| Audio & Lighting Head units, subs, amps, caps, neon lighting, LEDs, and anything else that uses a DC power source not tuning related goes here. |
All Black Everything
Jason
2008 Eclipse GT
How To: Install Load Resistors to LED Tail Lights (To get rid off TCL OFF light)
There have been many reports that after installing new LED Tail Lights that the driver may see a TCL OFF light appear on their dashboard. This is your Traction Control, basically what helps you when pulling off in rain/snow. Some drivers have also mentioned that when this light is on, their cruise control shuts off.
Usually the light only appears after around 10 minutes of driving. When you shut your car off & restart, the light does not appear, but will re-appear once you start driving again. (If your light constantly stays on no matter what, I would suggest having it checked it by the dealership or someone familiar with Mitsubishi cars.) The reason this light is appearing is due to the way Mitsubishi cars are wired. Everything is integrated with each other. So when the car’s computer notices that the brake lights are not getting enough power, it ends up activating this light. What you need to do is hook up a load resistor to each tail light. This will basically “fool” the computer to think that it is getting the same amount of power that the stock tail light’s received. ______________________________________ For installation remove your tail lights from the car, but do no disconnect the wires or anything. You just need to have access to the wires. You will need to have 2 Load Resistors. I picked mine up from a local Auto Zone. 2 of them came in one package as seen below. You will need to use the dual-splice connectors that come with it (if they don’t come with it, don’t worry, it’s really cheap) & connect the resistor to the brake wire & ground wire. • Brake wire is the red wire coming from the tail light. • Ground wire is the black wire coming from the tail light. • Green wire goes to the lights that come on when you turn on your headlights. In each of the dual splices will be the black wire that comes from the resistor & wires mentioned above. There is a metal piece in the middle of the splicers. They must be really pushed in with a set of pliers in order to cut into the wire and actually splice. You will need to position this as close to the tail light as you can (in terms of how far you go up the wire), but leaving room so that you can position the resistor in a way that wont touch anything else. THE RESISTOR DOES GET WARM/HOT! So use whatever method you can to secure the resistor without touching anything plastic or any wires. (I personally used some zip ties to secure the wires back and let the resistor hang in the air by itself.) That’s all there is to it! ![]() ![]() ![]() ![]()
Motegi Racing MR118 Rims / Fujita CAI / 35% Tint / Halo Projector Headlights / Projector Eyelids / DRL Delete / Black LED Tail Lights / Interior LEDs / Sony Head Unit / 12" MTX Subs / MTX Terminator Amp / Debadged / Upper + Lower Grillcraft Grill / Progress Rear Sway Bar / RRE Magnaflow Axle-Back / Painted Calipers / Momo Shift Knob / Custom Seat Covers Last edited by JDub; October 15th, 2011 at 04:04 PM. Reason: How To: Install Load Resistors to LED Tail Lights (To get rid of TCL OFF light) |
4G Zombie Killa
![]() Tournaments Won: 103 Name:
Jay to the F'N Rod
Black Spyder GT
Got Camber? 10.5+15 of IT
Fuzzy Wuzzy Umpkin
2006 Eclipse GT
this is the kind of stuff we need on the site. good write up Jason
MY AUTOMOTIVE PHOTOGRAPHY SITE - STREET | MANOR Check Out The Official Kazman Thread!!! |
Jason
2008 Eclipse GT
Thx
![]() I actually just realized a bunch of typos I made lol. I'll fix it later when I'm at a computer (on my phone now). Wrote all that & made the graphic while working on a bunch of other things at the job earlier lol.
Motegi Racing MR118 Rims / Fujita CAI / 35% Tint / Halo Projector Headlights / Projector Eyelids / DRL Delete / Black LED Tail Lights / Interior LEDs / Sony Head Unit / 12" MTX Subs / MTX Terminator Amp / Debadged / Upper + Lower Grillcraft Grill / Progress Rear Sway Bar / RRE Magnaflow Axle-Back / Painted Calipers / Momo Shift Knob / Custom Seat Covers |
Preston
2007/Eclipse/GT
Thanks for the awesome write up. That was actually one of the reasons I haven't gotten the aftermarket tail lights yet. Has this fixed your problem 100%?
**5AT** AEM SRI // HKS 3" Headerback Exhaust // Ingalls Stiffy // KYB Shocks // Eibach Prokit // Eibach Rear Sway Bar // Centric Rotors & Ceramic Pads // D-Speed Rear Bumper // Projector Headlights With CCFL Halos // 3k Fogs // 15mm Ichiba Spacers // SE Lip |
#6 (permalink) | |
Jason
2008 Eclipse GT
Yea, I have had these in for a week now & the light has not appeared. Everything works like normal. Quick $10 fix.
Rob
2009/Eclipse/GS
I do not have traction control but my 3rd brake light is constantly on, I'm gonna try this and see if it fixes the problem. Nice write up!
Boobies: Because you can't motorboat personality |
The thread killer...
Jeff
07 GT
my cruise control stoped working after installing LED tails... With this mod it works again... nice write up!
I got Mods. Last edited by Freeker; December 20th, 2010 at 01:58 AM. |
06 Eclipse GT
These cost $10 for 2?
06 Eclipse GT
I suppose that's not too bad considering they are packaged for this application...
If anyone wonders though you can get the resistors for just over $1 a piece...less if you buy 25 or more...
Jeff
07 GT
meh bargain shopping for items less than $10 isn't worth my time... it was walk in, grab what I needed, and off i go... done
I got Mods. |
06 Eclipse GT
True true...just thought I'd let you all know just cause I had the info!
Eclipse MR
![]() Tournaments Won: 12 Join Date: Jul 2007
Corvette C6.R, SRT4 ACR
Good info!
LS2: Longtube headers + cat less x-pipe + Ram air intake + ported intake manifold and Throttle body = 395whp and 380ftlb tq. Next up: Comp cam, Yella Terra rocker arms... Hello 450whp!!!!
Jason
2008 Eclipse GT
Glad to hear that it's working for everyone else as well. You can really thank Joe over at Auto City Imports, lol, he gave me the idea because he heard of a similar issue on the Lancers. I guess I was just the test dummy to see if it would work on our cars as well, lol.
Lathe Master
05 Lancer Evolution
Anybody know the resistance value of these guys? Should be labeled on them somewhere with an omega.
06 Eclipse GT
Those are 6.2 or 8.2 ohms at 25 watts...
Lathe Master
05 Lancer Evolution
Thanks I might as well give this a shot while its down for the winter......
#21 (permalink) |
FDLFDH
Craig
06/GT/AT
I just did this today, and I have a few comments.
I found everything at radioshack. I used a 20w 8 ohm resistor. I searched for days and couldn't find a kit. Every auto parts store thought I was crazy hahaha. They acted like I was looking for a bag of wizardry. So I wired my everything to your diagram, and I discovered that you have your wired crossed. The solid green wire is supposed to go to the green/silver wire, and the red wire is supposed to the green/yellow wire. everything else was correct. Has no one else tried this?
#22 (permalink) | |
![]() Join Date: Jul 2008
06 Gt 6spd
i shall try this both my traction and stability light come on
Est.430+whp Nitrous-150shot. Aiming for 350+WHP N/A |
#23 (permalink) |
DILLIGAF?
David
2006 Eclipse GT
I just found the exact same ones pictures in the OP at Autozone. The people there weren't sure but they pointed me to the electrical aisle. I found them because of this post with that picture. Then they wanted to know what it was for and I gave a shout out to club4g.org. Thanks JDub!!! This website is awesome!!! I would have never known there was an issue with these tail lights if it weren't for this thread and how to fix it.
#24 (permalink) |
Jason
2008 Eclipse GT
^^ Glad to be of help
![]() ...and to those who are wondering, I have had these on my car for almost a year now, no issues at all. So the resistors definitely work. If your TCL light happens to come on again, it may have to do with another problem. (For example, I just installed a new double-din last week, and I hooked up 1 wire wrong, and BAM.... TCL light was on after that. The damn ECU system in our cars are very sensitive.)
#27 (permalink) |
DILLIGAF?
David
2006 Eclipse GT
So I did this while doing my install and the cruise control still doesn't work and the TCL and swerve symbol are on. WTF??? I've never used those types of splicers so maybe I didn't do it right. Will check it out tomorrow when it's daylight. And I thought I was smart for doing this during the initial install. Grrrrrrr.
Sent from my iPod touch using Tapatalk
#28 (permalink) |
DILLIGAF?
David
2006 Eclipse GT
Ok so I fixed the problem. There is a metal piece in the middle of the splicers. They must be really pushed in with a set of pliers in order to cut into the wire and actually splice. I just pushed them together at first with my fingers until the clicked into place. JDub will you add this to the OP for people like me that don't know anything about electricity and splicing. After reconnecting the car battery everything was back to normal. Cruise control and all worked again!!!
#29 (permalink) |
Jason
2008 Eclipse GT
Yea sure, I will add that. Although, I could have sworn it said that in the instructions of the resistor pack, hehe
#30 (permalink) |
DILLIGAF?
David
2006 Eclipse GT
I didn't read those instructions. I just read yours and went to work installing. the box is already thrown away so I can't even check. Oh well, my bad.
#35 (permalink) |
Pete
2007/Eclipse/Spyder/GS
So I followed the instructions just the way you guys posted and...THEY WORKED!
Got my Cruise Control back and my right parking lights back! Thanks Club4g!
#36 (permalink) | |
Pete
![]() ![]() ![]() I made a heat-shield-sushi with some insulator material I was using for my hood.
#37 (permalink) |
2006/Eclipse/GT
Anyone have a problem where the car runs like complete crap after installing the resistor?
I installed the same resister from autozone as originally posted. After completed install cruise and TCL all work fine now but now the car revs real high and has no power whats so ever. I take resister off the car runs fine. but TCL and cruise do not work. I do have the wires tapped in correctly Red/Black on resistor. Ugh! |
#38 (permalink) | |
Pete
#39 (permalink) |
2006/Eclipse/GT
yea I know its not just a mod feel.
The RPM guage revs up to 5-6K and the car moves like a snail I timed 45-50 seconds to get up to 60 MPH. It feels almost like being in 6th gear when you should be in 1st taking off. Literally have to be pedal to the medal to even *crawl* up to 60-70. |
| air, art, auto, back, black, brake, car, cars, cruise, driver, drivers, dual, headlights, how to, install, installation, led, lights, metal, mitsubishi, power, remove, stock, tail lights |
