The ultimate guide to Projectors/Halos/HIDs/and how to align it all together - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old September 26th, 2008, 12:33 PM   #1 (permalink)
>>4G loving Jeep SRT8<<
j-rod's Avatar
17 Highscores
Tournaments Won: 103
Name: Jay to the F'N Rod
Vehicle: 69 Cadi (07 Spyder GT)
j-rod has a reputation beyond reputej-rod has a reputation beyond reputej-rod has a reputation beyond reputej-rod has a reputation beyond reputej-rod has a reputation beyond reputej-rod has a reputation beyond reputej-rod has a reputation beyond reputej-rod has a reputation beyond reputej-rod has a reputation beyond reputej-rod has a reputation beyond reputej-rod has a reputation beyond repute
to do this right i need break all of the sections up then fill in the blanks afterwards.
Projector and HID How-To writeup exists in Garage.
Projectors.
they come in two finishes Black and Chrome
  • when looking at the drivers lamp the bulb to the outside is the blinker (which when installed simply uses ur factory bulb)
  • then continuing in the next light is referred to as a Projector (this has a deflector built in to keep from blinding other drivers)
  • the last light is the High Beam (when u purchase a set of Projectors know that they use H1 style bulbs not H13 like your stock lamps use)
projectors are a great addition to any car but be warned they are not as high of quality as your stock lamps but there is a company named CincityDesigns.com that can replace or improve anything on your stock or projector lamps.
Cons;
  1. the leds above the lights are very cheap and dull
  2. the light clips that hold the lights in the housing break very easly
  3. the halos (the ring around the lights) are dull and seem to burn out fast
  4. they are known to come to the customer with poor seals (this is the seal that is between the clear lamp and the housing) and need to be sealed before installiation
Pros;
  1. a whole new look to the exterior of the car
  2. separates the high and low beams
  3. are inexpensive and allow the owner to buy cheaper light bulbs
__________________________________________________ __________________________________________________ ____
Angel Eyes
are some times referred to as Halos. they represent a ring of light simular to 2000 model bmws.
these can be preformed on the stock 4G lamps.
they sell the kits available online but they are risky and envolved (but if u are a DIYer go ahead a try it out)
but like stated above there is an alternative a company called CinCityDesigns.com can produce this as well as paint and modify the lamps to your wildest dreams.
pros;
  1. you get a new look for a small amount of money
  2. when others get projectors (for the halos) you'll know yours will at least be seen
  3. is custom
cons;
  1. have to take your existing lights out and carefully seperate the lamp (might not be able to drive the car until lights are finished)
  2. could break while installing, the halo could fall off, etc
HIDs
are a must have for any vehicle
but in the 4G's case it has a drawback
the HIDs require you to disable the DRLs (Daytime Runing Lights)
  • Stock Lamps only have one bulb so to have Low and High beams you'd need to buy Bi-Xeon H13s (have yet to be told of a PLUG and PLAY set).
  • Projectors allow you to buy two sets of much cheaper H1s (which are plug and play)
to lean how to disable the DRLs. refer to this link. (i would advise you to simply bend the post. Do not remove it completely)
HOW TO: Disable Day Time Running Lights (DRL)
aligning Stock Lamps with HIDs
follow this link
http://club4g.org/board/electronics-...eadlights.html
j-rod is offline   Reply With Quote Quick reply to this message
Old November 14th, 2008, 07:16 AM   #2 (permalink)
<3's bewbz
LPfenix182's Avatar
Vehicle: 07 Eclipse GS
LPfenix182 has much to be proud ofLPfenix182 has much to be proud ofLPfenix182 has much to be proud ofLPfenix182 has much to be proud ofLPfenix182 has much to be proud ofLPfenix182 has much to be proud ofLPfenix182 has much to be proud ofLPfenix182 has much to be proud of
is there any specific voltage for the H1 bulb? lol I don't even know if that's a legitimate question all I kno is my passenger headlight went out yesterday nd now I need a new bulb lol...sorry I can't search either I'm on my fone
LPfenix182 is offline   Reply With Quote Quick reply to this message
Old November 14th, 2008, 01:12 PM   #3 (permalink)
<3's bewbz
LPfenix182's Avatar
nvm..got it cause im awesome
Old January 15th, 2009, 03:45 PM   #4 (permalink)
ppimpbyblood11 is on a distinguished road
very good write up
ppimpbyblood11 is offline   Reply With Quote Quick reply to this message
Old January 15th, 2009, 04:24 PM   #5 (permalink)
a=dv/dt
Matt-Man's Avatar
Vehicle: 2008 ECLIPSE GS
Matt-Man has a reputation beyond reputeMatt-Man has a reputation beyond reputeMatt-Man has a reputation beyond reputeMatt-Man has a reputation beyond reputeMatt-Man has a reputation beyond reputeMatt-Man has a reputation beyond reputeMatt-Man has a reputation beyond reputeMatt-Man has a reputation beyond reputeMatt-Man has a reputation beyond reputeMatt-Man has a reputation beyond reputeMatt-Man has a reputation beyond repute
I love you
Selling E4E rear and sides, will need to be refinished and repainted. Pm me
Matt-Man is offline   Reply With Quote Quick reply to this message
Old January 20th, 2009, 08:41 AM   #6 (permalink)
j-rod's Avatar
17 Highscores
will also do a how to install HIDs as well when i get time
Old February 2nd, 2009, 11:50 AM   #7 (permalink)
Mitsuwhat's Avatar
Vehicle: 2006/Eclipse/GS
Mitsuwhat is on a distinguished road
Has there been a How to HID intall on stock lamps been made? I thought I remember seeing it but cant seem to find it now. Even through search.
NVM I GOT IT!
Did I really miss the HUGE lettering on the top of this thread....
Mitsuwhat is offline   Reply With Quote Quick reply to this message
Old February 4th, 2009, 10:41 PM   #8 (permalink)
"Panty Dropper"
REDLiNE's Avatar
Vehicle: 2008 Eclipse GS
REDLiNE has a reputation beyond reputeREDLiNE has a reputation beyond reputeREDLiNE has a reputation beyond reputeREDLiNE has a reputation beyond reputeREDLiNE has a reputation beyond reputeREDLiNE has a reputation beyond reputeREDLiNE has a reputation beyond reputeREDLiNE has a reputation beyond reputeREDLiNE has a reputation beyond reputeREDLiNE has a reputation beyond reputeREDLiNE has a reputation beyond repute
yeh but theres nothing showing how to install hids to regular headlights.unless im missing something
http://www.cardomain.com/ride/3082857
-08' Eclipse GS--Fujita CAI,Powder Coated Rims(Matt Black)Smoked Tails,GSX spoiler,Painted Emblems,Magnaflow Cat-back Exhaust,8K HiDS
REDLiNE is offline   Reply With Quote Quick reply to this message
Old February 4th, 2009, 10:42 PM   #9 (permalink)
"Panty Dropper"
REDLiNE's Avatar
nvm haha
Old February 20th, 2009, 04:07 PM   #10 (permalink)
just me.
XEN_owner's Avatar
Vehicle: 07/GS/MT
XEN_owner is on a distinguished road
how do u seal the projectors? both head and tail lights? and how do you install HID's?
Fujita CAI, Magnaflow Catback Exhaust, Tein S-Tech Springs, Tenzo type R weight Shift Knob, Nokya E- Brake Handle, Ralco Short Shifter, Black Projector Head lights, Black LED Tail lights, Halo Fog Lights, 12k HID, pioneer single din DVD player and 18 inch black and silver lining Dolce rims, and Carbon Creation Carbon Fiber Trunk Latch.
XEN_owner is offline   Reply With Quote Quick reply to this message
Old March 12th, 2009, 08:00 PM   #11 (permalink)
Sharpie Guy
jared15421's Avatar
Vehicle: 2008 SE
jared15421 is a jewel in the roughjared15421 is a jewel in the rough
Do you have to remove the bumper in order to take the headlights out?
jared15421 is offline   Reply With Quote Quick reply to this message
Old March 12th, 2009, 10:26 PM   #12 (permalink)
a=dv/dt
Matt-Man's Avatar
yes, see the write up in the garage
Old March 13th, 2009, 08:38 AM   #13 (permalink)
j-rod's Avatar
17 Highscores
Old May 23rd, 2009, 11:47 AM   #14 (permalink)
Scrape Artist
kazman's Avatar
kazman has a brilliant futurekazman has a brilliant futurekazman has a brilliant futurekazman has a brilliant futurekazman has a brilliant futurekazman has a brilliant futurekazman has a brilliant futurekazman has a brilliant futurekazman has a brilliant futurekazman has a brilliant futurekazman has a brilliant future
can somebody please tell me how to adjust the HID bulbs?? i just installed them and the right one is sorta weak and the left one is hella bright with a big circular beam of lighta.. almsot as its focusing in on a circular spot??
plz help?!?!
Just
lower Slam the shit out of
It
-----Break free from the chains of conformity-----
"There are a lot of us who are caught up in this hell we all live in,
Content with being blinded by rules and judgment.
We live in a world where it's more okay to follow than to lead.
In this world being a leader is trouble for the system we are all accustomed to.
Being a leader in this day and age is being a threat." - Common
kazman is offline   Reply With Quote Quick reply to this message
Old May 23rd, 2009, 12:40 PM   #15 (permalink)
I'm Rich Bitch!
Ghost's Avatar
Vehicle: 06 Eclipse GT
Ghost has much to be proud ofGhost has much to be proud ofGhost has much to be proud ofGhost has much to be proud ofGhost has much to be proud ofGhost has much to be proud ofGhost has much to be proud ofGhost has much to be proud ofGhost has much to be proud of
I got the same problem cept my shit points at the ground and it doesn't shine far out its just like 5 feet
18" HPD Cool Down Rims Projector Headlights Black LED Tail-Lights Import Trens Carbon Fiber Hood Import Trens Carbon Fiber Fenders Cucso StrutTower Bar Fujita CAI Magnaflow Catback Exhaust RRE Headers Tanabe Underbrace Bar 2 12' JL W6V2 with a JL 1000.1/2 amp with a Jensen flip out head unit Eclipse SE 6.9's Eclipse SE 6.5's with JL tweeters Planet audio 400.4. 10k hids Compustar alarm Drilled/slotted rotors ss break lines.Prokit.
Ghost is offline   Reply With Quote Quick reply to this message
Old May 23rd, 2009, 09:30 PM   #16 (permalink)
Scrape Artist
kazman's Avatar
ghost have u tried adjusting the headlights??? like the projectors them selves!?
Just
It
Old May 23rd, 2009, 09:35 PM   #17 (permalink)
ALBOE's Avatar
Vehicle: 2000 Audi A4 quattro
behind your projector housing, you're gonna see/feel two 8mm socket screws. One will be on the left hand side of the low beam, and the other one will be on the right hand side. The one that's closest to the fender will be the one that adjusts the up/down beam, and the one that's close to the radiator will adjust left/right.
ALBOE is offline   Reply With Quote Quick reply to this message
Old May 23rd, 2009, 10:01 PM   #18 (permalink)
Gots me a sooby
Ballfade's Avatar
Vehicle: 02 wrx
^ what have you not screwed with yet alex
Ballfade is offline   Reply With Quote Quick reply to this message
Old May 23rd, 2009, 10:03 PM   #19 (permalink)
ALBOE's Avatar
the chick that sits next to me
Old May 23rd, 2009, 10:06 PM   #20 (permalink)
Scrape Artist
kazman's Avatar
ya what he said^
but how do u adjust the bulb.... so this doesnt happen??
My left on is fine but my right.. like wtf?
Do i have them in crooked or what?? upside down maybe?
Here both of them together
heres the left by itself
And the right...
Just
It
Old May 23rd, 2009, 10:21 PM   #21 (permalink)
ALBOE's Avatar
both of my bulbs only went in one way because of the following stick thingy
so I don't think there are multiple ways to get those HID's in there. Please correct me if I'm wrong. you may just need to adjust them.
mine were kinda like that too. One of them was perfect lighting up the trees and the ditch, and the other one was like literally not there pointing at the fog lights
I'll check that for you whenever I get home.
Old May 23rd, 2009, 10:27 PM   #22 (permalink)
Scrape Artist
kazman's Avatar
that would be awsome! but the thing is i alrdy have them adjusted the headlights!! c/ i had to adjsut them when i installed them.... so idk! i think i might have put it in differently... it was sorta hard to put in.. it wsa RLLLLLYY snug i wsa almost forcing it! but both were like that so idk
but id appreciate it alot!!
Just
It
Old May 24th, 2009, 10:27 AM   #23 (permalink)
Scrape Artist
kazman's Avatar
any one??
Just
It
Old May 24th, 2009, 05:46 PM   #24 (permalink)
ALBOE's Avatar
I couldn't find anything else to move/adjust
deffective housing?
Old May 24th, 2009, 07:05 PM   #25 (permalink)
Scrape Artist
kazman's Avatar
lol naw i figured it out.. ididnt have to bulb sitting right! there was a wire int eh way and i thought it was in all the way but i readjusted the bulbs an theyre fine now...
But thanks again alboe for checking... i really appreciate it!
Just
It
Old May 24th, 2009, 07:50 PM   #26 (permalink)
ALBOE's Avatar
Old June 3rd, 2009, 07:45 PM   #27 (permalink)
Vehicle: 2007 Eclipse GS / SunsetP
OhioGS is on a distinguished road
awesome thread.. glad I found this
OhioGS is offline   Reply With Quote Quick reply to this message
Old January 2nd, 2010, 08:10 AM   #28 (permalink)
redlenses's Avatar
Vehicle: 08 GT Spyder
redlenses has a spectacular aura about
So a few questions:
2006-2008 stock headlights have one main light that is used for DRL, low beam, and high beam, correct? The low beam is used for both the DRLs and low beam depending on the voltage being sent (hence the problem with using an HID in DRL mode)? The high beam uses an independent power line right?
2009 stock are HIDs right? Are the bi-xenon? How does DRL work on 2009 stock headlights - i.e. do they have different wiring so that the HID is lit with full voltage when in DRL mode? Are the 2009 headlights plug and play with 2006-2008 models i.e. can you swap the full headlight housing?
Are HID upgrades to 2006-2008 stock headlights legal in California? Does any of this void the electrical warranty?
When people put Halos in their cars, do they use them for DRL? Is that legal? Or are halos usually on their own custom switch?
For the projector lights in the first pictures, what triggers the top LEDs coming on? What triggers the Halos coming on? What about the two little lights next to the LEDs? Does this light housing work as a direct replacement, i.e. do DRLs work?
Are all "projector" lights (for the eclipse) HIDs? i.e. there aren't halogen projectors on any eclipses are there?
redlenses is offline   Reply With Quote Quick reply to this message
Old January 2nd, 2010, 08:12 AM   #29 (permalink)
redlenses's Avatar
From what I've heard, Stock Projectors include a second halogen bulb to do DRL.
For the Aftermarket projectors, do they include a halogen bulb for DRL? Are the Halos & LEDs run off the DRL or parking lights or what?
Old January 31st, 2010, 01:45 PM   #30 (permalink)
"Panty Dropper"
REDLiNE's Avatar
so when i order the projectors im going to have to go with the H1 HID kit instead of the h13 kit i have now?
Old March 3rd, 2010, 02:34 PM   #31 (permalink)
Vehicle: 2010 GT
Emoq8 is on a distinguished road
sounds cool ;p
Emoq8 is offline   Reply With Quote Quick reply to this message
Old March 3rd, 2010, 08:00 PM   #32 (permalink)
redlenses's Avatar
Bump - hoping someone will answer
Old December 22nd, 2011, 11:38 PM   #33 (permalink)
Much Parts, Little Money.
PearlGreenNMean's Avatar
Vehicle: 2009/Eclipse/GS
PearlGreenNMean is a splendid one to beholdPearlGreenNMean is a splendid one to beholdPearlGreenNMean is a splendid one to beholdPearlGreenNMean is a splendid one to beholdPearlGreenNMean is a splendid one to beholdPearlGreenNMean is a splendid one to beholdPearlGreenNMean is a splendid one to behold
Originally Posted by redlenses View Post
So a few questions:
Correct. Independent? I couldn't tell you. Maybe there is a resister or something in the plug... Who knows. Its a mystery. ;]
Wrong. My 09 came with halogens.
Are the bi-xenon?
Read above answer.
Not sure, because Its an option to get HID, not standard. I'm pretty sure that its bi-xenon, so the shutter is simply shifted, while the power outtage is the same. Don't qoute me. This is hypothetical.
Uhmm, I don't believe so. There were members who have done this before, with extreme hassle I believeee...
If its an Halogen based headlight, then yes. Thats illegal.
Halo's? I believe those are ALL legal except Blinking red/blue colors. They can be ran with a switch, or run parallel with your parking lights.
What ever you want. If you hooked them to a switch, than the switch. If you put them in with the parking lights, then those.
Read above.
Yes it should. The DRL's will cause flicker. Leading you, to disable them by bending the correct pin. (Search button, Disable DRL)
The reason for "Projectors" is to Angle that Massive amount of light beam to the road effectively, without passing glare to the oncoming driver.
I'll pass on this question.
The halogen in A,M. headlights are your "High beams" Your H.I.D.'s are "Low beams" There fore, your Drl's... That will cause Flicker though, so you need to disable it. And yes, The Extra Lights run off the parking light.
I ANSWERED THESE TO HELP PEOPLE WITH SIMILAR QUESTIONS, I WAS FEELING PRODUCTIVE.
HAVE: Full Bolt On - OBX headers, cai, RRE pulley, Aero Turbine, Projectors, Hackish tune, D2 Coilovers, Volt stabilizer, eibach sways, under brace & strut tower bar tanabe
SOON: Turbo w/ arp head studs, mounts.
WANT: Ingals Stiffy... Hmu if you're selling <3
PearlGreenNMean is offline   Reply With Quote Quick reply to this message
Old January 26th, 2012, 06:22 PM   #34 (permalink)
Long live the queen.
MissChriss's Avatar
Vehicle: 2007/Eclipse/SE
MissChriss will become famous soon enough
Would you happen to know what bulb size the halo/angel eyes are? My friend has the dual halo lights for his mazdaspeed and he was able to change the inner ring to blue, but doesn't know what size it was because he got it professionally done.
Let me know, and if I'm asking the wrong question in the wrong thread, I apologize. I figured it was better than starting a new thread.
2007 Eclipse SE----CLICK ME!
MissChriss is offline   Reply With Quote Quick reply to this message
Old January 30th, 2012, 11:49 AM   #35 (permalink)
KJR
KJR's Avatar
KJR is on a distinguished road
I clicked on the link on "How to disable DRL" but my question is where is the red ecu that I need to bend? I couldnt view the pictures posted on that thread. Currently my lights flicker during the day obviously due to the DRLs.
KJR is offline   Reply With Quote Quick reply to this message
Old January 30th, 2012, 02:16 PM   #36 (permalink)
MissChriss's Avatar
When you open the box there's another smaller box to the right if you're on the driver side of the car. The ECU that you need is in there. It helps with the pictures though.
Don't be discouraged if you can't find it. It took me an hour to figure out where it was until I realized there was another small box to open.
Old January 30th, 2012, 02:45 PM   #37 (permalink)
KJR
KJR's Avatar
So theres a smaller box inside the ECU I need to open?
Old January 30th, 2012, 07:46 PM   #38 (permalink)
KJR
KJR's Avatar
Nvm I got it. I was able to viewthe pictures on a different computer. That was a easy fix . Good guide.
Old March 9th, 2012, 01:47 AM   #39 (permalink)
Vehicle: 2008 gs
ironic.irony1 is on a distinguished road
Hey all. I lost to a parked car the other day. Yeah, it was parked, yeah, I hit it. Anyway, it broke my RH headlight assembly. I upgraded my '08 OEM bulbs with HIDs and LOVE them. They run all the time, even during the day due to the daylight running lights - but that's fine, I don't mind. My problem is this - a new OEM headlight assemble is a few hundred new, and about $120-160 on ebay including shipping. Like I said, I love the OEM lenses with my HID upgrade, but if I'm going to spend the money, should I consider looking at the more prolific dual projector assemblies. I'm not too keen on the LEDs - the halos might be kinda cool, but I'm more concerned with putting light on the road. I'm not advertising for these guys, but they seem to have a popular looking model of the projector/halo assemblies available on ebay. Any direction / advice would be greatly appreciated. I hate driving my car with a 'patched' lens so I want to do this as soon as possible. But I don't what to buy some crap assembly that is gonna leak or crack or whatever. I have the joy of -30 - +30 weather throughout the year, plus sand and gravel in the winter so I don't want some cheap lens that's gonna scratch either. So - stock or after market? And if after market - anyone have a good experience they'd like to share? I do A LOT of night driving.
While I'm on the subject of lights, I have a GS with no OEM fog lights. My car seems to have all the wiring harness parts already installed, just no lights, and no switch. Any suggestions on fogs too? Like to keep the same color temp as my HIDs - which are pure white - no blue tint.
http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=140678703426
Last edited by ironic.irony1; March 9th, 2012 at 01:51 AM. Reason: added link for pic
ironic.irony1 is offline   Reply With Quote Quick reply to this message
Old March 27th, 2012, 09:47 PM   #40 (permalink)
dsm2mivec's Avatar
Vehicle: 06 Mitsu Eclipse GS
is there a hi/lo kit for h1 aftermarket projectors? i have read almost every thread on here and search the interwebz and i can't find a thing:/
plus this is kinda urgent both my headlights are out and i need to get this done tonight
dsm2mivec is offline   Reply With Quote Quick reply to this message
2006, angel, audio, black, bulb, buy, car, day, eclipse, electronics, eyes, h13, headlights, hid, housing, how to, install, kits, lighting, paint, projector, projectors, sell, show, stock
