| Audio & Lighting Head units, subs, amps, caps, neon lighting, LEDs, and anything else that uses a DC power source not tuning related goes here. |
Christian
08 Spyder GT/MT
Outside dimmer undercar lights
Ok I searched and im surprised no one's done this.
What I want to do is have under car lights that light up and dim the exact same way the dome light does when you unlock the car with the remote. My question is how can I achieve that? I'm not familiar with electrical but I'm handy so any advice would be appreciated. Sent from my HTC Desire HD using Tapatalk
Don Glisson
2008 Eclipse GT
I would not try and use the same dimmer circuit. Even with LEDs it still might be too much of a current drain/load. Expect you will have to get another dimmer module and trigger it off the door switch just like the dome but using a completely different ckt. Good luck with this....hope it is worth the effort.
Christian
08 Spyder GT/MT
So am I just wiring up a relay to the dome light and then connecting everything from there? Is that something I wire directly from the fuse box inside the car?
Christian
08 Spyder GT/MT
Fairly straight forward then? Do I need that particular relay or if not what relay will do?
07 GT Eclipse
Most likely a SPDT RELAY (single pole double throw) prefer Bosch.
Black 07 GT, WORKS header back exhaust cat delete,Injen SRI,Outlaw spacers, Stiffy, rear sway bar,underbrace,Strut bar,Tanabe springs,MOMO pedals, Optima battery,BIG3 upgrade, 20" IICrave wheels sitting on 35s', carbon fiber hood, polyurethane front lip, Ipad integrated audio system... |
| car, electrical, htc, light, lights, lock, question, remote |
