REMOTE amp wire connection/location and question on speakers. - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old January 28th, 2012, 06:05 PM   #1 (permalink)
Vehicle: 2009 eclipse gs
leviathann666 is on a distinguished road
Red face REMOTE amp wire connection/location and question on speakers.
I searched and saw a few posts on possible locations to connect the blue remote amp wire. Don't want to be repetitive but after all your experience where is the best location to connect the wire? headunit? Fuse? I really want to finish this tonight so please help! I have the non RF headunit.
If connected to headunit, which wire do I splice into? Color?
If using the fuse method, which fuse will power the amp ONLY when I turn on the car? (to prevent constant power so battery is not drained)
Second. Im planning on keeping the headunit (already have had cars broken into because of aftermarket HU.
IF I get new speakers, Knowing our non RF headunits have a low rms output, will adding a four channel amp bring the new speakers rms potential?
Thanks
leviathann666 is offline   Reply With Quote Quick reply to this message
Old January 28th, 2012, 09:21 PM   #2 (permalink)
Vehicle: 07 GT Eclipse
fst-fwd is a jewel in the roughfst-fwd is a jewel in the rough
Buy an ADD A FUSE and a DMM to test which fuse works when the key is turned on.
you can always add an amp, not sure what your asking on the RMS, RMS is root mean square or the power a speaker can take for a long period of time. if you add an amp, i would add new speakers as well, this will give you more power to the new speakers vs. factory.
Black 07 GT, WORKS header back exhaust cat delete,Injen SRI,Outlaw spacers, Stiffy, rear sway bar,underbrace,Strut bar,Tanabe springs,MOMO pedals, Optima battery,BIG3 upgrade, 20" IICrave wheels sitting on 35s', carbon fiber hood, polyurethane front lip, Ipad integrated audio system...
fst-fwd is offline   Reply With Quote Quick reply to this message
Old January 28th, 2012, 10:03 PM   #3 (permalink)
Selling 4G & Parts.
cmattox23's Avatar
6 Highscores
Vehicle: '07 Eclipse SE
cmattox23 is a name known to allcmattox23 is a name known to allcmattox23 is a name known to allcmattox23 is a name known to allcmattox23 is a name known to allcmattox23 is a name known to all
If you upgrade your speakers and add a 4 channel amp it will provide power to those speakers you wired it to..its a lot of time to run the wires though.
Sent from my iPhone 5 using Tapatalk
Originally Posted by kazman View Post
still the car i look up to when it comes to stance
follow me @usversusthem
cmattox23 is offline   Reply With Quote Quick reply to this message
Old January 28th, 2012, 10:18 PM   #4 (permalink)
Thanks guys.
What I meant by rms was, with my stock non RF HU, When I put new speakers and add an amp for the new speakers and connect it to the HU. Will the stock HU be able to "deliver" enough juice thru the amp for the new speakers to sound lowder than the stock ones?
The other part was another issue, Im installing a mono amp and sub, the only thing left is to connect the remote wire. From your experience, what cable do I use from the stock headunit to power the amp when the ignition is on? or should I just wrap the remote to a fuse and put the fuse back in?
Old January 29th, 2012, 11:02 PM   #5 (permalink)
If you use the stock headunit you will need a hi/low converter, the amp will get the signal it needs, and the amp will provide the power for the speakers.
Too be honest with you i dont remember which wire it is, but i did use an add a fuse which will have a wire coming out that you can add a remote wire too. I can look tom. And let you know.
aftermarket, battery, blue, broken, car, cars, connection, fuse, headunit, posts, power, question, remote, speakers, wire
