mind the wires to the right there also hooked up to the P R N D lights one is a led that shows threw the ebrake gap and one lights up water bottles
then tested the lights b4 i adhesived them in place
then adhesive them into place and tested once again. I shoulda put them a lil further back but was hard 2 get my hands in to the vents then put everything back together wait till its dark and test them out
I think they look pretty good but if your at eye level you can see the leds threw the vents but most ppl dont stare into the vents so its all good
if u need help with ne thing just ask will be glad to help
the leds are not switch actavated they come on when i turn my lights because i have my DRLs disabled when my headlights are on at night all the leds in my car are because there wired threw existing lights
ROOSE is offline   Reply With Quote
Club4G Sponsors
Old February 5th, 2010, 06:43 PM   #2 (permalink)
Vehicle: 2008 eclipse spyder gs
sk13322 has a spectacular aura about
good wright up im not to sure bout the wiring not saying u did anythiong wrong i just hate messing with 4g wireing lol e rep
sk13322 is offline   Reply With Quote
Old February 6th, 2010, 08:53 AM   #3 (permalink)
ha ya my pic aint that good lol u just drop wires threw the holes u drilled in the vents straight down to the PRND set up adn theres to wires red and white u cat really miss em there like the only ones tehre but i have more than one set of lights running of them so my cluttered wiring makes it a lil hard to see
Old February 8th, 2010, 09:55 PM   #4 (permalink)
People suck...
Cheez's Avatar
Vehicle: 07 Kalapana GS
Cheez will become famous soon enough
I've got the same thing in mine, except mine are 4 inch blue cathodes. I've got them under my dash and in the air vents. I like how you wired them to the gear shift lights, my only complaint with that is you can't turn them off. I've got mine wired to a seperate switch. I only say this b/c I put some 12" sound reactive ones in my friends truck and he got pulled over for them.
Cheez is offline   Reply With Quote
Old February 8th, 2010, 10:17 PM   #5 (permalink)
ya lol ill wire them to a switch eventually
Old February 8th, 2010, 10:20 PM   #6 (permalink)
People suck...
Cheez's Avatar
Cool man but nice job in the end looks really clean...and exactly like my car, except my hu is sharpied
Old February 9th, 2010, 07:34 AM   #7 (permalink)
i dont get it when u guys say u sharpie stuff so ur saying u took a sharpie like a marker? to ur head unit? and if u did dont it rub off on somthing plastic like taht?
Old February 9th, 2010, 07:11 PM   #8 (permalink)
People suck...
Cheez's Avatar
Yea it's literally a sharpie marker, and no it doesn't rub off at all
led how to lights
Club4G Sponsors
Copyright ©2007 - 2010, Club4G.org
