Interior Lights - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old August 12th, 2012, 11:28 AM   #1 (permalink)
oldmike is on a distinguished road
Interior Lights
Hey, just a few newbie questions. I have a 07 GS. I think previous owner did a few mods on the interior lighting and I'm trying to get back to stock. I didn't get an owners manual so the sticky on factory bulbs helped a lot. OrangeDemon had a good listing. (below)
2007 Mitsubishi Eclipse Light Bulb Fitment Application List:
2007 Mitsubishi Eclipse High & low beam headlight uses H13 (9008) bulb.
2007 Mitsubishi Eclipse Tail light uses LED bulb.
2007 Mitsubishi Eclipse Stop light uses LED bulb.
2007 Mitsubishi Eclipse High mount stop light uses LED bulb.
2007 Mitsubishi Eclipse Fog/Driving light uses H11 bulb.
2007 Mitsubishi Eclipse License plate uses 168 bulb.
2007 Mitsubishi Eclipse Back up light uses 3156 bulb.
2007 Mitsubishi Eclipse Rear sidemarker uses 168 bulb.
2007 Mitsubishi Eclipse Glove box uses 74 bulb.
2007 Mitsubishi Eclipse Step/Courtesy light uses 74 bulb.
2007 Mitsubishi Eclipse Trunk/Cargo area uses DE3022 bulb.
But I still have questions. Did our cars come with blue bulbs? I replaced the blue dome light with DE3175. Same wattage and it works fine. What do the map lights take? I have the autodim mirror. Also where are the step courtesy lights? Also the 74 bulbs I found at Autozone are TINY. Don't look like they would put out much light.
Thanks for any help,
Mike
oldmike is offline   Reply With Quote Quick reply to this message
Old August 12th, 2012, 11:47 AM   #2 (permalink)
disillusions's Avatar
Vehicle: 06 Eclipse GT
disillusions is a jewel in the roughdisillusions is a jewel in the rough
Mike
Our cars come with halogen lights for all of the lighting sources sans the gauge cluster, HVAC, sound system, and shifter assembly. The map lights take T10 bulbs. There are no step courtesy lights that I know of; at least, I've never had them or seen any cars with them (but now I want to hunt them down if they exist). The only lights that I know of that come on as courtesy lights is the dome. The 74 bulbs are definitely tiny, but if you go LED then they will definitely light up a very good amount. Plus, the only 74 that I know we use on the interior is the glove box.
Function: AEM CAI; Tanabe AB; Sickspeed oil catch can; Brembos; Outlaw Engineering spacers w/bypass
Form: DDM HID 5k; Konig Illusions; Kuhmo rubber; Spoon Sports reservoir socks; Plastidip'd; Iconic Designz headlights; Ralliart eyelids; OEM fangs
Welcome to North 4G Korea
disillusions is offline   Reply With Quote Quick reply to this message
Old August 12th, 2012, 11:55 AM   #3 (permalink)
ClipsGT's Avatar
Vehicle: 07/Eclipse/GT
ClipsGT is a jewel in the roughClipsGT is a jewel in the rough
I have an 07 gt. I have the same mirror my map lights are 192L. I'm sure you can use 168,194 bulbs also in there. No the stock lights are white. I do not have step courtesy lights either. The 74's are not real bright but just get'em in white LEDs.
ClipsGT is offline   Reply With Quote Quick reply to this message
Old August 12th, 2012, 07:02 PM   #4 (permalink)
Thanks for the quick answers, guys. I went to the car and did more research. My map lights have to be 192, 194 etc. because there is that type socket, not T10 if I'm understanding what a T10 is. (Little cylinder with metal caps on each end) I guess the 10 is for how long it is. I also can't find floor courtesy lights. I can't even find the glove box light!! Could someone kinda explain where to find it.
Thanks again,
Mike
Old August 12th, 2012, 08:25 PM   #5 (permalink)
Thanks again,
Mike
That's my mistake. I meant T-3 (194/168). I used LEDs for it, so they weren't going by the 194/168 sizing guide. Now, the glove box light, this one is a little more involved. You have to remove the glovebox first, so what you do is you open it up and unhook the string on the right side of the glove box. Once you do that, let it drop, then push up on the back until it pops out. Locate the 4 screws, then pull it out towards you and a little down. After that, you'll be able to see the little 74 bulb that's in there. Turn on the interior lights if you need to locate it easily. Plug it in, then reassemble.
If you're going to replace the bulbs, then why not replace them with super white LEDs? The halogens are shit for visibility, and there's just no reason not to, lol.
Here, check mind out with the super whites:
Disillusion's Cookie Monster
Old August 13th, 2012, 11:37 AM   #6 (permalink)
isai's Avatar
Vehicle: 2008/Eclipse/Gt Black
isai is on a distinguished road
so if i want some blue dome lights which is the exact ones to look for in ebay?
isai is offline   Reply With Quote Quick reply to this message
Old August 13th, 2012, 11:48 AM   #7 (permalink)
Screw eBay, lol. But you want a DE3022 for the dome light. Unless you're talking about the front dome lights that come with the non-sunroof version; in which case, I don't think they're the same size, but I'd have to look to see exactly which they are.
Old August 13th, 2012, 02:12 PM   #8 (permalink)
isai's Avatar
nah i have the sunroof and ohh the ones in ebay suck?
Old August 13th, 2012, 05:14 PM   #9 (permalink)
I don't know if they suck, I just always use superbrightleds.com, and I've never had a problem. Okay so the dome light right behind the sunroof takes a DE3022 festoon type bulb. The map lights within the auto-dimming rear view are T3-1/4 types. They replace 194/168 bulb sizes. I'm using the 5 LED pattern in my car, and let me tell you, they look like little fog lights when they're on. Tons of light.
Old September 1st, 2012, 09:26 AM   #10 (permalink)
FlareneX's Avatar
Vehicle: 09 Eclipse GT
FlareneX will become famous soon enough
superbrightleds.com use the vehicle finder then order your bulbs. cargo and dome light use the same size bulb. rearview mirror lights are size T10
FlareneX is offline   Reply With Quote Quick reply to this message
Old September 18th, 2012, 02:37 PM   #11 (permalink)
eclipsepat06's Avatar
Vehicle: 2006 eclipse gt
eclipsepat06 will become famous soon enough
my dome light and truck light are different sizes.... i got a 3022 from ddm tuning and it fit in the dome but not in the trunk... the truck looks to be a smaller festoon.
eclipsepat06 is offline   Reply With Quote Quick reply to this message
Old September 18th, 2012, 02:48 PM   #12 (permalink)
It fits, you just need to persuade it a little bit. By that, I mean bend the outer arm and dent in the edges of the festoon to make it fit.
Old September 18th, 2012, 03:38 PM   #13 (permalink)
FlareneX's Avatar
is this because your 4G is an 06 and mine is an 09? I got that ize from superbrightleds and the same bulb fit in the trunk and dome. although I did have to bend the connectors in the trunk a little bit to make it fit. as long as tehre is a connection on the ends its fine, doesnt have to fit perfectly
Old September 18th, 2012, 03:39 PM   #14 (permalink)
FlareneX's Avatar
same thing I just told him. thats two of us that had to jerry rig it a little bit to get it to fit
Old September 18th, 2012, 09:10 PM   #15 (permalink)
yaaa i just shoved it in there pretty hard an bent it a little bit an it fit! thanks
Old September 18th, 2012, 10:44 PM   #16 (permalink)
Yeah, man! Great minds think alike, haha.
Glad it all worked out I've always had that problem with the trunk DE3022 bulbs, so it's kind of par for the course.
Old September 24th, 2012, 04:55 PM   #17 (permalink)
Jerzey G
Anthony27's Avatar
Vehicle: 2006 Eclipse Custom
Anthony27 is a jewel in the roughAnthony27 is a jewel in the rough
sent from Jersey
Anthony27 is offline   Reply With Quote Quick reply to this message
Old September 24th, 2012, 04:56 PM   #18 (permalink)
Jerzey G
Anthony27's Avatar
g-men
sent from Jersey
Old September 24th, 2012, 04:56 PM   #19 (permalink)
Jerzey G
Anthony27's Avatar
blue clock leds, super easy install
sent from Jersey
Old September 24th, 2012, 04:58 PM   #20 (permalink)
Jerzey G
Anthony27's Avatar
just can't figure out how to get my damn compass working.
sent from Jersey
Old September 24th, 2012, 05:07 PM   #21 (permalink)
Fresh n Clean is how I B
Cubansoldier20's Avatar
Vehicle: 09 Mitsubishi Eclipse GS
Cubansoldier20 is just really niceCubansoldier20 is just really niceCubansoldier20 is just really nice
How did you install the custom lighting in the clock display? I have done eeevery bulb on and in my car except that one lol.
Cubansoldier20 is offline   Reply With Quote Quick reply to this message
Old September 24th, 2012, 05:57 PM   #22 (permalink)
Jerzey G
Anthony27's Avatar
take top dash out ,/ 2 screws on top come out/ pull off unit/ untwist two bulbs / pull bulb out and replace/ reassemble :thumbup:
sent from Jersey
Old September 24th, 2012, 10:23 PM   #23 (permalink)
sent from Jersey
Cool, thanks, what size are the bulbs? Do you know off the top of your head?
Old September 24th, 2012, 10:25 PM   #24 (permalink)
74
Old September 24th, 2012, 10:34 PM   #25 (permalink)
74
thanks much are they festoon bulbs like the trunk light?
Old September 24th, 2012, 10:49 PM   #26 (permalink)
NP. They're actually wedge types, like the bulbs in the rear view mirror (assuming you have the sunroof). If you've done every bulb, like you said, then you've come across the size before. It's the same as the glove compartment bulb.
Old September 25th, 2012, 07:07 AM   #27 (permalink)
Oh ok, yea I don't have the sunroof model, wish I did, but ok thanks, I think I have a good idea of what you are referring to.
Old September 25th, 2012, 07:45 AM   #28 (permalink)
Yeah, I wasn't sure. These are the ones you want:
74 LED Bulb - 3 SMD LED Wide Angle Wedge Base | Miniature Wedge Base LEDs | LED Car Bulbs | Super Bright LEDs
Old September 25th, 2012, 08:28 AM   #29 (permalink)
FlareneX's Avatar
Cuban, those are the exact bulbs I bought to replace the clock display and glove box. haven't got around to but after reading this thread I think im going to try and install them tonight...if I get time. I'll snap pics of the process and post em up tonight if I get time
Old September 25th, 2012, 08:47 AM   #30 (permalink)
Jerzey G
Anthony27's Avatar
sent from Jersey
its super easy you dont even have to unplug the clock unit, just pop it up and they be two black bulb holders , you untwist them counter clock wise , pull the old bulb out and replace vwala:sly:
sent from Jersey
Old September 25th, 2012, 08:48 AM   #31 (permalink)
Jerzey G
Anthony27's Avatar
sent from Jersey
correction* i cant get my thermostat to pop back on, any takers for advise?
sent from Jersey
Old September 25th, 2012, 08:49 AM   #32 (permalink)
Jerzey G
Anthony27's Avatar
what color did you get?
sent from Jersey
Old September 25th, 2012, 09:17 AM   #33 (permalink)
There are actually a few writeups about the clock pod install floating around the forum. There's also one detailing how to take off the glovebox; which takes all of ten minutes if you're taking your time. Plus as Ant already showed you, it looks like this when it's all finished:
Old September 25th, 2012, 09:42 AM   #34 (permalink)
FlareneX's Avatar
sent from Jersey
blue from superbrightleds. replaced dome, trunk, rearview mirrior lights and now going to do the glove and clock. All i can say is she glows blue at night cant wait to do the clock tonight. end of the work day cant come fast enough
Old September 25th, 2012, 09:50 AM   #35 (permalink)
Jerzey G
Anthony27's Avatar
i hear you, lol just be sure not guaze in its hypnosis of attraction as your driving:thumbup:
sent from Jersey
Old September 25th, 2012, 09:51 AM   #36 (permalink)
Jerzey G
Anthony27's Avatar
yes its right there , the thing that says ICE doesnt work at all :thumbdown::banghead::banghead::beer:
sent from Jersey
Old September 25th, 2012, 09:59 AM   #37 (permalink)
sent from Jersey
Check your connections, make sure it's nice and snug. Jiggle some wires if you need to....and be sure your ground is nice and tight.
Old September 25th, 2012, 05:28 PM   #38 (permalink)
Jerzey G
Anthony27's Avatar
fixed~
sent from Jersey
Old September 25th, 2012, 06:49 PM   #39 (permalink)
Jerzey G
Anthony27's Avatar
trunk LED :sent from Jersey
Old September 25th, 2012, 06:50 PM   #40 (permalink)
Jerzey G
Anthony27's Avatar
led everything
sent from Jersey
application, back, box, cars, eclipse, fitment, fog, good, h13, headlight, interior, led, license, light, lighting, lights, manual, mitsubishi, owners, plate, questions, rear, stock, stock., works
Are these the lights I need for the interior? The Banana Man Interior and Exterior Modifications (Show) 2 November 26th, 2011 04:35 PM
Interior lights question froggy Audio & Lighting 3 March 21st, 2010 11:58 PM
Interior lights Cheez Interior and Exterior Modifications (Show) 42 August 19th, 2009 07:41 PM
Interior Dash Lights da1nonly Audio & Lighting 3 October 8th, 2008 10:48 PM
Interior neon lights? CJudge Audio & Lighting 11 April 14th, 2008 07:21 PM
